In freecad 0.21.1 and 0.21.2 I’m noticing that I can’t do any editing into pocket with vcarve especially at a depth over 8mm and above
The path lines stay suspended into the air over the pocket and can’t carve the piece can someone please help with solving this problem
can you upload the file?
I have been trying to but I get this http error
If the file is larger than 1MB, you could upload it to Google Drive, for example
https://drive.google.com/file/d/1CWavIWzt04vgfhQbCKUXE4EG6z7vWisC/view?usp=drivesdk
Okay I see hope you can get it and that’s what I trying to explain
Apparently the file is not released
I don’t understand what do you mean not release I’m do you have a site where I can send you the whole freecad file to checkout
All you need to do is share the file in Google Drive and post the link here
Okay let’s try it now
it works now. do you also have a freecad file?
Yes I do
Hello, i have the same problem… When I start the CNC, after making the H0 point, the CNC makes the 5mm path above my board!
SebAlsace Please use English in the English sections of the forum. You can use an online translation service if you need help with that. Alternatively there a French forum available.
https://drive.google.com/file/d/1D36xjWTkJPinUWziDAsDSqgWHoY93sW_/view?usp=drivesdk
Here’s is the freecad file
The release seems to be missing here again
Should be good now
Does it work if you position the workpiece higher?
No same thing ![]()
