"Robust References" Redux
I have read through the blog, yes, though I may need to go back and read it again now that I’ve played with occ stuff a bit more and understand more of the terminology. I have also looked at the DRAWEXE program. I found it sort of cumbersome to work with : I don’t know tcl, there’s no command history in the prog, etc.
Yea, I the reason for the side-by-side comparison I’ve made isn’t because I plan to use this sort of comparison for the ‘robust references’ solution, but rather because it makes it easier for me to see what’s what, and what’s different. I plan to use this to help me test ideas and theories while trying to solve the topological naming issue.
So, I assume based on the output that you drew a 10x10 square in the x-y plane and then extruded it 10 in the +z direction. The ‘missing’ face appears to be the face at (0, 0, 10) with Axis=(0, 0, 1).
Hm…so, I guess each face is it’s own TopoDS_Shape of type TopAbs_FACE, each referring to and underlying Geom_Geometry (i.e. Geom_Surface in our case) and for the two x-y Faces they are referring to the same Geom_Surface. So, that makes sense, especially b/c if the underlying geometry changes it makes it easy for occ to change the to affected surfaces (and their dependent edges and vertices?).
I still don’t understand why Dump doesn’t show all six in your example though. I would expect to see all six. Although, I guess it’s just showing you unique Geom_Geometry’s.
Blah, I’m a bit confused in my head now.
Edit: Ultimately, what I’m trying to do right now is develop a light-weight way to test things for the topo naming issue. When you say ‘comparing geometry definitions … is going to be flawed’ do you mean specifically in regards to solving the topo naming issue? What I did in python-occ (and am trying to duplicate now using plane occ) is use TopExp_MapShapes to grab all the Faces from the cube. Then, I got the underlying Geom_Surface from each of those Faces and downcast them to Geom_Plane and finally pulled the Location and Axis from that Geom_Plane to give me a ‘definition’ of the Face I was looking at. This gives me a textual representation of what is rather easy to see in the FreeCAD 3D GUI, but without having to compile and run FreeCAD to see it.
Are you suggesting that this approach is flawed? I would hope that it would show how a TopoDS_Face that occ has labeled ‘face 1’ is now labeled ‘face 2’, b/c in the before/after the Location and Axis coresponding to the original ‘face 1’ are now applied to ‘face 2’.
I agree. ‘cumbersome’ is a nice way to put it. However there is some useful things that don’t require a lot of effort. ‘dump’ is a great example of that.
Yes.
There is more going on ‘under the hood’, but that is essentially true. You shouldn’t have to worry about the following, but anyway: If you look at https://github.com/tpaviot/oce/blob/add50046a86e5359e4a728cb68fce56e7c29612b/src/BRep/BRep_Tool.cxx#L71 you can see the TopoDS_Shape is used to access a TopoDS_TShape that is then ‘down casted’ to BRep_TFace. BRep_TFace has the actual surface.
IMHO: I would argue that this sharing of geometry makes updating more difficult because now a check has to be performed and a surface copy made when sharing exists and 1 face is modified. I believe that the geometry sharing is purely for memory savings.
You guess right.
Welcome to the rabbit hole.
I probably shouldn’t have used the word ‘flawed’. I was pointing out the shortcomings, I could see, from that approach. The Geom_Surface definitions are almost meaningless because each TopoDS_Shape has its own TopLoc_Location member. So in theory we could construct a 6 sided cube from 1 Geom_Surface definition. So looking a geometry definition alone won’t get you there. You would have to take each face and transform the underlying surface into absolute modeling space and then compare. Then you have to ask yourself: ‘what happens when a modeling operation transforms the topology’. Then after we get our ‘result’ shape and transform the geom_surfaces into absolute space we have to inverse transform the modeling operation so the comparison between before and after are valid. Don’t let me talk you out of anything. Keep going.
Constructing a 6 sided cube from a single Geom_Surface may be a fun exercise to do one day, just to learn.
Hey thanks that’s encouraging! I was worried you were suggesting I was heading down a dead end.
I do think it is a dead end, but I am no authority and you should run with whatever idea you want. If nothing else, you will have a greater understanding of occt and the topo-naming problem.
Lol, fair enough. Still encouraging :slight_smile:
Here is another update. Think I’ll add this one to the second post.
I’ve finished re-implementing the python-occ stuff in opencascade. Here is the code in full. First, my CMakeLists.txt file:
cmake_minimum_required (VERSION 2.6)
project(occTest)
set (CMAKE_SOURCE_DIR ${PROJECT_SOURCE_DIR}/src)
set (CMAKE_BINARY_DIR ${PROJECT_SOURCE_DIR}/Build)
set (EXECUTABLE_OUTPUT_PATH ${CMAKE_BINARY_DIR}/bin)
set (LIBRARY_OUTPUT_PATH ${CMAKE_BINARY_PATH}/lib)
#include_directories(${PROJECT_SOURCE_DIR})
include_directories("/usr/local/include/opencascade")
link_directories("/usr/local/lib")
add_executable(occTest ${CMAKE_SOURCE_DIR}/occPyTest.cpp)
target_link_libraries(occTest TKBRep TKPrim TKernel TKTopAlgo TKMath TKBO TKG3d TKGeomBase)
Here is the source code for the opencascade program:
#include <iostream>
#include <Geom_Plane.hxx>
#include <Geom_TrimmedCurve.hxx>
#include <GC_MakeSegment.hxx>
#include <TopExp.hxx>
#include <TopoDS.hxx>
#include <TopoDS_Shape.hxx>
#include <TopoDS_Edge.hxx>
#include <TopoDS_Wire.hxx>
#include <TopoDS_Face.hxx>
#include <TopLoc_Location.hxx>
#include <TopTools_ListIteratorOfListOfShape.hxx>
#include <TopTools_ListOfShape.hxx>
#include <BRep_Tool.hxx>
#include <BRepTools.hxx>
#include <BRepPrimAPI_MakeBox.hxx>
#include <BRepPrimAPI_MakePrism.hxx>
#include <BRepBuilderAPI_MakeEdge.hxx>
#include <BRepBuilderAPI_MakeWire.hxx>
#include <BRepBuilderAPI_MakeFace.hxx>
#include <BRepAlgoAPI_Cut.hxx>
#include <gp_Pnt.hxx>
#include <gp_Dir.hxx>
#include <gp_Vec.hxx>
#include <gp_Ax1.hxx>
#include <gp_Ax2.hxx>
void printShapeInfos(TopoDS_Shape shape1, TopoDS_Shape shape2, TopoDS_Shape shape3);
void writeShapeInfos(TopoDS_Shape shape1, TopoDS_Shape shape2, TopoDS_Shape shape3);
void printShapeInfo(TopoDS_Shape shape);
void writeShapeInfo(TopoDS_Shape shape, std::ofstream&);
void printDumpFile(TopoDS_Shape shape);
void writeDumpFiles(TopoDS_Shape orig, TopoDS_Shape cut, TopoDS_Shape newBox);
void printShapeInfos(TopoDS_Shape shape1, TopoDS_Shape shape2, TopoDS_Shape shape3){
    std::cout << "orig box" << std::endl;
    printShapeInfo(shape1);
    std::cout << "cut box" << std::endl;
    printShapeInfo(shape2);
    std::cout << "new box" << std::endl;
    printShapeInfo(shape3);
void writeShapeInfos(TopoDS_Shape shape1, TopoDS_Shape shape2, TopoDS_Shape shape3){
    std::ofstream myOutFile;
    // open output files
    myOutFile.open("shapeInfos.txt");
    myOutFile << "orig box" << std::endl;
    writeShapeInfo(shape1, myOutFile);
    myOutFile << "cut box" << std::endl;
    writeShapeInfo(shape2, myOutFile);
    myOutFile << "new box" << std::endl;
    writeShapeInfo(shape3, myOutFile);
    myOutFile.close();
void printShapeInfo(TopoDS_Shape shape){
    TopTools_IndexedMapOfShape mapOfShapes;
    TopExp::MapShapes(shape, TopAbs_FACE, mapOfShapes);
    for (int i = 1; i <= mapOfShapes.Extent(); i++){
        TopoDS_Face aFace = TopoDS::Face(mapOfShapes.FindKey(i));
        Handle(Geom_Surface) aSurface = BRep_Tool::Surface(aFace);
        if (aSurface->DynamicType() == STANDARD_TYPE(Geom_Plane)){
            Handle(Geom_Plane) aPlane = Handle(Geom_Plane)::DownCast(aSurface);
            gp_Pnt aPoint = aPlane->Location();
            gp_Ax1 anAxis = aPlane->Axis();
            gp_Dir aDir   = anAxis.Direction();
            Standard_Real locx, locy, locz, dirx, diry, dirz;
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
            std::cout << "For i= " << i << " ";
            std::cout << "loc = (" << locx << ", " << locy << ", " << locz << ") , ";
            std::cout << "dir = (" << dirx << ", " << diry << ", " << dirz << ") " << std::endl;
void writeShapeInfo(TopoDS_Shape shape, std::ofstream& myOutFile){
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
            myOutFile << "For i= " << i << " ";
            myOutFile << "loc = (" << locx << ", " << locy << ", " << locz << ") , ";
            myOutFile << "dir = (" << dirx << ", " << diry << ", " << dirz << ") " << std::endl;
void printDumpFile(TopoDS_Shape shape){
    BRepTools::Dump(shape, std::cout);
void writeDumpFiles(TopoDS_Shape orig, TopoDS_Shape cut, TopoDS_Shape newBox){
    std::ofstream myBoxFile, cutBoxFile, newBoxFile;
    myBoxFile.open("orig_box.txt");
    cutBoxFile.open("cut_box.txt");
    newBoxFile.open("new_box.txt");
    BRepTools::Dump(orig, myBoxFile);
    BRepTools::Dump(cut, cutBoxFile);
    BRepTools::Dump(newBox, newBoxFile);
    // close output files
    myBoxFile.close();
    cutBoxFile.close();
    newBoxFile.close();
void cutBoxAndShowThings(TopoDS_Shape origBox){
    TopoDS_Shape cutBox, newBox;
    gp_Pnt cut_loc;
    gp_Dir cut_dir;
    gp_Ax2 cut_ax2;
    // create box to cut out and write it out.
    cut_loc = gp_Pnt(7, 5, 30);
    cut_dir = gp_Dir(0, 0, -1);
    cut_ax2 = gp_Ax2(cut_loc, cut_dir);
    cutBox = BRepPrimAPI_MakeBox(cut_ax2, 5., 5., 5.).Shape();
    // create new box by cutting out the second box from the first
    BRepAlgoAPI_Cut builder(origBox, cutBox);
    newBox = builder.Shape();
    // print out Dump to files
    writeDumpFiles(origBox, cutBox, newBox);
    //printDumpFile(origBox);
    //printDumpFile(cutBox);
    //printDumpFile(newBox);
    writeShapeInfos(origBox, cutBox, newBox);
    //printShapeInfos(origBox, cutBox, newBox);
void runCase1(){
    // Variable defs
    TopTools_ListIteratorOfListOfShape iterator;
    TopoDS_Shape myBox;
    // say hello
    std::cout << "Hello, Running Case 1" << std::endl;
    // make base box
    BRepPrimAPI_MakeBox mkBox(10., 20., 30.);
    myBox = mkBox.Shape();
    cutBoxAndShowThings(myBox);
void runCase2(){
    // Variable defs
    gp_Pnt v1, v2, v3, v4;
    TopoDS_Shape myBox;
    // say hello
    std::cout << "Hello, Running Case 2" << std::endl;
    // define points for outline
    v1 = gp_Pnt(0, 0, 0);
    v2 = gp_Pnt(0, 20, 0);
    v3 = gp_Pnt(10, 20, 0);
    v4 = gp_Pnt(10, 0 ,0);
    // define line segments of outline
    Handle(Geom_TrimmedCurve) segment1 = GC_MakeSegment(v1, v2);
    Handle(Geom_TrimmedCurve) segment2 = GC_MakeSegment(v2, v3);
    Handle(Geom_TrimmedCurve) segment3 = GC_MakeSegment(v3, v4);
    Handle(Geom_TrimmedCurve) segment4 = GC_MakeSegment(v4, v1);
    // define the topological edges based on these segments
    TopoDS_Edge edge1 = BRepBuilderAPI_MakeEdge(segment1);
    TopoDS_Edge edge2 = BRepBuilderAPI_MakeEdge(segment2);
    TopoDS_Edge edge3 = BRepBuilderAPI_MakeEdge(segment3);
    TopoDS_Edge edge4 = BRepBuilderAPI_MakeEdge(segment4);
    // define the wire which is our outline
    BRepBuilderAPI_MakeWire mkWire;
    mkWire.Add(edge1);
    mkWire.Add(edge2);
    mkWire.Add(edge3);
    mkWire.Add(edge4);
    TopoDS_Wire myOutline = mkWire.Wire();
    // define a face based on our wire, which is what we'll extrude
    TopoDS_Face myFace = BRepBuilderAPI_MakeFace(myOutline);
    // Finally, extrude the face
    gp_Vec extrudeVector(0, 0, 30); // Specifies direction AND length of extrude
    myBox = BRepPrimAPI_MakePrism(myFace, extrudeVector);
int main(){
    //runCase1();
    runCase2();
    return 0;
here is a parser for the output from writeDumpFiles:
import os, time
def getSurfaces(filename):
    found_section = False
    modtime = time.ctime(os.path.getmtime(filename))
    modtime = modtime.split()
    mtime1 = ' '.join(modtime[0:3])
    mtime2 = ' '.join(modtime[3:])
    out_lines = ['\n','{:^20}'.format(filename), '{:^20}'.format(mtime1), '{:^20}'.format(mtime2)]
    with open(filename, 'r') as infile:
        last_three_lines = [None, None, None]
        for line in infile:
            last_three_lines.append(line)
            last_three_lines.pop(0)
            if not None in last_three_lines and \
               found_section == False and \
               '---' in last_three_lines[0] and \
               'surfaces' in last_three_lines[1] and \
               '---' in last_three_lines[2]:
                   found_section = True
                   continue
            if found_section == True and '---' in line:
                break
            if found_section:
                out_lines.append(line.rstrip())
    return out_lines
if __name__=='__main__':
    import sys
    if len(sys.argv) == 1:
        print('Please provide at least one file')
    else:
        datas = []
        for filename in sys.argv[1:]:
            datas.append(getSurfaces(filename))
        outFormat = '{:20}'*len(datas)
        most = max([len(i) for i in datas])
        for line in range(most):
            toprint = []
            for i in range(len(datas)):
                if len(datas[i]) > line:
                    # print('line = {}, len(datas[i]) = {}'.format(line, len(datas[i])))
                    toprint.append(datas[i][line])
                else:
                    toprint.append('')
            print(outFormat.format(*toprint))
And finally, here’s a parser for the output of printShapeInfos:
import re
def printData(filename):
    indRegexp = re.compile('For i= ([0-9]+) .*')
    locRegexp = re.compile('.*loc = (\(.*?\)).*')
    dirRegexp = re.compile('.*dir = (\(.*\))')
    outlines = [[],[],[]]
    tagIndex = -1
        tag     = False
        # first line is 'Hello, Wolfgang'
        infile.readline()
        for line in infile:
            if 'For i' in line:
                index = indRegexp.match(line).group(1)
                location = locRegexp.match(line).group(1)
                direction = dirRegexp.match(line).group(1)
                # import pdb; pdb.set_trace()
                if index == '1':
                    tagPrint = '{:^25}'.format('For object {}'.format(tag))
                    outlines[tagIndex].append(tagPrint)
                indPrint = '{:^25}'.format('Face {:02}'.format(int(index)))
                locPrint = '{:^25}'.format('loc = {}'.format(location))
                dirPrint = '{:^25}'.format('dir = {}'.format(direction))
                outlines[tagIndex].append(indPrint)
                outlines[tagIndex].append(locPrint)
                outlines[tagIndex].append(dirPrint)
            else:
                tag = line.strip()
                tagIndex += 1
    maxLength = max([len(i) for i in outlines])
    for i in range(maxLength):
        one = ' '*25
        two = ' '*25
        three = ' '*25
        if len(outlines[0]) - 1 >= i:
            one = outlines[0][i]
        if len(outlines[1]) - 1 >= i:
            two = outlines[1][i]
        if len(outlines[2]) - 1 >= i:
            three = outlines[2][i]
        printLine = ''.join([one, two, three])
        print(printLine)
    return outlines
if __name__ == '__main__':
    import sys
        print('Please specify an input file')
    else:
        if len(sys.argv) > 2:
            print('Using {}, ignoring the rest'.format(sys.argv[1]))
        printData(sys.argv[1])
Here’s how I have it set up on my system. I have a project folder in ~/Programs called myOccProject, so the full path is /home/myUser/myOccProject. Let’s call this directory $ProjectDir. The structure is as follows
$ProjectDir
|--Build
|--src
|    |-----occPyTest.cpp
|--CMakeLists.txt
So, I do the following to build and run the program:
cd $ProjectDir/Build
cmake ..
