Dependencies Not Found
I have erase all the FreeCAD folder in appdata/roaming/freecad and do it again from the beginning.
addon manager → install plot. Close FC
addon manager → install cfdOF Close FC (as described on the installation web site)
Check dependencies doesn’t work
Replace the cfdOF folder in appdata/roaming/freecad by the folder from github.
Damn…
OK, last try:
Can you use the LP-version instead of conda?
  • I have your file CfdOF-Kopie no success
  • Try to mesh the file elbow90degree, mesh exits with error.
Before try your version, to summerise:
I have in my folder appdata/roaming/freecad/cfdOF → from last github or your folder
In my folder C:\Program Files\FreeCAD_019\FreeCAD_0.19.22960-Win-Conda_vc14.x-x86_64\Mod I thunk that I have nothing to add!!
So try also to add in C:\Program Files\FreeCAD_019\FreeCAD_0.19.22960-Win-Conda_vc14.x-x86_64\Mod\cfdOF-master
but I have an error when loading the cfdof wb in FC.
11:51:37  During initialization the error ""'CfdOFWorkbench' already exists."" occurred in C:\Users\julien\AppData\Roaming\FreeCAD\Mod\CfdOF\InitGui.py
11:51:37  Please look into the log file for further information
Ofcourse in any case dependenies checker doesn’t work
Julien
yes, this is the correct location.
Ok I try your file.
In details, what I do:
  • copy paste your unzip file FreeCAD_0.19.22988_Win-LPv12.1.6_vc14.x-x86-64 from https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre
    in the folder C:\Program Files\FreeCAD_019
  • Start FC
  • From addon manager add plot module and close FC
  • From addon manager add cfdOF module and close FC
  • Modify the path of OpenFoam location in preference view of cfdOF → C:\Program Files\blueCFD-Core-2017\OpenFOAM-5.x + click apply
  • Try check dependencies → IT WORKS !!!
Thank you thschrader
Great!
Maybe not the right place to post but linked with the previous discussion
Is it normal that I have not the Assembly 3 WB in addon manager with the LP version of FreeCAD 0.19 ?
Julien
Is it normal do you think ? It is a problem for me, because I need assembly 3 WB.
i dont use assembly wb.
you should post your questionin the help forum for better
resonance
