Starting parts
I thin it would be good to provide some standard parts (profiles, tubes…) with FreeCAD.
Parts should be fully parametric and so easy to change.
Attached are examples for U and L-profile and rectangular tube.
tube-rectangular_v000.fcstd (11.7 KB)
profile-U_v000.fcstd (8.52 KB)
profile-L_v000.fcstd (6.77 KB)
Indeed it would be great to have a library of parts for FreeCAD, you are not the first person to raise the idea… What we would really need, IMHO, is some effort to setup such library outside of FreeCAD itself. There is no point in bundling a library like this inside FreeCAD,it is much better to keep it outside,o on the web (more easily updated) and have FreeCAD plug into it, which would probably be fairly easy. There were already many talks about that on this forum
Why not start with a github repository, or something like that? Anybody interested?
Hi, it is a good idea !
This could then be integrated as the “SketchUp 3DWareHouse” (for example).
@bajsi : do you want to make the github ? If not, I’d like to do :wink:
I have some wood materials with french standard dimensions( Timber, decking, flooring, panels, ironsmith).
http://forum.freecadweb.org/viewtopic.php?f=10&t=1378
Yes, this post is interesting(the last message is a bit old though). But why not start with a github as proposed yorik ?
It’s easy to set up (compared to openPLM) for a single user like me. It’s also easy to use for users.
Yes I also think a good first start would be to build a collection of parts, on some easy-to-use and easy-to-collaborate structure like github. Then, all the rest will become easier, like mount a more advanced system, a sharing platform, etc…
I do agree that OpenPLM is hard to grasp. I did the demo and was baffled by all of it.
But Github is Git, and I’m sorry but Git is not so easy to use! Can you add files from the Web UI on GitHub? As far as I know you can only create a new text file.
I guess it would be the most convenient way for now.
If bajsi doesn’t manifest in the next day or so I say do it! :slight_smile:
We need to set up a structure though. Also, since FreeCAD is open source and in the spirit of openness, this repo should also have STEP files so people who do not work on FreeCAD can use these files too. Or .BREP? It is the native file format for Open Cascade and all apps based on it can open .brep files (Heekscad, Salome Meca…)
I suggest this repo could have category folders (hardware, profiles…), then each folder would have a FCStd folder and a STEP folder.
I have been looking a bit into openPLM and that might be a good idea to use in the future.
Never thought of Github - honestly I don’t really know how to use it (I am a mechanical engineer by profession - but I also do some python programming for FEM codes).
If someone is willing to set up such a system, then I can manage/correct/improve the starting parts.
Maybe there are solutions where it’s easier to upload than github (a shared dropbox? google drive?) I don’t really know, but github has the advantage of being easily readable, browsable and mirrorable by other people… Anyone has another idea?
If we go for github, I can setup a repository on my account or on the official freecad one, then who is interested in working on it just creates a github account and asks me, and I’ll give you write access on the repo, a bit like we did with the freecad homepage.
Yes you’re right, for those who want to share its parts is relatively difficult. But at the beginning the users can download easily a part and we can share parts on this forum.
An example with folders : https://github.com/wood-galaxy/FC-Library
(in ironsmith folders, there is three folders brep, step, fcstd)
Yorik, this is my github account.
I have a friend who is working on a clone of thingiverse. He mentioned open sourcing the code when he was done. A website like that would allow people to easily upload their own parts and profiles, and I think he was working on a webGL (or something?) viewer for .stl parts. I haven’t talked to him in a while, but I could touch base with him and see how it is coming along and if we could make this a long-term goal.
You know what would be really cool? A website frontend that stores all the parts in a git repo so you could easily download and keep updated with all the parts.
Can you selectively download files from a git repo? If not and the repo grows humungous, then everyone’s harddrive space will be filled with parts they may not want or need.
You can do "sparse checkout"s which still means that you have the whole repository, but things you don’t need are not in your working copy and therefore might benefit from compression.
You can do a “shallow clone” which means that you get only the last revisions of each file.
And you can split up the project into “submodules”. But i think none of the above will perfectly fit the problem.
IMHO the FreeCAD Resource Project should manage a local cache. And download missing Parts from a server.
Unless the part library stays smaller than freecad by itsself, i don’t see a problem.
And on the day it grows to big, will get the FreeCAD Resource Project ready.
LOL, another one. Problem is, there are too many - and none is getting it right. Or having success…
There are already a couple open source STL viewers, I hope he’s not reinventing the wheel.
Already done.
https://cubehero.com/
http://www.fabfabbers.com/
It’s possible from Github, but not really user friendly.
Okay I created a repo here (on my account first, when it grows we fork it on the official freecad account): https://github.com/yorikvanhavre/FreeCAD-library I propose to store stuff there to begin with, and it will always be time to move to some better system when we have one. I also gave write access to rockn, normandc and shoogen. Anyone else interested? Just ask me.
Basically, for who is new to git and wants to contribute (after gaining write access), you must install a git client on your machine, then you sync to the github repo (this will create a local copy of the files on your machine), then you make changes, add files, etc, then commit (“register”) the changes, then sync again, which will upload your changes to the repo. But just ask here and we’ll help you.
Ah github has an embedded stl viewer now I believe…
Great Yorik, thank you.
Does it make any sense to save all the FCStd files uncompressed (level 0), to allow git use do it’s delta compression? This might help to keep the repository smaller, while the working copy gets bigger.
The background is that ZIP-compression only works a single item (like a shape in the FCStd file) while the delta compression of git should benefit from multiple shapes in a FCStd file and from multiple revisions.
Yes you have to right-click and “download the link target” otherwise github displays the file as text.
Thanks yorik, I would try to push something later.
Ah, I obviously hadn’t done any research. I didn’t know other clones existed or stl viewers and stuff. Well I look forward to the library though, thank you for working on it everyone :sunglasses:
That’s interesting… Would it work? I’m not sure that even with 0 compression it won’t still be a binary blob with no possibility of diff… I already did some experience with uncompressing fcstd files (inside, it’s almost only text, since brep files are actually text files!) but it is a bit complicated, and might be much hassle for such simple files… I believe those Parts won’t get many versions…
Yes, it’s still one continuous blob. But I’d like to distinguish three aspects. diffs, patches, and (delta) compression. There basicly two types of diffs those, that can be applied as a patch and those you don’t contain enough information to be used as a patch. A (unified) diff on sourcode can be used as a patch. Git can also generate binary diffs that can be used as a patch.
You can as well use external diff tools or convert the whole file to a textual representation and to a diff on the text.
For example the plain text of a MS Word Doc could be extracted or the EXIF info of a jpeg-File.
Those diffs are useful when looking at commits but they can’t be used to patch the original file.
The (delta) compression works on binary files as it works on text files. i search for patterns that are reused between different files and versions. But on already compressed files (like FCStd) i won’t find anything useful,unless a subfile (e.g. a shape) is exactly the same, and the (zip/deflate) compression parameters are exactly the same.
Wow very interesting explanation. I’ll definitely do some testing with fcstd files… Indeed if this can reduce the amount of data stored for each version, that can be tremendously interesting, imagine that with huge projects…