make
LD_LIBRARY_PATH=/usr/local/lib bin/occTest
The syntax for the first python parser, let’s call it parser1.py is:
python parser1.py file1 file2 file3 ...
It will take the output from the Dump command, parse out just the faces, and print them side-by-side for each of the files. So, based on the occTest program, which has some hard-coded filenames in there, you’d run it as follows:
python parser1.py orig_box.txt cut_box.txt new_box.txt
Note that you need to run it from the same directory as where you ran the occTest program, or else copy the generated text files over.
The syntax for the second python parser, let’s call it parser2.py, is:
python parser2.py fileToParse
Based on the hard-coded filename in occTest, you’d use this as follows:
python parser2.py shapeInfos.txt
This is the output I am most interested in right now. It shows you, side-by-side, the results of traversing the shape face-by-face using TopExp::MapShapes. It grabs the underlying Geom_Plane for each face in order to provide a location coordinate and a direction vector for each - this is so that when you’re looking at the textual output, you can distinguish one face from the other. Here is the results or this parser2.py when running case2:
   For object orig box      For object cut box       For object new box
         Face 01                  Face 01                  Face 01
     loc = (0, 0, 0)         loc = (7, 5, 30)          loc = (0, 0, 0)
    dir = (-1, 0, 0)         dir = (-1, 0, -0)        dir = (-1, 0, 0)
         Face 02                  Face 02                  Face 02
    loc = (0, 20, 0)         loc = (2, 5, 30)         loc = (10, 0, 0)
     dir = (0, 1, 0)         dir = (-1, 0, -0)        dir = (0, -1, 0)
         Face 03                  Face 03                  Face 03
    loc = (10, 20, 0)        loc = (7, 5, 30)         loc = (0, 20, 0)
    dir = (1, 0, -0)          dir = (0, 1, 0)          dir = (0, 1, 0)
         Face 04                  Face 04                  Face 04
    loc = (10, 0, 0)         loc = (7, 10, 30)        loc = (5, 10, 0)
    dir = (0, -1, 0)          dir = (0, 1, 0)        dir = (-0, -0, -1)
         Face 05                  Face 05                  Face 05
    loc = (5, 10, 0)         loc = (7, 5, 30)         loc = (5, 10, 30)
   dir = (-0, -0, -1)        dir = (0, 0, -1)        dir = (-0, -0, -1)
         Face 06                  Face 06                  Face 06
    loc = (5, 10, 30)        loc = (7, 5, 25)         loc = (10, 20, 0)
   dir = (-0, -0, -1)        dir = (0, 0, -1)         dir = (1, 0, -0)
                                                           Face 07
                                                      loc = (7, 10, 30)
                                                       dir = (0, 1, 0)
                                                           Face 08
                                                      loc = (7, 5, 30)
                                                      dir = (-1, 0, -0)
                                                           Face 09
                                                      loc = (7, 5, 30)
                                                       dir = (0, 1, 0)
                                                           Face 10
                                                      loc = (2, 5, 30)
                                                      dir = (-1, 0, -0)
                                                           Face 11
                                                      loc = (7, 5, 25)
                                                      dir = (0, 0, -1)
Based on what I see from here, I think I can understand the topo-naming issue a bit better. Allow me to try and enumerate it here:
  1. FreeCAD’s TopoShape creates an opencascade TopoDS_Shape
  2. When the user modifies the TopoShape, like cutting a pocket out, a new TopoDS_Shape is created. FreeCAD keeps a copy of both shapes (?) which is what is seen in the tree (?)
  3. When the user fillets an edge, it is done on the latest TopoDS_Shape in the tree. These fillets are done on, say, ‘Edge 1’, per the output of TopExp::MapShapes
  4. If the user goes back and deletes a pocket that was created before the fillet, a brand new TopoDS_Shape is created. I assume now FreeCAD walks back through the history of operations and re-applies them to each progressive TopoDS_Shape to re-build the solid without the pocket
  5. When FreeCAD gets to the fillet step, it has an issue, because ‘Edge 1’ refers to a different edge now!
This can be seen in my example above. In ‘orig_box’, ‘Face 02’ is the x-z face located at x=0, y=20, z=0. In ‘new_box’, ‘Face 02’ is the x-z face located at x=10, y=0, z=0. The x-values aren’t really what’s important here for the location, it’s the y-value. in orig_box, Face 02 is the ‘back’ face. In new_box, it is the ‘front’ face. If we had done other operations, it could have ended being any other face.
So, I assume this same issue occurs with edges, which is why the fillet operation does not perform as expected when rebuilding the solid.
@tanderson69 - per our earlier conversation, I don’t understand the shortfall in using the underlying Geom_Plane here to distinguish between the different faces. I specifically wrote case2 to duplicate your case earlier - I created a 2-d Face and extruded it using BRepPrimAPI_Prism. TopExp::MapShapes still gives me 6 faces to iterate over. It does still look like the Top and Bottom faces reference the same underlying geometry, at least based on the Direction vector: you can see that both Direction vectors for the x-y faces point in the negative Z direction, while every other face has a Direction vecton that points “out” from the solid.
In other words, each Face has an Orientation of TopAbs_Forward except for the top face, which is oriented TopAbs_Reverse. I assume this is b/c of sharing the same underlying geometry.
