That’s the continuation of Sketcher performance - why is Python the culprit?
I ended understanding how to use the VStudio profiler well enough to draw some conclusions, and Python is not the culprit (I’ll put the FreeCAD version info and details on the procedure at the end. I’ll say it here though that the profiling data has been obtained with a Windows build, on a Win10 Home hosted by a Lenovo laptop, AMD Ryzen 5 3500U 2.10 GHz, with 16.0 GB of RAM).
In short, for sketches with (too) many elements and constraints:
- about 58% of the CPU goes into SketchObject::solve(bool), with about 36% into Sketch::solve(void) and 21.5% into Sketch::setupSketch(…) (see Figure 1 below). Most of the CPU goes on eigen’s account, but there are some small bits that I’ll come back to .
In any case, Python adds on overhead of about 3% to this branch of the call tree. - about 38% of the CPU goes into some async execution with an anonymous (not assigned to any module) lambda - see Figure 2
I have some troubles identifying where this comes from. Initially I thought that it may be some callbacks to pass the results back into Python-land once the “C++ solving” is complete, but I find way more plausible to be the
auto fut = std::async(&System::identifyDependentParametersSparseQR,this,J,jacobianconstraintmap, pdiagnoselist, /*silent=*/true);
makeSparseQRDecomposition( J, jacobianconstraintmap, SqrJT, rank, R, /*transposed=*/true, /*silent=*/false);
int paramsNum = SqrJT.rows();
int constrNum = SqrJT.cols();
fut.wait(); // wait for the execution of identifyDependentParametersSparseQR to finish
towards the end of the int System::diagnose(Algorithm alg) method in the GSC.cpp file (because, yeah, eigen again)
I will appreciate though an explicit confirmation coming from the ones in-the-know that the first hypothesis (passing back some data into the Python-land by using async callbacks) is rubbish and I can forget about it.
Figure 1 - the SketchObject::solve(bool) CPU budget
Figure 2 the async call into some lambda
The FreeCAD version details
Version: 0.21.0.31291 (Git)
Branch: fallen-fruits
Hash: d763f5a64aef76c94653e7f43e854d3c962210d3
* CurvedShapes 1.0.4
* freecad.gears 1.0.0
* lattice2 1.0.0
* sheetmetal 0.2.59
The profiling procedure
- Build the Release configuration following the instructions
- download the
solverLoad-2oo.py (4.13 KB)
file and place it in some directory - open the solution in VisualStudio and set the FreeCADMainCmd as the solution’s ‘Startup project’
- edit the FreeCADMainCmd project’s properties and, in the Debugging section, set the full path to the solverLoad-2oo.py as the value for the “Command Arguments” property
- in the VisualStudio Debug menu, choose the “Performance Profiler (Alt-F2)”
- select the “CPU Usage” checkbox then press the “Start” button at the bottom of the page
- wait for the execution to finish (in my config, took about 1m40secs) and the report page to finish analyzing the data
- click “Open details” link (under the plot) and set the “current view” to “Module”
- Right click on the list of modules and, on the popup menu, pick “Load all symbols”. Wait for the view to settle
- switch the current view to “Call tree”
- explore at you leisure the contributions of various functions to CPU consumption
