Thank you for the feedback.
Geometry extension development: Geometry facade
Today I have merged sketcher code that develops the concept of sketcher geometry extensions to be able to treat extended geometry more conveniently for c++ developers (GeometryFacade and ExternalGeometryFacade). There are also Python counterparts of these as I want to provide convenient access to all this universe for Python developers.
The following is meant mainly for developers, but I will try to explain it as simpler as possible.
Until now there was geometry Part::Geometry, there were extensions (parent class Part::GeometryExtension), there were unused sketcher extensions (Sketcher::SketchGeometryExtension and Sketcher::ExternalGeometryExtension). This code was a previous effort to provide an interface compatible with Realthunder defining geometry. However access to this extensions implied obtaining the extension from each geometry reading or mangling it and setting back the extension. The fact that sketcher geometry relevant data members are spread over a geometry object (for example construction), and potentially several extensions (a defining external geometry will be have an ID and layer information, which is or will be stored in the SketchGeometryExtension, and information due to its defining status, for which it will have a ExternalGeometryExtension too), leads to overcomplicated difficult to read, error prone and cumbersome to maintain code. One solution is to use a Facade object that integrates in one object the interfaces of geometry and extensions.
A Facade is a well-known design pattern that provides an interface for a subsystem (in this case the Part::Geometry and the extensions). The intent is to enable to interface with a (potentially complex) subsystem via a simpler interface (which may not necessarily offer all the functionality of each of the components of the subsystem).
A first Facade (Sketcher::GeometryFacade) object operates on a Part::Geometry object and its SketchGeometryExtension, and inherits the extension interface (in full), while it only offers the part of the functionality of Part::Geometry relevant for common sketcher operations. Currently SketchGeometryExtension only features an Id (which is unused and is intended to support RT’s long Id in his Part::Geometry), but it will have for example a layer index indicating the layer where a given geometry is to be drawn. An example:
const std::vector< Part::Geometry * > &vals = getInternalGeometry();
auto gf = GeometryFacade::getFacade(vals[GeoId]);
auto id = gf->getId();
This Facade also offers some convenience utility functions, for example copying an Id from one Geometry to another can be as simple as this (last line only relevant the others provided for context):
const Part::Geometry *geo = getGeometry(GeoId);
std::unique_ptr<Part::GeomBSplineCurve> bspline(new Part::GeomBSplineCurve(curve));
Part::GeomBSplineCurve * gbsc = bspline.release();
GeometryFacade::copyId(geo, gbsc);
A second facade Sketcher::ExternalGeometryFacade, inherits from both SketchGeometryExtension and ExternalGeometryExtension, as an external geometry as an Id as normal geometry does, plus it has additional status flags (defining, detached, missing). These are based on realthunder’s interface to support some of the additional functionalities of his branch.
Divergence/Integration with LinkStage3
The PR above does not create extensions (unless explicitly commanded from Python), as it is not currently invoked by SketchObject. So this PR neither diverges, nor integrates any work.
Following the GEN_ID macro of Realthunder, but using a real function instead, a placeholder (no actual calculation of Ids) could look like this.
Merge of functionalities of LinkStage3
In the meantime I have tried to explore the amount of work necessary to integrate realthunder’s functionality.
There are some tens of commits difference over 3 years only for the sketcher (source git log HEAD..realthunder/LinkStage3 src/Mod/Sketcher):
commit 6c43b147bf5a77601e51ba48d87dad0c4f105fc7
Author: Zheng, Lei <realthunder.dev@gmail.com>
Date: Thu Oct 22 10:18:44 2020 +0800
Sketcher: shorten constraint property display
commit 654f1d5e437ebd1b938fb2575cc62ada3fea012d
Date: Thu Oct 22 10:18:04 2020 +0800
Sketcher: add sanity check on constraint expression when restore
Related #54
commit 9a04770542a669b8c17bc4057c924d77e5940d5d
Date: Thu Oct 22 10:17:35 2020 +0800
Sketcher: fix potential crash in rebuildExternalGeometry()
commit 456f9b236cc82e72455efcd73617304093a1abcc
Date: Wed Oct 21 09:55:10 2020 +0800
Sketcher: fix missing transaction for undo/redo in EditDatumDialog
commit 999405b33189252b4bb7ce564ec127039db332fc
Merge: 95367eb253 bc6fefe3a0
Date: Fri Oct 16 05:39:34 2020 +0800
Merge 'upstream/master' into LinkStage3
commit f1f2ea088215d1ae5f090c892dde6489e55b0853
Date: Fri Oct 9 13:03:59 2020 +0800
Sketcher: fix CommandSketcherBSpline build Windows
Fixes realthunder/FreeCAD_Assembly3#321
commit 39514734b6ed396d97f987637c9bd36588c53fa2
Date: Sun Oct 4 18:05:24 2020 +0800
commit ab88228d823feab9ca7e4fab19ff83b8c197e3bf
Date: Mon Sep 28 12:33:36 2020 +0800
Part/Sketcher: support auto grid scale in ViewProvider2DObjectGrid
commit 2695ba34d0d50d1c02e3d7cfd1587c2d2bcff1be
Date: Sat Sep 26 07:13:34 2020 +0000
Sketcher: fix pixmap cursor hot spot
commit 5a632c21f75d9347c38db03866f5f2a1aa2d1d59
Date: Sat Sep 26 04:05:56 2020 +0000
Sketcher: update all open documents on constraint renaming
In case of external linking
commit 4d81bc69ee5690e8d98dea055f5e3cab7a3974fc
Merge: 921df5da81 0306c237ed
Date: Fri Sep 25 13:09:53 2020 +0800
Merge 'upstream/master' into LinkMerge
commit 3a270db626c3e311059176290504fb4a1e423f78
Date: Sun Aug 16 19:37:25 2020 +0800
Part/PartDesign: improve topological naming
Reduce direct use of TopoDS_Shape as much as possible, in favor of
TopoShape, which carries the topological name mapping.