Edit: I am by no means a C++ expert - in fact, I’m still pretty much a neophyte. I done my best here, but I know there’s some redundant code and there are probably some opportunities to clean it up a bit. I’m open to suggestions/feedback, but for now I’m going to work on my next milestone as outlined in post 2 on this thread. I’ll try to clean up the code as I go and as I learn more.
Edit2: Found this neat sample in the opencascade source that shows a working example of the TNaming stuff. I’m going to try to incorporate this into my simple program and see what happens.
Edit3: :exclamation: this TNaming_Selector class seems to be what we’re looking for. The sample I linked in my last edit to this post shows an example of how to use this. I’m excited I think this TNaming thing may be the ticket!
Let me show you another situation, where T-naming is to help.
Let’s say you have padded a gear. And now you want to make a hole for the shaft. So you select the top face, make a sketch, and pocket it.
Now, you realized you need to change the number of teeth a bit… As soon as you do, the project breaks. Because the top face has a number of, say, 152. That is, the face is enumerated the very last, after all the facets of gear teeth.
gear-with-hole.FCStd (133 KB)
Steps:
  1. PartDesign Involute Gear (in menu)
  2. PartDesign Pad
  3. Select top face, switch to Sketcher WB, New sketch. Attachment mode FlatFace.
  4. Draw the hole. Close sketch.
  5. Pocket
  6. Double-click gear in model tree, and change number of teeth.
  7. Observe the error state of the sketch :neutral_face: . The pocket does update though, since the old shape and placement of sketch are remembered and used, even though the sketch failed to recompute. But if you try to edit the size of the hole in that sketch, the result won’t be updated.
EDIT: I think this example is rather good, because this apparently small change (number of teeth) absolutely requires complete rebuilding of everything (But FreeCAD does it anyway, even if it may not be required, when executing features).
Hit a bit of a roadblock today with the TNaming stuff. I started incorporating some of the code from the ‘neat sample’ I linked earlier, but when I try to compile the linker complains about Undefined Reference errors:
[ 50%] Linking CXX executable bin/occTest
CMakeFiles/occTest.dir/src/occPyTest.cpp.o: In function `runCase3()':
/home/wolfie/Program/pyFreeCad/src/occPyTest.cpp:257: undefined reference to `TNaming_Builder::TNaming_Builder(TDF_Label const&)'
/home/wolfie/Program/pyFreeCad/src/occPyTest.cpp:262: undefined reference to `TNaming_Builder::Generated(TopoDS_Shape const&)'
/home/wolfie/Program/pyFreeCad/src/occPyTest.cpp:266: undefined reference to `TNaming_Builder::TNaming_Builder(TDF_Label const&)'
/home/wolfie/Program/pyFreeCad/src/occPyTest.cpp:269: undefined reference to `TNaming_Builder::Generated(TopoDS_Shape const&)'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o: In function `TNaming_NamedShape::~TNaming_NamedShape()':
/usr/local/include/opencascade/TNaming_NamedShape.hxx:85: undefined reference to `TNaming_NamedShape::Clear()'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o: In function `TNaming_NamedShape::ID() const':
/usr/local/include/opencascade/TNaming_NamedShape.lxx:23: undefined reference to `TNaming_NamedShape::GetID()'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x28): undefined reference to `TNaming_NamedShape::DynamicType() const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x40): undefined reference to `TNaming_NamedShape::BeforeRemoval()'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x60): undefined reference to `TNaming_NamedShape::BeforeUndo(opencascade::handle<TDF_AttributeDelta> const&, unsigned int)'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x68): undefined reference to `TNaming_NamedShape::AfterUndo(opencascade::handle<TDF_AttributeDelta> const&, unsigned int)'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x78): undefined reference to `TNaming_NamedShape::BackupCopy() const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0x80): undefined reference to `TNaming_NamedShape::Restore(opencascade::handle<TDF_Attribute> const&)'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xa0): undefined reference to `TNaming_NamedShape::DeltaOnModification(opencascade::handle<TDF_Attribute> const&) const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xa8): undefined reference to `TNaming_NamedShape::DeltaOnModification(opencascade::handle<TDF_DeltaOnModification> const&)'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xb0): undefined reference to `TNaming_NamedShape::DeltaOnRemoval() const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xb8): undefined reference to `TNaming_NamedShape::NewEmpty() const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xc0): undefined reference to `TNaming_NamedShape::Paste(opencascade::handle<TDF_Attribute> const&, opencascade::handle<TDF_RelocationTable> const&) const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xc8): undefined reference to `TNaming_NamedShape::References(opencascade::handle<TDF_DataSet> const&) const'
CMakeFiles/occTest.dir/src/occPyTest.cpp.o:(.rodata._ZTV18TNaming_NamedShape[_ZTV18TNaming_NamedShape]+0xd0): undefined reference to `TNaming_NamedShape::Dump(std::ostream&) const'
collect2: error: ld returned 1 exit status
CMakeFiles/occTest.dir/build.make:94: recipe for target 'bin/occTest' failed
make[2]: *** [bin/occTest] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/occTest.dir/all' failed
make[1]: *** [CMakeFiles/occTest.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
I’m going to spend some time trying to figure out what’s going on, but I thought I’d post this in case anyone else may have a clue, since I’m not really that well versed in this compiler/linker/C++ stuff
edit: here’s the source code I’m trying to compile:
#include <iostream>
#include <TDF_Data.hxx>
#include <TDF_Label.hxx>
#include <TDF_LabelMap.hxx>
#include <TDF_ChildIterator.hxx>
#include <TDF_MapIteratorOfLabelMap.hxx>
#include <TNaming_NamedShape.hxx>
#include <TNaming_Selector.hxx>
#include <TNaming_Tool.hxx>
#include <TNaming_Builder.hxx>
#include <TNaming.hxx>
    myOutFile.close();
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
    myBoxFile.close();
    cutBoxFile.close();
    newBoxFile.close();
    gp_Pnt cut_loc;
    gp_Dir cut_dir;
    gp_Ax2 cut_ax2;
void runCase1(){
    // Variable defs
    TopoDS_Shape myBox;
    // say hello
    // make base box
void runCase2(){
    // Variable defs
    TopoDS_Shape myBox;
    // say hello
    mkWire.Add(edge1);
    mkWire.Add(edge2);
    mkWire.Add(edge3);
    mkWire.Add(edge4);
void runCase3(){
    // This is for the Data Framework
    Handle(TDF_Data) DF = new TDF_Data();
    TDF_Label aLabel = DF->Root();
    // Create our base box
    BRepPrimAPI_MakeBox myBox(10., 20., 30.);
    // Load the faces of the box into the Data Framework. This adds nodes to the
    // DataFramework tree, I believe. Note that myBoxLabel is added to the Root, while all
    // the rest are added underneath myBoxLabel, so they're at level 3
    TDF_Label myBoxLabel      = aLabel.FindChild(1); // First Label in Root
    TDF_Label myBoxTopLabel   = myBoxLabel.FindChild(1, Standard_True); // All these are under the first Label
    TDF_Label myBoxBotLabel   = myBoxLabel.FindChild(2, Standard_True);
    TDF_Label myBoxRightLabel = myBoxLabel.FindChild(3, Standard_True);
    TDF_Label myBoxLeftLabel  = myBoxLabel.FindChild(4, Standard_True);
    TDF_Label myBoxFrontLabel = myBoxLabel.FindChild(5, Standard_True);
    TDF_Label myBoxBackLabel  = myBoxLabel.FindChild(6, Standard_True);
    // TNaming_Builder takes a label as it's constructor. It allows us to add 'attributes'
    // to the Label (see the OCAF documentation about Data Framework for more info). These
    // attributes, I believe, help us track changes to a Topological structure. This is
    // how Generated, Modified, and Deleted attributes are kept track of. Oh, and
    // apparently "One evolution type per builder must be used"
    TNaming_Builder myBoxBuilder(myBoxLabel);
    // Add the 'Generated' attribute to the myBox TopoDS_Shape. The myBoxLabel Label is
    // where we are storing attributes for the whole myBox TopoDS_Shape. Underneath that
    // label, we created other labels for each of the Faces, where we can track changes to
    // those Topological structures.
    myBoxBuilder.Generated(myBox.Shape());
    // create a Builder for each Face and add the 'Generated' attribute to the Data
    // Framework
    TNaming_Builder topBuilder(myBoxTopLabel);
    // Note, this is sort of cheating, for other Topo structures we'll have to do this on our own
    TopoDS_Face myBoxTopFace = myBox.TopFace();
    topBuilder.Generated(myBoxTopFace);
    // And, do the rest of the faces...
