You mean a Window or Door object which just punch a hole but no frame, panel etc. right? Yes, sub-volume works somehow but not convenient (screencpature), the Sketch outline is projected on ‘XY’ plane e.g. Not sure someone has make a feature request or not, seems not difficult but needs developer’s time
Yes. We are talking specifically about the library object “hole”, available in choice along with windows and doors.
I know of several ways to make an opening (hole), but they all look like propping up a falling ceiling with a mop.
But openings are used very often in construction (not everywhere openings need to be filled)
The problem with the opening has been identified and at the moment any solution options are inconvenient.
We can probably finish, since we are deviating from the topic.
Programmatically this is indeed not very hard. But a principle question needs to be answered. As you probably know you can select any shape and then turn it into a window. But to support a sketch-based empty opening we need to not use the shape of the sketch for the shape of the window. What criterion should we use to decide that? Check for the presence of solids, faces, or check if all edges are part of the OuterWire, or …?
I don’t know which option would be the most convenient. For me it doesn’t make much difference how it is arranged “inside”. The main goal is to make a hole in the wall by simply indicating its location. Of course, with certain dimensions (width and height). If there is more depth, it will be possible to make niches in the walls. (windows and doors already have this - parameter Hole Depth).
Perhaps someone will need openings with arches or with bevels (by the way, this also applies to ordinary windows and doors). But this would already be a useful “addition”.
Nowadays, such windows and doors can also be assembled, but it would be more convenient in a library of ready-made models.
Here is an example of a GIF image from a blender addon.
Roy_043 Thanks for putting it in a separate topic!
Thank you!
It works. But you must admit that it is not at all necessary to know such a subtle feature. This looks like a hack)
View tree is often cluttered without it. Creating more additional entities for the sake of hiding/anhiding does not seem logical.
In addition, it is not always known in advance what and at what level will need to be hidden/unhide. Making a part for each level is not much easier than changing the finished opening once (an extra task)
Maybe another a little less cluttering possibility would be to use a Draft Layer.
Objects will still show after hide/show of the wall, but then all undesired Doors/windows can be hidden at once afterwards…
Yes, but note that just anything can be used to create an opening in a wall. You can create a sketch, extrude it (with Part Extrude or for ex. Arch Structure), then use that object as a subtraction (use the Arch Remove tool).
So the functionality actually exists already.
In IFC terms, also, an opening is not the same as the object that fits into that opening (the window). In NativeIFC I’m actually tending towards expliciting that. In Arch/BIM, we have a kind of “combo” tool that does both at the same time. But does that still make sense when we have an opening without window inside?
But indeed, programmatically, it is simple. If you think it’s a good idea, I have nothing against it, the more functionality the better
Then, if Window tool can be used to create Opening only, then, it should only exported to IFC with ‘opening’ in IFC only. Anyone would like to tweak the existing Window tool to achieve that?
2 options I think:-
If the Window tool does not define any Frame, Pane, Panels, even with an underlying Sketch, the Window Object should only return an ‘opening’ only.
There is an addition attribute say, ‘Create Opening Only’, when it is True, the Window object does not create the window shape and export to IFC with ‘opening’ only.
