Template:"WB Name" Tools navi ... & related
Hello
:mrgreen:
I would greatly appreciate editors making even minor changes to type templates:
eg:
https://wiki.freecadweb.org/Template:PartDesign_Tools_navi/
https://wiki.freecadweb.org/Template:Sketcher_Tools_navi
https://wiki.freecadweb.org/Template:Powerdocnavi
https://wiki.freecadweb.org/Template:Userdocnavi
to post edits in this topic. Translators will then be in the know when changes need to be made to their language versions. :wink:
by the way … template https://wiki.freecadweb.org/Template:Powerdocnavi
contains a red link to a document that has been removed. :unamused:
https://wiki.freecadweb.org/Template:Draft_Tools_navi
This page was last edited 2021-07-15, 12:38:27.
:exclamation:
Yes, but this is just an intermediate step. Because some pages were deleted I had to check and remove all links pointing to those pages. More work has yet to be done when it comes to the Draft documentation. And this page and the Draft_Module page will be done last for obvious reasons. When they are done I’ll report this.
This page was last edited: 2021-07-23, 23:11:32.
Edit:
the admin has made the necessary changes to the template pages of other languages.
I have updated:
https://wiki.freecadweb.org/Template:Devdocnavi
Reason: removal of Module_Creation link.
thank you
:smiley:
https://wiki.freecadweb.org/Template:Std_Base_navi
was updated
Updated again.
Template:TechDraw_Tools_navi was updated. See here:
https://forum.freecadweb.org/viewtopic.php?f=21&t=61803&p=533424#p533424
thanks for the info.
Template:Draft_Tools_navi was updated. See here:
https://forum.freecadweb.org/viewtopic.php?f=21&t=57154&p=533985#p533985
Two navi pages were updated:
Added Std_UserEditMode.
Made links and categories translatable.
Minor change to usage instructions (but those instructions can be left out in translated versions).
Reordered the “Miscellaneous” tools to match the Draft WB page.
Added Draft_Hatch.
Added Draft_AddNamedGroup.
Minor change to usage instructions (see above).
reading your last post Roy, i clicked on Std_UserEditMode.
that page is translatable but was not proposed on this link.
https://wiki.freecadweb.org/Special:LanguageStats
any reason?
Edit: as I start to translate, i’ve refreshed the above link, and now the Std_UserEditMode appears. Strange.
Another navi page was updated:
https://wiki.freecadweb.org/Template:Spreadsheet_Tools_navi
Added Spreadsheet_Preferences.
I have already updated the /pl and /ru versions. But please check those. The other languages rely on redirects.
thanks
https://wiki.freecadweb.org/Template:TechDraw_Tools_navi
Renamed the “Import/Export” category to just “Export”.
Moved the “Decorations” category.
Added the “Extensions” category. Note that more tools will be added to this category.
Added horizontal lines.
Made TechDraw_Workbench link translatable.
:sunglasses:
Roy my appreciation to you,
you have revised all the major templates (if I counted correctly it’s 21 pages), and all the existing language versions. :bulb: it’s really a lot of work.
So I have a question, please confirm if I am right :unamused:
You have prepared Polish versions of templates that have not been translated so far, e.g:
https://wiki.freecadweb.org/index.php?title=Template:Surface_Tools_navi/pl&redirect=no
page source content is:
#REDIRECT [[Template:Surface_Tools_navi]]
if I want to prepare Polish version, I have to remove this content and prepare translated content according to template’s main page - right :question:
Yes. That is correct.
I have not really revised these navi templates. All I have done is made the links and categories in the English versions automatically translatable by inserting {{#translation:}} where appropriate. This has the advantage that for the initial versions for the 24 supported languages you can just redirect to the main template. Many of these versions will actually never be translated and in those cases the redirect has the added advantage that the ‘translated’ template is always up to date with the main template.
When a translator wants to do a proper translation the content of the main template has to be copied and the visible text has to be translated. All occurences of {{#translation:}} can be replaced by, for example, /pl. I would do that, but strictly speaking this is not required.
I have just updated:
https://wiki.freecadweb.org/Template:Part_Tools_navi
Several tools were missing and the order of the tools in the ‘navi’ did not match the Part Workbench page.
Thanks for the information,
there will be something to do :mrgreen:
