I’m trying to create my first part, to be CNC routed from 4.7mm plywood on a ShopBot PRSAlpha machine. I’ve set the processor output to ‘opensbp’ for the ShopBot. Here’s the first lines:
'Exported by FreeCAD
'Post Processor: opensbp_post
'Output Time:2024-01-23 12:54:37.706292
' (1_4in_Endmill002)
&ToolName=2
&Tool=2
JS,,100.000000
JZ,4.9000
JS,50.000000,
J2,214.1813,317.1808
JS,,50.000000
JZ,2.9000
MZ,0.0000
CG,,118.4545,288.9902,-40.1813,-40.1813,T,-1
The line ‘JZ, 4.9000’ moves the Z axis to a point 4.9 inches above the origin. In my Job->Profile, the Clearance height is 4.9mm, which is where I’m guessing this number is coming from.
According to the ShopBot Command reference manual, for the ‘VD’ (Values for Display settings):
Linear Units (default = inches)
Sets the X, Y and Z axes to run in inches (0) or millimeters (1). One inch = 25.4mm. The default is in inches,
so the values given in the Unit Values for Different Gear Ratios assume that you are working in inches.
If I understand this correctly, without a VD command proceeding the JZ command, the ‘4.9000’ will be interpreted as inches and not millimeters. Is my understanding correct? How can I set FreeCAD to output an Open ShopBot processed file using the correct units?
Thanks so much for all your help. I’ve attached my file, if anyone’s curious.
-Kevin
OS: Ubuntu 22.04.3 LTS (ubuntu:GNOME/ubuntu-xorg)
Version: 0.21.1.33694 (Git) AppImage
Branch: (HEAD detached at 0.21.1)
Hash: f6708547a9bb3f71a4aaade12109f511a72c207c
Python 3.10.12, Qt 5.15.8, Coin 4.0.0, Vtk 9.2.5, OCC 7.6.3
* A2plus 0.4.62
* FeedsAndSpeeds 0.5.0
* Assembly3 0.12.1 (Disabled)
* Help 1.0.3
* Assembly4 0.50.6
* woodworking 0.21.1.33694
