I’ve done some changes in your code.
I have only my few models to test it, so it is not tested well.
Probably it may fail for some other models (maybe in different scale, with different constrains etc.).
So rather think about is as a proof-of-concept, then solution for everything.
But for my model works, is faster and can handle models with everything messed up.
But it still not works for my more complex models in animation mode - I don’t understand why, but I not analyzed this method yet.
With less complex models it works and is quite fast
Main changes:
spinCenter is now randomly chosen from inside “bounding box” - it works quite well to avoid stuck in some ‘pitfalls’
rotations are weighted averaged by radius length (so it works like torque right now), for axial spins that (pseudo)radius is refPointsBoundBoxSize
added one more required accuracy step (0.033) - also I think here posAccuracy should not be absolute (it would behave different in different scale models) - should be calculated based on model bounding box size
added lot of debug messages (+ changed DebugMsg to be compatible with print() )
added SOLVER_ONESTEP to do only one step of solving (usefull for debugging)
I attached .patch with changes all together, because your github project is private and I can’t create a branch. a2.patch.gz (4.43 KB)
Thank you very much. Sounds very, very interesting. I did some first tests. For a very small system, solving was succesful. For a medium sized model solving failed. I attach the test file.
I created a branch called “topyra” at github repo. Your patch is already applied. So you can do PR’s if you want. pump-system.fcstd (765 KB)
I found there was as problem in one constrain rigids.
refPointsBoundBoxSize was zero, and I used this as ‘radius’ for axial forces.
As a workaround I expand bounding box by 5 in each direction (not good solution, as every that use fixed number not related to actual model dimensions), but it fixing this issue. I’ll find something better later.
Patch is attached.
But I cant still solve pump-system, but I found interesting thing.
I can’t be solved using ‘a2p_SolverCommand’ - it can’t even go down to 10.0 accuracy.
But when I use ‘a2p_SearchConstraintConflictsCommand’ (conflict finder) it is able to solve it quick in each step with perfect accuracy like 1e-07
Could you please briefly describe differences between regular solver, and solving during searching for conflicts?
Is only difference is adding constrains one-by-one? Or there is some more magic behind? a2.fix2.patch.gz (635 Bytes)
In axial rotation when calculated ‘weight’ of each rotation I temporally put ‘30’ and forgot about that.
So there is next patch (should be applied on one from previous post)
PS I don’t know much about github.com but is this possible to give me permission to commit changes into topyra branch? a2.fix3.patch.gz (1.15 KB)
I applied both patches to branch “topyra” and uploaded the new version to github.
I think i cannot grant commit permissions to a single branch only. That’s a problem.
Usual way is: (but im also not an very experienced git user)
you create your own github accont (it’s free of costs)
fork my A2plus repo to your account at github
clone your A2plus repo to your local machine
checkout the topyra branch on local machine
do your changes
commit them on your local machine
push the changed branch to your repo
on github, use the compare button. After that you can create a pull request, which appears in my repo. I will merge it soon to your branch.
It’s much better to track changes at github than managing patch sets manually.
If to complicated, i can still apply your patches like i do at moment.
Test results of your new changes:
pump-system can be solved now
I attach 2 other files, which now have solving problems with your new version.
P.S: Tomorrow, i try to implement the graphical output for 3D debugging of constraints. I will try to reduce the 3D output somehow to selected rigids/constraints. Perhaps we can trace the problems more exactly. hexapod.fcstd (39.7 KB) machinery-frame.FCStd (442 KB)
Within a2plib.py, there is now a section for debug setup and you can activate a GRAPHICALDEBUG flag:
# do debug settings here:
A2P_DEBUG_LEVEL = A2P_DEBUG_NONE #normal: A2P_DEBUG_NONE
GRAPHICALDEBUG = True #normal: False
# for debug purposes
# 0:normal
# 1:one step in each worklist
# 2:one step in first worklist
SOLVER_ONESTEP = 1 #normal: 0
The GRAPHICALDEBUG is used together with a new function in a2plib:
def drawDebugVectorAt(position,direction,rgbColor):
function draws a vector directly to 3D view using pivy/Coin
expects position and direction as Base.vector type
color as tuple like (1,0,0)
color = coin.SoBaseColor()