    //TNaming_Builder botBuilder(myBoxBotLabel);
    //TopoDS_Face myBoxBotFace = myBox.BottomFace();
    //botBuilder.Generated(myBoxBotFace);
    //TNaming_Builder rightBuilder(myBoxRightLabel);
    //TopoDS_Face myBoxRightFace = myBox.RightFace();
    //rightBuilder.Generated(myBoxRightFace);
    //TNaming_Builder leftBuilder(myBoxLeftLabel);
    //TopoDS_Face myBoxLeftFace = myBox.LeftFace();
    //leftBuilder.Generated(myBoxLeftFace);
    //TNaming_Builder frontBuilder(myBoxFrontLabel);
    //TopoDS_Face myBoxFrontFace = myBox.FrontFace();
    //frontBuilder.Generated(myBoxFrontFace);
    //TNaming_Builder backBuilder(myBoxBackLabel);
    //TopoDS_Face myBoxBackFace = myBox.BackFace();
    //backBuilder.Generated(myBoxBackFace);
int main(){
    //runCase1();
    //runCase2();
    runCase3();
    return 0;
edit2: Could it be that the TNaming module was designed to be used strictly with the OCAF stuff, and that’s why I’m getting these errors? That doesn’t make sense, as I don’t see anywhere else in the source files where these functions the linker is complaining about are defined, and in fact they’re all defined in TNaming.
edit3: DeepSOIC, i’m not ignoring your post. I just don’t think I’m at a place yet to use that gear example - perhaps after I have a working prototype for a solution I can throw the gear problem at it, but right now I’m working with just cubes and keeping it simple.
Don’t worry about it. Just keep going.
You are missing the library responsible for the tnaming in your cmake file. Probably ‘TKCAF’.
that’s not it, I’ve added TKLCAF to the cmake thing, and when I compile it with make VERBOSE=1 I see that it’s part of the g++ call. goo try though!
Is that a typo? “TKLCAF” != “TKCAF”
It was not a typo, turns out I need both TKLCAF and TKCAF. Thanks!
Edit: So, it compiles now, and I just tried out this little code snippet:
    // Note: this is an example of how to recover an object from a particular node in our
    // Data Framework. This is key, as this is where opencascade takes care of the Robust
    // Reference thing for us. You'll notice that in this particular instance we don't
    // actually need to use this mechanism, as I still have a reference to myBox handy and
    // it hasn't been modified, but I'm doing this here for educational purposes.
    Handle(TNaming_NamedShape) namedShapeObject; // store the retrieved object here
    // This part of the occ example confounds me. How in the world could this CLASS METHOD
    // GetID know anything about an instance of TNaming_NamedShape enough to return to me
    // the GUID that I'm looking for? The occ documentation under "OCAF Shape
    // Attributes-->Using Naming Resources" suggests that there is also a method that each
    // object "of an attribute class" has that will return the GUID. this makes more sense
    // to me..
    myBoxLabel.FindAttribute(TNaming_NamedShape::GetID(), namedShapeObject);
    TopoDS_Shape myRecoveredBox = namedShapeObject->Get();
    // let's check if it's the same box!
    Standard_Boolean checkBox = myBox.Shape().IsEqual(myRecoveredBox);
    std::string output;
    if (checkBox)
        output = "True";
    else
        output = "False";
    std::cout << "myBox == myRecovered Box == " << output << std::endl;
    // output "myBox == myRecoveredBox == True" woah! it works! So, this should also work
    // for faces and stuff, right....?
I think this is rather promising. I’m going to keep fleshing out this example, eventually adding fillets and trying to get a constant reference to an edge/face before/after a subsequent Cut operation to the Fillet operation. But, as you can see here, if we use TNaming to write TDF_Label entries into the TDF_Data structure, the myLabel.FindAttribute method appears to give us a consistent way to refer back to that TodoDS_Shape. :exclamation:
Hang on a moment, was that some kind of faint light there in the end of the tunnel :smiley: :open_mouth:
Another update. The code comments speak for themselves I think:
    // Ok, I think I got a bit ahead of myself. I think it's this TNaming_Selector thing
    // that is key - we create a new TNaming_Selector for each TNaming_Label that we need
    // a constant reference too, and then it gives us a consistent, er, Name for each
    // TopoDS_Shape?
    TDF_Label resultCutLabel = myBoxCutLabel.FindChild(1);
    TNaming_Selector myBoxCutSelector(resultCutLabel);
    Handle(TNaming_NamedShape) cutBoxNamedShape;
    cutBoxLabel.FindAttribute(TNaming_NamedShape::GetID(), cutBoxNamedShape);
    // like above, this is not necessary b/c I still have a reference to cutBox from
    // earlier, but for completeness and b/c IRL (in real life) this will be done in a
    // separate function, I'm putting it in.
    const TopoDS_Shape& cutBoxRecovered = cutBoxNamedShape->Get();
    // The two arguments here are 'selection' and 'context', respectively. This means
    // "store in NamedShape (which is an instance attribute of this TNaming_Selector
    // instance) the name for the TopoDS_Shape 'selection' which is found with the
    // TopoDS_Shape 'context'. The 'context' thing probably makes more sense when
    // searching for a Face within a Shape, or an Edge within a Face.
    myBoxCutSelector.Select(cutBoxRecovered, cutBoxRecovered);
    // Finally, grab the TopoDS_Shape that resulted from the 'Select' operation. I could
    // do this in two steps, i.e. `TNaming_NamedShape ns = myBoxCutSelector.NamedShape()`
    // then `TopoDS_Shape& myShape = ns->Get()` but I won't. Doing it in two steps,
    // though, does highlight how the 'Select' method works 'behind the scenes' and stores
    // the output TNaming_NamedShape inside of itself, and then you have to go back and
    // grab it.
    // So, why is this step necessary, if we alread have cutBoxRecovered? I think it's
    // because of the following: cutBoxRecovered is very 'young' in our Data Framework
    // tree. It was the orignial Box that was cut from the original grand-daddy Box myBox.
    // Other stuff may have happened since then. In this simple example, nothing else has
    // happened, but realistically we could be WAY down the Data Framework tree by now,
    // after Fillet operations and Fuse operations oter Boolean operations. So, although
    // we have a reference to the very 'young' cutBox, we don't really have a reference to
    // that box within the current context of our TopoDS_Shape. So, this next operation
    // get's us the same cutBox, but relative to the current state of the TopoDS_Shape.