commit 281f8a5236501a6d8c08e2b89ade018779b291c1
Date: Wed Aug 5 09:46:45 2020 +0800
Sketcher: fix build warning
commit fa664bad77956db24cbdde84df2510308f7c6c8d
Date: Mon Jul 27 11:09:05 2020 +0800
Sketcher: reduce unnecessary recompute on editing finish
commit 902ccd15bddf6543107a2b6d94ac90a8dc702fc6
Date: Fri Jul 17 21:24:36 2020 +0800
App/Sketcher: fix linked ObjectIdentifier::canonicalPath()
Fixes realthunder/FreeCAD_Assembly3#311
commit 07c1eff2cbbfe55b9fe4ad34b472a138b9ceb530
Date: Fri Jul 17 17:29:11 2020 +0800
Sketcher: fix undo/redo handling
commit 6bbc742ebd081c5c8e92f85672f2a74ce5956dbe
Date: Fri Jul 17 17:27:36 2020 +0800
Sketcher: fix PropertyConstraintList related problems
Fixes realthunder/FreeCAD_Assembly3#310
commit 08d98012bc060b20f7f237931d2b54a3123f0002
Date: Fri Jul 17 08:36:16 2020 +0800
Sketcher: fix addConstraints()
Error caused by merging with upstream
Fixes realthunder/FreeCAD_Assembly3#309
commit 7087d2647deb6b4fc5a26de96dc35f990134fea0
Date: Wed Jul 15 07:43:00 2020 +0000
Sketcher: enable PropertyConstraintList::isSame()
Because sketcher constrain is often used with expression. Enable
isSame() can greatly reduce recomputation due to unrelated changes in
spreadsheet, such as add/remove rows.
Related realthunder/FreeCAD_Assembly3#306
commit d2fa6450cbde623936840604274a45e01eff3ce3
Merge: c1d8e4dc91 6e40c19f73
Date: Sat Jul 11 12:50:51 2020 +0800
commit 58609b6fdbc4eef82f44ff58c30d65658b95e415
Date: Sat Jul 4 16:45:46 2020 +0800
Sketcher: temporary fix of external reference losing mapped topo name
commit c8043169fa5027834f14aab64326bd9cabfae869
Date: Thu Jun 4 04:29:41 2020 +0000
Sketcher: fix selection on editing
The editing sketch may live in a non-active document
commit 204a7e3740ecf41535df42f76b1720b3e647d2e1
Merge: 94e99c6a99 99a99f48ef
Date: Thu May 28 17:20:11 2020 +0800
commit 6ff8bb2fcfb2c8b734e0c1a8ed47843fc71bf2a2
Date: Wed May 13 05:15:31 2020 +0000
Sketcher: relax migration error check
commit 43874d7136a91d391683a81a2c2e13b614a21650
Merge: 4c2fc7ce60 419e8f7a99
Date: Sun May 3 10:08:20 2020 +0800
commit 53cea697b13c96905e8e10cf634b5c0af6941b99
Merge: 5c425a09b7 2d29ac5fc1
Date: Thu Apr 16 08:00:13 2020 +0800
Merge 'upstream/master' into LinkDev
commit e4584793c323fe76a39fe631ebd1008c0c3f32dd
Date: Wed Apr 8 15:11:37 2020 +0800
Disable copyBeforeChange() in some property
Because it causes ill behavior and requires more changes in
cooresponding workbench.
commit 604b89308f410df3b02da6ff510596cef89d5b1e
Date: Tue Mar 31 13:15:03 2020 +0800
App: improve document recomputation
The recomputation optimization is enabled by parameter
BaseApp/Preferences/Document/OptimizeRecompute (default to true). It
works like this,
Property::aboutToSetValue() will make a copy of the property using
Property::copyBeforeChange(). Property::hasSetValue() will then compare
the current property value with the saved copy using Property::isSame().
