Dependencies Not Found
Hi all,
After several attempts of installing cfMesh and HiSA I still get the “Not Found” tagline when I check for dependencies.
Attached are the log files and the output.
Thanks for all your help in advance!
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.8.6
Output.txt (681 Bytes)
Log HiSA.txt (115 KB)
Log cfMesh.txt (624 KB)
The same for me.
You use bluecfd core?
Julien
Here it works. I use bluecfd-core 2017-2.
Now: end of working day…
Version: 0.19.22846 (Git)
Hash: 1f46b72491a0008384a6db4f2615a656249f6f08
Python version: 3.6.8
Qt version: 5.12.1
Hello Thschrader,
So you don’t install openfoam v2006 ? You use instead bluecfd and install paraViem, cfMesh and Hisa in the preferences window of FreeCAD 0.19 ?
I have bluecfd-core 2017-2 correctly installed, it was running with FreeCAD 0.17. But when I install cfMesh I have plenty of warnings, and when check dependency it gives:
Checking dependencies...
cfMesh (CfdOF version) not found
HiSA not found
When I try to mesh something in cfdOF workbench I have an error but I don’t find a log file to share with you
Julien
Yes, I use bluecfd. I installed cfmesh/hisa with the “Choose existing file option”.
Download cfmesh/hisa zips from sourceforge and try this option.
You should run an openFOAM tutorial directly from the bluecfd-terminal to
check if the installation is ok.
Thanks for all your help thschrader!
I tried this method but is giving me the exact same problem, I’m still stuck :cry:
Bluecfd core is running without problem on chtMultiRegionFoam case.
I have the 2 softwares installed (the first time I have open FreeCAD 0.19, I have done the openfoam v2006 installation), Bluecfd and Openfoam v2006. Openfoam v2006 is not well installed because of Docker problems… Maybe it is a mistake, it is better to uninstall OF v2006 and try to install again cfMesh and Hisa.
Best regards
Julien
I try but it doesn’t work again. Join my log files
Maybe I have to clean the folders in Bluefcd core before trying to reinstall again and again?
Any advises?
Julien
log.Allwmake.txt (115 KB)
log.Allwmake.txt (624 KB)
Can you check if cfmesh runs from bluecfd-console without error?
Simply copy a cfmesh-cfdof tutorial (I used “elbow90degree”, runs very fast)
into the run folder, then run the “Allrun” batch-file.
Check the mesh with “checkMesh” command.
Paraview opens with “paraFoam” command.
When everything is fine, there should be an issue with FC.
If not, you should do a complete reinstall incl. bluecfd.
Again: for me it works. Strange…
Thank you for your support. I will try
I have done the elbow 90 test case and it works
What is the next step that I can check ?
Julien
install the newest cfdof wb and try cfmesh,
even when dependency check fails.
does it work?
i am on cellphone today…
To be sure how to do this:
I uninstall cfdOF from the add-on manager on FC
Close and open FC and reinstall cfdOF in add-manager
Reinstall cfMesh etc..? but I don’t touch to my blueCFD folder, I have already inside cfMesh-cfdof folder and hisa also ?
Right?
no, do not use the addon manager.
close freecad
delete cfdof wb folder from mod-folder
download new cfdof wb zip from github directly.
unpack zip and copy to mod folder
start freecad and do the dependency check.
I have try.
I have download and unzip from github the cfdof-master folder and copy it in the Mod folder of FreeCAD 0.19
Do the check dependency again and again not cfMesh and Hisa not found :frowning: .
I have try to mesh something and I have an error.
My FreeCAD folder from where the software is running in my download folder, is it a problem? I don’t want to move it now because maybe it can give other new problems.
Julien
I restart from the beginning.
Erase and unzip again FreeCAD0.19. Copy the extracted folder in my program folder.
When I open FreeCAD in the addon manager the benchmarks that I had choose before are already installed. Strange. I don’t know how to uninstall and start from a fresh FreeCAD
I think that I don’t put the cfdof-master folder in the right place, in my version of FreeCAd 017 in the Mod file there is no cfdof-master floder.
Do you are agree with this path?
C:\Program Files\FreeCAD_019\FreeCAD_0.19.22960-Win-Conda_vc14.x-x86_64\Mod\CfdOF-master
I check dependencies are again not found
cfdof wb is located in
appdata/roaming/freecad
when bluecfd/cfmesh runs fine, dont touch it.
still oncellphone… :unamused:
Ok sorry :wink:
I have put the folder in the right place now, I have remane it CfdOF (not CfdOF-master, initial name of the downloaded file). I see that there is 2 missing folders (named .git and pycahe) in the new cfdOF-master that I have downloaded.(old folder = obsolete in the view)
So I have try to check dependencies without the 2 missing folders. Result → cfMesh not found, hisa not found
So I copy paste these 2 folders from the old CfdOF folder, check dependencies. Result → cfMesh not found, hisa not found.
Of course I have close FC during these operations.
Julien
Hi
if i remember right, you have to remove the -master from the folder name
Again my folder structure, FC adds all additional wb here:
May cfdof-wb, can you try this?
CfdOF - Kopie.zip (458 KB)
for testing:
elbow90degree.FCStd (120 KB)