    // I think. This is all pure speculation. But I think it's right!
    const TopoDS_Shape& cutBoxSelected = myBoxCutSelector.NamedShape()->Get();
    // finally, now that we've retrieved both the box to cut and the box that we're going
    // to cut from it, we can perform the Cut operation and then store the necessary stuff
    // in our Data Framework
    BRepAlgo_Cut mkCut(myRecoveredBox, cutBoxSelected);
The next step is rather extensive - I have to record a bunch of stuff in the Data Framework. Figuring that out now…
Alright, bumping the thread for a sort of big update. Here’s the full source code I’m working with. My apologies for the extensive commentary, it’s mostly to help me wrap my mind around things. I’ll provide some TLDR below:
#include <iostream>
#include <TopExp_Explorer.hxx>
#include <TopOpeBRepBuild_HBuilder.hxx>
#include <BRepAlgo.hxx>
#include <BRepAlgo_Cut.hxx>
    myOutFile.close();
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
            locx = aPoint.X();
            locy = aPoint.Y();
            locz = aPoint.Z();
            dirx = aDir.X();
            diry = aDir.Y();
            dirz = aDir.Z();
    myBoxFile.close();
    cutBoxFile.close();
    newBoxFile.close();
    gp_Pnt cut_loc;
    gp_Dir cut_dir;
    gp_Ax2 cut_ax2;
void runCase1(){
    // Variable defs
    TopoDS_Shape myBox;
    // say hello
    // make base box
void runCase2(){
    // Variable defs
    TopoDS_Shape myBox;
    // say hello
    mkWire.Add(edge1);
    mkWire.Add(edge2);
    mkWire.Add(edge3);
    mkWire.Add(edge4);
void runCase3(){
    // the rest are added underneath myBoxLabel, so they're at level 3. NOTE: it is not
    // necesarry to pass the second argument to FindChild, but I like to do so in order to
    // make it more explicit that I am asking it to create this Label if it doesn't exist.
    const Standard_Boolean createIfNotExists = Standard_True;
    TDF_Label myBoxLabel      = aLabel.FindChild(1, createIfNotExists); // First Label in Root
    TDF_Label myBoxTopLabel   = myBoxLabel.FindChild(1, createIfNotExists); // All these are under the first Label
    TDF_Label myBoxBotLabel   = myBoxLabel.FindChild(2, createIfNotExists);
    TDF_Label myBoxRightLabel = myBoxLabel.FindChild(3, createIfNotExists);
    TDF_Label myBoxLeftLabel  = myBoxLabel.FindChild(4, createIfNotExists);
    TDF_Label myBoxFrontLabel = myBoxLabel.FindChild(5, createIfNotExists);
    TDF_Label myBoxBackLabel  = myBoxLabel.FindChild(6, createIfNotExists);
    // Framework
    // Create second box, which will be Cut from the first
    gp_Pnt cut_loc = gp_Pnt(7, 5, 30); // location for axis of cutBox
    gp_Dir cut_dir = gp_Dir(0, 0, -1); // direction for axis of cutBox
    gp_Ax2 cut_ax2 = gp_Ax2(cut_loc, cut_dir); // axis at cut_loc pointing down, so into our myBox
    BRepPrimAPI_MakeBox cutBox(cut_ax2, 5., 5., 5.);
    // It seems that even though cutBox is not a Fused part of our TopoDS_Shape, since it
    // is still a 'part' of it by means of being Cut out of it, we must store information
    // about it in our Data Framework. This is the equivalent of what we did for myBox,
    // and I think finding a way to write a generic function that accomplishes this is in
    // order, as doing it manually like this is not sustainable for the greater FreeCAD
    // project
    // number here is arbitrary, though we do have to keep track of our numbers somehow.
    // i.e. we used 1 for myBoxLabel, so we can't reuse it, and I have to remember that 1
    // correspondes to myBoxLabel, not cutBox. Seems like a job for a custom class or
    // something. hrm...
    TDF_Label cutBoxLabel      = aLabel.FindChild(2, createIfNotExists);
    TDF_Label cutboxTopLabel   = cutBoxLabel.FindChild(1, createIfNotExists); // same thing about numbering as above, but for children
    TDF_Label cutBoxTopLabel   = cutBoxLabel.FindChild(1, createIfNotExists); // All these are under the first Label
    TDF_Label cutBoxBotLabel   = cutBoxLabel.FindChild(2, createIfNotExists);
    TDF_Label cutBoxRightLabel = cutBoxLabel.FindChild(3, createIfNotExists);
    TDF_Label cutBoxLeftLabel  = cutBoxLabel.FindChild(4, createIfNotExists);
    TDF_Label cutBoxFrontLabel = cutBoxLabel.FindChild(5, createIfNotExists);
    TDF_Label cutBoxBackLabel  = cutBoxLabel.FindChild(6, createIfNotExists);
    TNaming_Builder cutBoxBuilder(cutBoxLabel);
    cutBoxBuilder.Generated(cutBox.Shape());
    TNaming_Builder topCutBuilder(cutBoxTopLabel);
    TopoDS_Face cutBoxTopFace = cutBox.TopFace();
    topCutBuilder.Generated(cutBoxTopFace);
    TNaming_Builder botCutBuilder(cutBoxBotLabel);
    TopoDS_Face cutBoxBotFace = cutBox.BottomFace();
    botCutBuilder.Generated(cutBoxBotFace);
    TNaming_Builder rightCutBuilder(cutBoxRightLabel);
    TopoDS_Face cutBoxRightFace = cutBox.RightFace();
    rightCutBuilder.Generated(cutBoxRightFace);
    TNaming_Builder leftCutBuilder(cutBoxLeftLabel);
    TopoDS_Face cutBoxLeftFace = cutBox.LeftFace();
    leftCutBuilder.Generated(cutBoxLeftFace);
    TNaming_Builder frontCutBuilder(cutBoxFrontLabel);
    TopoDS_Face cutBoxFrontFace = cutBox.FrontFace();
    frontCutBuilder.Generated(cutBoxFrontFace);
    TNaming_Builder backCutBuilder(cutBoxBackLabel);
    TopoDS_Face cutBoxBackFace = cutBox.BackFace();
    backCutBuilder.Generated(cutBoxBackFace);
    // OK, here's the hard/fun part. Let's cut cutBox from myBox and do all the
    // appropriate things to the DataFramework
    // First, we create anoter label in our DataFramework under Root. In other words, our
    // first label was for myBox, our second was for cutBox (both TopoDS_Shapes) and our
    // third label is for the resultant box of the Cut operation. we'll call it myBoxCut
    TDF_Label myBoxCutLabel = aLabel.FindChild(3, createIfNotExists);
    // to me..
    std::string output;
    if (checkBox)
        output = "True";
    else
        output = "False";
    // TopoDS_Shape?
    TDF_Label resultCutLabel = myBoxCutLabel.FindChild(1); // child 1 of myBoxCutLabel, which is the third node in Root right now
    // grab it.
    TopoDS_Shape resultBox = mkCut.Shape();
    if (!mkCut.IsDone()) {
        cout << "CUT: Algorithm failed" << endl;
        return;
    else {
        // Alright, take a deep breath, b/c this stuff goes deep
        // First, it seems we must use BRepAlgo::IsValid to check if the faces generated
        // by the mkCut operation are Valid. *shrug* the occ example does it, so I do it
        TopTools_ListOfShape listBoxes;
        listBoxes.Append(myRecoveredBox);
        listBoxes.Append(cutBoxSelected);
        if (!BRepAlgo::IsValid(listBoxes, resultBox, Standard_True, Standard_False)) {
            cout << "CUT: Result is not valid" << endl;
            return;
        else {
            // We're going to add data to the Data Framework. This data will be added to
            // the third node under the Root: we called it myBoxCutLabel. The data we are
            // adding corresponds to the result box from the Cut operation, and will store
            // the Modified, Deleted, and other relevant data that the Data Framework
            // needs.