If the values are the same, the property will not be touched, and hence
not call PropertyContainer::onChanged().
DocumentObject adds a new _revision that will increase inside its
onChanged() function, unless the changed property is marked as
Property::Output/NoRecompute. Document::_recomputeFeature() is optimized
to call the features recomput() if and only if any of the unmarked
property is touched.
The net effect of this optimization is so that the object is recomputed
only if any of its property has actually be changed, or any of its
linked object is changed.
Property::isTouched/purgeTouched() are changed to virtual to allow
customization. PropertyLinkBase overrides these function to report
touched in case the linked object's revision number changes.
Property::isSame() has been changed to pure virtual function, forcing
every property to provide a more efficient implementation. For
properties that do not support comparision, it shall always return
'false' from isSame(), and also return nullptr from copyBeforeChange().
User code can force touch the property by calling Property::touch(),
or force recompute object by calling DocumentObject::enforceRecompute().
commit 06d2efcefdf0fb3b19a45aadc92521739c556c45
Date: Wed Mar 18 07:09:02 2020 +0800
Sketcher: fix typo during merge
commit 96f97995235cc66f458ac6f40e7cd83071a8f0b1
Date: Sat Mar 7 13:01:11 2020 +0800
Fix build for MacOSX
commit 18f9a70a8f5dca87e0e60d27145e9a9fb0a10dfd
Merge: bbde42384d c782435b7b
Date: Fri Feb 28 16:22:32 2020 +0800
Merge branch 'origin/ExprCompleter'
commit 73be870c5c2a009aaf97c8fa2970de34e57216af
Date: Thu Feb 27 09:59:58 2020 +0800
Gui: improve support of named sketch constraint in Expression completer
commit 9f2b113fabb47eedf31a30c75538361b1b97aecc
Date: Sun Feb 2 15:37:17 2020 +0800
App: change Property::getPaths() and getPyPathValue()
Since ExpressionCompleter will now look into Python attributes, there
is no need to expose duplicated information through getPaths(), except
those that provides extra information (e.g. Rotation.Angle with extra
unit information)
getPyPathValue() is modified to return Python attributes after the
given path.
commit 21e6e898962681f3cc8c757633ad4d6a00328b5c
Merge: e24bc133c3 01e8e7f777
Date: Tue Feb 18 12:16:20 2020 +0800
Merge branch 'upstream/master' into LinkDev2
commit 09e960d7d4f2d91698fc10f03017a4c0eb65631c
Merge: 9ac862bb94 1d9a3ab790
Date: Wed Jan 15 08:04:40 2020 +0800
Merge branch 'origin/Screenshot' into LinkDev
commit d72a496d0899c28b37084babab6e8cfb6fd98c38
Merge: dcfb230e9d c075380674
Date: Fri Jan 10 14:07:47 2020 +0800
commit bd119f7e0b6d67ab30fdd17d4a9198399ef160ea
Date: Fri Aug 30 11:02:16 2019 +0800
Sketcher: fix missing update on expression change
commit 51db4153731ac112f2b8c72a30f38565a0db6e76
Date: Fri Aug 23 18:58:14 2019 +0800
Sketcher: fix constraint update in undo/redo
commit bf3031326ef4fa8c14e83bca3b0470680e58f8f4
Date: Wed Aug 7 08:41:53 2019 +0800
Sketcher: auto undo when canceling constraint editing
Related realthunder/FreeCAD_Assembly3#207
commit 1dfd9b93c9f9a1bfe56e1aa940b118c933b2de1c
Date: Mon Aug 5 12:32:27 2019 +0800
Support save/restore document into/from directory
This is supposed to be the first step towards a proper support of
version control in FreeCAD. The commit enables user to save a document
into a directory without compression. Here is a summary of the changes,
* Add proper support of XML characters content in Base::XMLReader and
Base::Writer. Use XMLReader::beginCharStream() to stream either binary
or text data. Binary data will be base64 encoded on the fly with user
defined line size. The base64 string is stored as plain character
content inside the current XML element. Text data is stored inside
CDATA section with automatic detection and handling of CDATA end tag
inside the text. Be WARNED though, there is no validation of text
character yet. The user must ensure the input text is valid UTF8.
* Add three properties to App::Document to let user fine tune directory
saving options for better version control. They are,
* ForceXML, a integer specifying the level of preference to store
property content inside the XML file. 0 being the least prefernce,
i.e. store everything into separate files if possible.
