Hello everyone, I got some time to write fex lines on this topic. Please find the code below. I still have some issue with the transparency and color recovery after surface modification. The principle is the following:
- you select a link created by a2plus
- the run the macro
- it should hide every object except the 2 ones concerned by the link, make half transparent the parts and highlignt the selected surfaces which are linked.
- a window should pop-up and let you choose another surface. There is a warning if you try to work on the wrong part.
- if you close the window, it does not save the change, otherwise there is a button to close and exit.
if you have any feedback feel free to share.
Have a good weekend,
Hubert
# -*- coding: utf-8 -*-
# Macro Begin
import FreeCAD as App
import FreeCADGui as Gui
import PySide
from PySide import QtCore, QtGui
# Global function
try:
_fromUtf8 = QtCore.QString.fromUtf8
except AttributeError:
def _fromUtf8(s):
return s
try:
_encoding = QtGui.QApplication.UnicodeUTF8
def _translate(context, text, disambig):
return QtGui.QApplication.translate(context, text, disambig, _encoding)
return QtGui.QApplication.translate(context, text, disambig)
# Gui definition
class GuiSelectSubElemWindows(PySide.QtGui.QWidget):
# automagically called when the window is created
closed = QtCore.Signal()
def __init__(self,app=None):
super(GuiSelectSubElemWindows, self).__init__()
self.setWindowFlags(PySide.QtCore.Qt.WindowStaysOnTopHint)
self.setWindowTitle(_translate(
"MainWindow", "SelectionWindows", None))
self.app = app
# UI
self.setGeometry(14,200, 40, 50)
grid = PySide.QtGui.QGridLayout()
self.setLayout(grid)
self.setObjectName(_fromUtf8("SelectionWindows"))
# Labels
self.label_0 = QtGui.QLabel(self)
self.label_0.setText("Constraint name:")
self.UpdateConstraintName()
self.label_0.setToolTip("Current constraint evaluated")
self.label_0.adjustSize()
self.label_1 = QtGui.QLabel(self)
self.label_1.setText("Elem 1:")
self.UpdateSubElem1Name()
self.label_1.setToolTip("First Element of the constraint")
self.label_1.adjustSize()
self.label_2 = QtGui.QLabel(self)
self.label_2.setText("Elem 2:")
self.UpdateSubElem2Name()
self.label_2.setToolTip("Second Element of the constraint")
self.label_2.adjustSize()
self.label_3 = QtGui.QLabel(self)
self.label_3.setText("Status: ")
self.label_3.adjustSize()
# Update on request
self.PushButton_1 = QtGui.QPushButton(self)
self.PushButton_1.Label = 'Change_SubElem2'
self.PushButton_1.setText("Change E1")
self.PushButton_1.clicked.connect(self.UpdateSubElem1)
self.PushButton_1.setToolTip("Validate First Sub Element")
self.PushButton_1.adjustSize()
self.PushButton_2 = QtGui.QPushButton(self)
self.PushButton_2.Label = 'Change_SubElem2'
self.PushButton_2.setText("Change E2")
self.PushButton_2.clicked.connect(self.UpdateSubElem2)
self.PushButton_2.setToolTip("Validate Second Sub Element")
self.PushButton_2.adjustSize()
self.PushButton_3 = QtGui.QPushButton(self)
self.PushButton_3.Label = 'Save_and_Close'
self.PushButton_3.setText("Save changes and Close")
self.PushButton_3.clicked.connect(self.SaveModificationAndClose)
self.PushButton_3.setToolTip("Save modifications and close macro")
self.PushButton_3.adjustSize()
grid.addWidget(self.label_0,0,0,1,2)
grid.addWidget(self.label_1,1,0,1,1)
grid.addWidget(self.label_2,2,0,1,1)
grid.addWidget(self.PushButton_1,1,1,1,1)
grid.addWidget(self.PushButton_2,2,1,1,1)
grid.addWidget(self.label_3,3,0,1,2)
grid.addWidget(self.PushButton_3,4,0,1,2)
self.show()
def UpdateConstraintName(self):
self.label_0.setText("Constraint name: %s" % self.app.a2pConstraintName)
def UpdateSubElem1(self):
self.app.UpdateSubElem1() # ??????
self.label_3.setText('Status: %s' % self.app.status)
def UpdateSubElem1Name(self):
self.label_1.setText("Sub-Element 1: %s" % self.app.a2pSubElem1)
def UpdateSubElem2(self):
self.app.UpdateSubElem2() # ?????
