it is impossible to select a position from the table in random order (1-100-50-25-75)
in order for the table to work in (body.) mode, the list in the model must return to position 1 every second time (1-100-1-50-1-25-75)..
since the list is used by the model, I think this is a problem with automatically updating the table when working with the model.
Question 1: How do I set up automatic table updates when working with a list from a model?
Question 2: How to detach an object from a table if it needs to be deformed in place
Question 3: How to (quickly) bind an object back to the table if it became clear that you need to increase/decrease its cross-section?
watch short video
https://youtu.be/v2fAdTovfcA
I didn’t know that feature in FreeCAD.
May you write a link where learn this?
pMB
I saw this video. all questions to the author =)
https://youtu.be/NazxYVIeCOU?si=JPuN-JHfyQPZBax6
I would like to see: is it possible to bind 2 or more objects to one spreadsheet?
if I copy an object, then why is the table copied as well? how to copy an object by making it linked to the first table (need a video)
if there are pages in the table, then the entire known assortment of EVERYTHING can be combined into one spreadsheet with the possibility of expanding its own data.
Thanks ![]()
pMB