color.rgb = rgbColor
# Line style.
lineStyle = coin.SoDrawStyle()
lineStyle.style = coin.SoDrawStyle.LINES
lineStyle.lineWidth = 2
points=coin.SoCoordinate3()
lines=coin.SoLineSet()
startPoint = position.x,position.y,position.z
ep = position.add(direction)
endPoint = ep.x,ep.y,ep.z
points.point.values = (startPoint,endPoint)
#create and feed data to separator
sep=coin.SoSeparator()
sep.addChild(points)
sep.addChild(color)
sep.addChild(lineStyle)
sep.addChild(lines)
#add separator to sceneGraph
sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
sg.addChild(sep)
solver_debug_objects.append(sep)
If GRAPHICALDEBUG==True the imported parts of A2plus get a new boolean property “debugmode”
If you set “debugmode” = True at moment the move function of the corresponding rigid will draw it’s movement vector (blue) and it’s rotation vector (red) to screen. So you can see what the solver is producing.
If the output is getting to much, you can clean up the debug lines with this button:
There are 2 projects:
Project A - and the Assembly file is called assembly.fcstd
Project B - has a sub-assembly also called assembly.fcstd (but is located in another directory)
When the assembly file of Project A (assembly.fcstd) is open, and if you try to import assembly.fcstd of project B into another assembly file, it will effectively import assembly.fcstd from Project A.
A2Plus needs unique filenames. Using same filename but from another directory does not work. This behavior is intended and needed to keep assemblies portable from one machine to another.
Hi all I noticed A2 plus now works with the link version of freecad meaning you can insert a part into the assembly constraint it and then go back later and modify the component and update the assembly this is a great feature
I am new on this forum, and I hope I am in the right thread for my question. I’ve been using FreeCAD for a year now, and I have to say that the A2plus module brings quite a lot of possibilities to the software. Congrats to the owner(s) (kbwbe if I’m right, maybe others, sorry if I missed the names) !
My point of coming here: toponaming issue, there is quite a large number of posts and video on the web, and I understood clearly the main ‘core engine’ of FreeCAD does not help, so when we have a complex assembly with large number of constraints and there is a change in one of the part, … it’s a mess then , everything can be quickly broken and we have to redo all the constraints one by one. I have a suggestion, I don’t know if it has been discussed previously (at least I could not find it), so please excuse me if I missed the right thread. My suggestion would be to edit the sub element in the constraint (property view of dialog box). Today this is not possible from the GUI as it is locked with read only option when created, I guess it is to prevent selecting elements that are not compatible with the initial constraint (?). Changing it from python console works perfectly, for example :
obj =App.getDocument('Sans_nom').getObject('axisCoincident_001')
obj.SubElement1 = 'Face181' # was 180 before
and recomputation works fine. As couple of tests are already implemented to check the selection compatibility with every constraint, I am asking myself if it would be possible to implement such ‘modifyer’ in the WB? The Flow could be something like:
have the subelement label written in the constraint dialogbox and have an ‘update’ button on the right to change it
if update button is pushed, get the result of ‘highlight both part related’ (maybe having 2 colors for the surfaces to identify which of the 2 surfaces we are editing, or highlight in red or other color the edges again to help remember what are we editing), then popup a dialog box to confirm selection
let the user select the new element; validate, visibility is brought back to how it was before editing, then internally check if the new selection is still compatible with the constraint and keep doing the process like during creation
I don’t know if this could be a workaround to the toponaming issue. I saw that there is an option under dev, did not try it yet as my assembly is quite large and I am deseperate to restard from scratch . But, I let you guys give me a feedaback.
Thank you in advance for your support and all the work done so far for the community.
I have a sheet metal object, and did an unfold. Now I have 2 objects within the same file - while I hide one of them (the unfolded part) the folded one is still visible.
If I import the part both objects will show up.
Could A2Plus do a check if the object is visible and only import the visible part?
I think that’s still no good solution, I’d moreover expect an option in the circularEdge dialog if I’d like to align the object horizontally or vertically to the existing object.
It’s not about the cylinder - yes that might work that way but it seems to be “extra” complicated doing it that way, it’s about having 2 existing gears and adding a constraint to them.
Thank you for your effort and time, I (and for sure many others) absolutely appreciate what you have created!
I just wanted to point out about the issues which I’m facing with it from time to time, I had a look at the python code and it looks quite readable so I might dig into it within the next months. Those issues are minor all the major functionality I need is given.