            TDF_Label modifiedFacesLabel     = myBoxCutLabel.FindChild(2); // remember, 1 was for the result of the Cut operation
            TDF_Label deletedFacesLabel      = myBoxCutLabel.FindChild(3);
            TDF_Label intersectingFacesLabel = myBoxCutLabel.FindChild(4);
            TDF_Label newFacesLabel          = myBoxCutLabel.FindChild(5);
            // Finally time to store the result of the Cut operation on Child 1 of myBoxCutLabel -> we called this label
            // resultCutLabel earlier
            TNaming_Builder resultBoxBuilder(resultCutLabel);
            const TopoDS_Shape& preCutBox = mkCut.Shape1(); // first shape involved in boolean operation, i.e. myBox
            // The two arguments here are OldShape and NewShape, respectively. This stores in resultCutLabel a Modified
            // attribute wich describes NewShape as a Modification of OldShape
            resultBoxBuilder.Modify(preCutBox, resultBox);
            // Going one level deeper, we need to store in the Data Framework the modified faces.
            TopTools_MapOfShape uniqueShapes;
            TNaming_Builder modifiedFacesBuilder(modifiedFacesLabel);
            // Create a TopExp_Explorer to traverse the FACE's of the original Box
            TopExp_Explorer FaceExplorer(preCutBox, TopAbs_FACE);
            // Alright, let's work through the logic on this nested For-loop structure. First, it loops through each
            // TopoDS_FACE in the preCutBox, i.e. the original Box before it was cut. For each Face in the preCutBox,
            // use the BRepAlgo_Cut instance we have from earlier, mkCut, to check whether or not that Face was Modified
            // during the Cut operation. In fact, mkCut.Modified returns a _list_ of Modified Shapes. Why? Hm..I think
            // it's b/c the Face that we're checking _could_ have gotten split into multiple Faces during the Cut
            // operation, and therefore the Modified check needs to give allowance for that. Not really sure though...
            // But, you know, assuming that's true, the next step is to iterate over overy one of these Modified Face's.
            // At each step of this second iteration, we make sure this possiblyModifiedFace is not the same as
            // currentFace before adding it to the Data Framework.
            // Why do we have to preform this check? And why doesn't currentFace itself get added to the Data Framework?
            // I don't know! Lol, in fact, I'm a bit confused myself. It seems to me that even if the Face returned from
            // mkCut.Modified _is_ the same as currentFace, that we'd still want to add it to the Data Framework, since,
            // well, it was Modified. For now, I'll blindly follow the OCAF example, and hopefully I'll become
            // enlightened as to what is going on here...
            for (; FaceExplorer.More(); FaceExplorer.Next()){
                const TopoDS_Shape& currentFace = FaceExplorer.Current();
                Standard_Boolean res = uniqueShapes.Add(currentFace);
                if (!res)
                    // Face wasn't added, I think b/c it was already in the Map. Therefore, skip to the next Face. I
                    // think in FreeCAD we use TopExp_MapShapes instead of this, not sure why the OCAF sample does this.
                    // For now we'll do it their way...
                    continue;
                const TopTools_ListOfShape& modifiedFaces = mkCut.Modified(currentFace);
                TopTools_ListIteratorOfListOfShape modifiedFacesIterator(modifiedFaces);
                for (; modifiedFacesIterator.More(); modifiedFacesIterator.Next()){
                    const TopoDS_Shape& possiblyModifiedFace = modifiedFacesIterator.Value();
                    if (!currentFace.IsSame(possiblyModifiedFace))
                        modifiedFacesBuilder.Modify(currentFace, possiblyModifiedFace);
            // Do the same as above for Deleted faces
            uniqueShapes.Clear();
            TNaming_Builder deletedFacesBuilder(deletedFacesLabel);
            FaceExplorer.Init(preCutBox, TopAbs_FACE);
            // So, why is this loop simpler than the Modified loop? My best guess is that, unlike with Modified, a
            // Deleted Face does not ever result in multiple Faces being produces - I THINK! Instead, a Face is either
            // Deleted or it's not. *shrug*
            for(; FaceExplorer.More(); FaceExplorer.Next()){
                if (!res)
                    continue;
                if (mkCut.IsDeleted(currentFace))
                    deletedFacesBuilder.Delete(currentFace);
            // Add to the Data Framework 'section edges'. I'm not gonna lie, don't really understand this whole
            // 'Intersecting Faces' thing, but it has something to do with the Boolean operation
            TNaming_Builder intersectingFacesBuilder(intersectingFacesLabel);
            Handle(TopOpeBRepBuild_HBuilder) build = mkCut.Builder();
            TopTools_ListIteratorOfListOfShape intersectingSections = build->Section();
            for(; intersectingSections.More(); intersectingSections.Next()){
                // So, Select I guess adds a Shape to the label - a shape that wasn't modified. Pretty confused about
                // this, why does it need two arguements?
                intersectingFacesBuilder.Select(intersectingSections.Value(), intersectingSections.Value());
            // Finally, add to the Data Framework faces that were added
            const TopoDS_Shape& boxThatWasCutOut = mkCut.Shape2();
            TNaming_Builder newFacesBuilder(newFacesLabel);
            FaceExplorer.Init(boxThatWasCutOut, TopAbs_FACE);
                if (!modifiedFaces.IsEmpty()){
                        const TopoDS_Shape& newShape = modifiedFacesIterator.Value();
                        // Uhm, the documentation has a lot to say about this NamedShape method. :-/
                        Handle(TNaming_NamedShape) aNamedShape = TNaming_Tool::NamedShape(newShape, newFacesLabel);
                        if (aNamedShape.IsNull() || aNamedShape->Evolution() != TNaming_MODIFY){
                            newFacesBuilder.Generated(currentFace, newShape);
    // PHEW! Maybe one day I'll understand all of that... For now, let's just accept that we're done with the CUT
    // operation: we've cut stuff, and we've stored all the necessary data in the Data Framework. So, this means that,
    // although the Indexes between the Faces of myBox and resultBox may be different, I SHOULD be able to use the
    // Selector thing from earlier to get a constant reference to a given face...
    printShapeInfos(myBox, cutBox, resultBox);
    // NOTE: if you pipe this output into a file, say "./occTest > tdfShapes.txt" you can then feed that txt file to the
    // parser2.py that I posted on the Forum "python parser2.py tdfShapes.txt" to get a side-by-side comparison
    // Success! Well, sort of. The Face indexes between myBox and resultBox are indeed different. So, now let's take
    // this Data Framework thing for a test drive...