def refreshScreen(self):
Gui.Selection.clearSelection()
for obj in App.ActiveDocument.Objects:
if obj.ViewObject.isVisible():
Gui.Selection.addSelection(obj)
def UpdateSubElem2Name(self):
self.label_2.setText("Sub-Element 2: %s" % self.app.a2pSubElem2)
def SaveModificationAndClose(self):
self.app.Selection.SubElement1 = self.app.a2pSubElem1
self.app.Selection.SubElement2 = self.app.a2pSubElem2
self.close()
def closeEvent(self, event):
self.app.resetVisibility()
self.refreshScreen()
self.closed.emit()
# Model definition
class getRelatedConstraintObject():
def __init__(self,Selection=None):
self.ObjInView = []
self.OriginalVisibilities = []
self.OriginalTransparencies = []
self.OriginalSubElemColors = [None,None]
self.ProListCheck = ['Object1', 'Object2', 'Proxy', 'SubElement1', 'SubElement2', 'Suppressed', 'Toponame1', 'Toponame2', 'Type', 'Visibility']
self.a2pObject1 = None
self.a2pObject2= None
self.a2pSubElem1 = None
self.a2pSubElem2 = None
self.a2pConstraintName= None
self.Selection = Selection
self.isSelectionValid = False
self.status = ''
self.checkSelection()
if self.isSelectionValid:
self.getObjectConstraintDetails()
self.getObjInView()
self.getOriginalVisibilities()
def checkSelection(self):
if self.Selection.TypeId == 'App::FeaturePython' and all([item in self.Selection.PropertiesList for item in self.ProListCheck]):
self.isSelectionValid = True
def getObjInView(self):
self.ObjInView.clear()
try:
obj.getPropertyByName("Shape")
self.ObjInView.append(obj)
pass
def getOriginalVisibilities(self):
self.OriginalVisibilities.clear()
for obj in self.ObjInView:
vis =obj.ViewObject.Visibility
transp = obj.ViewObject.Transparency
self.OriginalVisibilities.append(vis)
self.OriginalTransparencies.append(transp)
if vis:
if obj.TypeId != str("Drawing::FeatureViewPython") and not self.isRelatedObject(obj):
obj.ViewObject.Visibility = False
elif self.isRelatedObject(obj):
pass
self.setRelatedFacesHighlighted()
def setRelatedFacesHighlighted(self):
# Sub Elem 1
self.OriginalSubElemColors[0] = self.setColorOnFace(self.a2pObject1, self.Selection.SubElement1)
# Sub Elem 2
self.OriginalSubElemColors[1] = self.setColorOnFace(self.a2pObject2, self.Selection.SubElement2)
def getObjectConstraintDetails(self):
self.a2pObject1 = self.Selection.Object1
self.a2pObject2 = self.Selection.Object2
self.a2pSubElem1 = self.Selection.SubElement1
self.a2pSubElem2 = self.Selection.SubElement2
self.a2pConstraintName = self.Selection.Label
try:
SelectedObj = Gui.Selection.getSelectionEx()[0]
SelectedObjName = SelectedObj.ObjectName
if SelectedObjName == self.a2pObject1:
self.a2pSubElem1 = SelectedObj.SubElementNames[0]
SelectedObj.Object.ViewObject.DiffuseColor = self.OriginalSubElemColors[0]
_ = self.setColorOnFace(self.a2pObject1, self.a2pSubElem1)
self.status = 'SubElem1 selected successfully'
else:
self.status = 'Wrong part selected'
except:
pass
try:
if SelectedObjName == self.a2pObject2:
self.a2pSubElem2 = SelectedObj.SubElementNames[0]
SelectedObj.Object.ViewObject.DiffuseColor = self.OriginalSubElemColors[1]
_ = self.setColorOnFace(self.a2pObject2, self.a2pSubElem2)
self.status = 'SubElem2 selected successfully'
else:
except:
pass
def isRelatedObject(self,CADObj):
return CADObj.Name == self.a2pObject1 or CADObj.Name == self.a2pObject2
def resetVisibility(self):
obj =App.activeDocument().getObject(self.a2pObject1)
obj.ViewObject.DiffuseColor = self.OriginalSubElemColors[0]
obj =App.activeDocument().getObject(self.a2pObject2)
obj.ViewObject.DiffuseColor = self.OriginalSubElemColors[1]
for obj,vis,transp in zip(self.ObjInView,self.OriginalVisibilities,self.OriginalTransparencies):
obj.ViewObject.Visibility = vis
obj.ViewObject.Transparency = 1 # workaroud for the display bug with reseting transparency
obj.ViewObject.Transparency = transp
def ChangeTransparency(self,colors,value):
colors = [(s[0],s[1],s[2],value) for s in colors]
return colors
def setColorOnFace(self, MyObject, MyFace,MyColor=None):
obj =App.activeDocument().getObject(MyObject)
NFaces = len(obj.Shape.Faces)
if len(obj.ViewObject.DiffuseColor) == 1:
colorlist = obj.ViewObject.DiffuseColor*NFaces
else:
colorlist = self.ChangeTransparency(colorlist,0.7)
SubElemIndex = int(MyFace[4:])-1
if MyColor is None:
c1, c2, c3, _ = colorlist[SubElemIndex]
MyColor = (float((1.-c1)), float((1.-c2)), float((1.-c3)), 0.)
# MyColor = (1.,0.,1.,0.)
colorlist[SubElemIndex] = MyColor # (0.,1.,0.,0.)
output = obj.ViewObject.DiffuseColor
obj.ViewObject.DiffuseColor = colorlist
return output
for selection in Gui.Selection.getSelection():
app = getRelatedConstraintObject(selection) # first in selection, no test)
if app.isSelectionValid:
view = GuiSelectSubElemWindows(app)
loop = QtCore.QEventLoop()
view.closed.connect(loop.quit)
loop.exec_()