    // scratch that, move on to selector
    //// First, let's ignore that Selector thing and see ho good this FindAttribute thing works
    //Handle(TNaming_NamedShape) namedShapeObject; // store the retrieved object here
    //myBoxLabel.FindAttribute(TNaming_NamedShape::GetID(), namedShapeObject);
    //TopoDS_Shape myRecoveredBox = namedShapeObject->Get();
    //TDF_Label myTestingNodeLabel = aLabel.FindChild(4, createIfNotExists);
    //TDF_Label myTopFaceLabel     = myTestingNodeLabel.FindChild(1, createIfNotExists);
    //TNaming_Selector myTopFaceSelector(resultCutLabel); // creates a selector at this Label
    Handle(TNaming_NamedShape) topFaceNamedShape;
    // myBoxTopLabel was defined waaaaay at the beginning of all this, when we first created myBox, before we Cut
    // anything out of it. This FindAttribute stores the Shape associated with this label in topFaceNamedShape
    myBoxTopLabel.FindAttribute(TNaming_NamedShape::GetID(), topFaceNamedShape);
    const TopoDS_Shape& theTopFace = TNaming_Tool::CurrentShape(topFaceNamedShape);
    std::cout << "The shape info for the recovered top face" << std::endl;
    printShapeInfo(theTopFace);
int main(){
    //runCase1();
    //runCase2();
    runCase3();
    return 0;
And for those keeping up at home, here’s an updated CMakeLists.txt as well:
project(occTest)
target_link_libraries(occTest TKBRep TKPrim TKernel TKTopAlgo TKMath TKBO TKG3d TKGeomBase TKCAF TKLCAF TKBool)
And then, before I get into the TLDR stuff, here’s the output of the printShapeInfos call near the bottom, formatted:
     loc = (0, 0, 0)         loc = (7, 5, 30)         loc = (0, 0, 30)
    dir = (1, 0, -0)         dir = (-1, 0, -0)         dir = (0, 0, 1)
    loc = (10, 0, 0)         loc = (2, 5, 30)          loc = (0, 0, 0)
    dir = (1, 0, -0)         dir = (-1, 0, -0)        dir = (1, 0, -0)
     loc = (0, 0, 0)         loc = (7, 5, 30)         loc = (0, 20, 0)
    dir = (-0, 1, 0)          dir = (0, 1, 0)         dir = (-0, 1, 0)
    loc = (0, 20, 0)         loc = (7, 10, 30)        loc = (10, 0, 0)
    dir = (-0, 1, 0)          dir = (0, 1, 0)         dir = (1, 0, -0)
     dir = (0, 0, 1)         dir = (0, 0, -1)         dir = (-0, 1, 0)
    loc = (0, 0, 30)         loc = (7, 5, 25)         loc = (7, 5, 30)
     dir = (0, 0, 1)         dir = (0, 0, -1)         dir = (-1, 0, -0)
                                                           Face 07
                                                      loc = (7, 10, 30)
                                                       dir = (0, 1, 0)
                                                           Face 08
                                                      loc = (7, 5, 30)
                                                       dir = (0, 1, 0)
                                                           Face 09
                                                      loc = (2, 5, 30)
                                                      dir = (-1, 0, -0)
                                                           Face 10
                                                       loc = (0, 0, 0)
                                                       dir = (0, 0, 1)
                                                           Face 11
                                                      loc = (7, 5, 25)
                                                      dir = (0, 0, -1)
And last but not least, the output of the last printShapeInfo call:
For i= 1 loc = (0, 0, 30) , dir = (0, 0, 1)
Alright, so what are we looking at? Well, the first output shows what we already knew: orig box (or really, myBox in case3) and new box (i.e. resultBox) have Faces with different indexes. in orig box, Face 1 is the Left Face, and Face 6 is the Top Face. In new box, Face 1 is the Top Face, and Face 2 is the Left Face.
Well, using the TDF_Label that I created on the orig box for the Top Face, I was able to grab a reference to that Face despite all the changes that were made to the Box as a result of the Cut operation: you can see that it is in fact the Top face b/c it’s coordinates are correct.
My next step is a little unclear for me. I want to understand a bit more of the Data Framework entries that are made, and why they’re made. In particular, I also want to understand this Selector business, b/c it seems powerful but I didn’t have to use it here. Which suggests to me that perhaps this is a false positive: did I really grab a Top Face off of resultBox, or am I kidding myself and I only grabbed the Top Face off of the original myBox? I’ll play with this some more, I’m just being called to bed by my dear Fiancee.
Feel free to post comments, critiques, encouragement, whatever. I’m pretty excited about the progress being made here, so I’m always checking the forum on my phone seeing if anyone has said anything.
I haven’t had a chance to read and digest this thread yet, but it’s really exciting to see this getting some attention! Thanks! -Ian-
Hello ezzieyguywuf,
looks like very good work, unfortunately I did not have time yet to go over it! Would it be possible for you to use a github repo? This code pasting here seems very hard to follow.
Yup, here you go. I didn’t expect the code to get so large, I was trying to make a very simple occ example, that’s why I didn’t use a github repo from the beginning. It still is pretty simple, but I guess the size of the source code can’t be avoided.
Another bump for another somewhat large update. I’ve finally convinced myself that in the example, the recovered Face is in fact the ‘Same’ Face as the original Top Face in the myBox while not being, in fact, the exact same Face. What I mean by this is that it is the Face on the Box AFTER the CUT operation, not the original vanilla face. I proved this to myself in two ways:
  1. I did a compare of each face on the original myBox with the recovered theTopFace using the TopoDS_Shape::IsEqual and TopoDS_Shape::IsSame methods. They all returned false
  2. I counted the number of edges on the recovered theTopFace, which is 8 as expected since the Face has a square hole cut out of it. I also printed out the number of edges on the original myBox to prove that it is still the same vanilla box.
That being said, I think we’re done with this milestone: I’ve used TNaming to recover a Face from a TopoDS_Shape without using the Index, since that Index is volatile. Whoot! Check out the git repo for the latest code and to see the examples I just listed in action.
I think the next ‘fun’ step will be to incorporate the Fillet part of the opencascade TNaming sample into my example, so I’m going to do that, but in parallel I’m also working on getting a more full understanding of how this TNaming stuff works, as I feel this will be critical for incorporating it into the FreeCAD code base. The next milestone after the Fillet thing will be a writeup of what is necessary to make TNaming work.
Edit: well, it’s 12:30 am here so I’m off to bed. Latest commit to the github repo includes such goodies as: a ‘runCase4’ that actually compiles and runs (this is the official opencascade TNaming example); an extended printShapeInfo method that accomodates printing out Edge information; a proof that the TNaming thing works for edges; the beggining of an example whereby a fillet is changed by referring to it using TNaming rather that it’s direct index.
I couldn’t compile your public branch. Is it out of date? TopTools_MapIteratorOfMapOfShape doesn’t work with TopTools_IndexedMapOfShape. Here is the change I had to make.
diff --git a/src/occPyTest.cpp b/src/occPyTest.cpp
index 2dbc860..7dfb252 100644
--- a/src/occPyTest.cpp
+++ b/src/occPyTest.cpp
@@ -809,13 +809,11 @@ void runCase4(){
     TDF_Label SelectedEdgesLabel = aLabel.FindChild(SelectedEdgesPOS); //Label for selected edges
     TopTools_IndexedMapOfShape mapOfEdges;
     TopExp::MapShapes(top1face, TopAbs_EDGE, mapOfEdges);
-    TopTools_MapIteratorOfMapOfShape edgeIterator;
-    edgeIterator.Initialize(mapOfEdges);
     //TopExp_Explorer exp(top1face, TopAbs_EDGE);
     Standard_Integer i=1;
     std::cout << "numEdges = " << mapOfEdges.Extent() << std::endl;
-    for(;edgeIterator.More();edgeIterator.Next(), i++) {
-        const TopoDS_Edge& E = TopoDS::Edge(edgeIterator.Key());
+    for(; i <= mapOfEdges.Extent(); i++) {
+        const TopoDS_Edge& E = TopoDS::Edge(mapOfEdges(i));
         const TDF_Label& SelEdge  = SelectedEdgesLabel.FindChild(i);
         // Creating TNaming_Selector on label
         TNaming_Selector Selector(SelEdge);