* SplitXML, a boolean value to decide whether to split each object's
content into separate XML files.
* PreferBinary, a boolean value indicating the preference of stroing
property content as binary or text.
These options only works when saving document into a directory. The
default setting, which is also the recommended setting for version
control is, ForceXML=3, SplitXML=true, PreferBinary=false. The default
options can be changed using parameter editor with path
* Modification in various properties to support the above options.
* Various GUI modifications to allow chooseing directory (and special
file name Document.xml) for saving.
* New signalDocumentFilesSaved to signal any files addition and removal.
This is intended to be used by version control modules to automate
file adding and removing.
commit 6205d58e5733cf63054d093d8e727a4239329388
Date: Mon Aug 5 08:04:03 2019 +0800
Sketcher: fix external editing
commit 9c6d77d0efd3534a85497ea0489631129f0d7831
Date: Tue Jul 16 13:45:10 2019 +0800
Sketch: fix in-place editing
commit 5c89db55b80370e85f35afa26b95cb2eb7e8efab
Date: Thu Jun 27 12:49:55 2019 +0800
Sketcher: fix missing external geometry during export/import
commit 53093e9cccdfe7eecf656878cb92830e00e40387
Merge: cecb599b00 d7b6d4dba9
Date: Fri Jun 21 12:32:25 2019 +0800
commit 9a566c06b5e5c7ac68ecf9430061a226dd800256
Date: Fri May 31 06:28:00 2019 +0800
Gui: add coinRemoveAllChildren to work around Coin3D bug
See bug description:
https://bitbucket.org/Coin3D/coin/pull-requests/119/fix-sochildlist-auditing/diff
Because of path based rendering (SoFCPathAnnotation) in mouse over
highlight, this bug causes crash more frequently here comparing to
upstream.
All C++ calling of SoGroup::removeAllChildren() is replaced by
Gui::coinRemoveAllChildren(), and python code is fixed by monkey
patching SoGroup.removeAllChildren() in FreeCADGuiInit.py.
commit f8ebbcddb5acd312609f82ededbffa671e54169b
Merge: 647f993148 2a9bd6d0e7
Date: Wed May 22 14:47:08 2019 +0800
commit 3147600a2d5ce3e9b5c3b755503e55d774d13d99
Date: Sun May 19 10:57:39 2019 +0800
App: improve AutoTransaction for better undo/redo
Merge Gui::Command::AutoCommit function into App::AutoTransaction for
auto transaction management. See document in AutoTransaction for more
details.
This patch also makes sure any modification done by any Gui::Command is
undoable/redoable without requiring to modify user code.
commit 77aa17c97cca43de93f8865bb2fa22339165f726
Merge: 262db980be df38102017
Date: Sun May 5 14:35:09 2019 +0800
Merge upstream/master into LinkMerge
commit 58a3b25b0dc584e7631da3e64eb7dba54bc7f1b3
Date: Thu Apr 25 11:38:42 2019 +0800
Sketcher: fix constraint expression
Fixes #11
commit 917a881efdb35ed6ad3593a9ed4ec4dea7347b19
Date: Thu Apr 25 11:38:20 2019 +0800
Sketcher: selection sync of constraint task panel
commit 556821135d4c3d13dd8488cefce37a0178768716
Date: Mon Apr 22 08:46:35 2019 +0800
Property: add new API getPyPathValue()
To prepare for switching Expression internal calculation to Py::Object.
commit 1204593d8070ef07b2a61428311cbc674d0b80f9
Date: Sun Apr 14 20:54:32 2019 +0800
Expression: move comment into Expression
The comment is previous available through
PropertyExpressionEngine::ExpressionInfo. However, this field is not
really exposed to end-user at the moment. This patch moves the comment
field into Expression. The plan is to use this field to store meta
information for various PropertyExpressionContainer, through its API
get/setExpressions().
One use case will be implemented in the following commit which
store/restore spreadsheet cell meta information, such as style, alias,
etc.
commit 99da55178cc846f82c952ca499bc785ed74b243f
Date: Fri Mar 29 17:02:15 2019 +0800
Sketcher: fix undo/redo when editing constraint expression
Fixes realthunder/FreeCAD_Assembly3#207
commit f670d46f2d1255867b3330052496894cf9ff7a23
Date: Sat Mar 9 10:18:52 2019 +0800
Sketcher: fix crash on deleting element in task panel
Fixes realthunder/FreeCAD_Assembly3#199
commit 5122d611b055099b99506c6ac756111eddc3397f
Date: Fri Feb 1 21:30:47 2019 +0800
Sketcher: disable signal on slotElementsChanged()
commit 23826fe06bf1ab95054ddf7a8a4faa93160da4bf
Date: Fri Feb 1 21:30:30 2019 +0800
Sketcher: fix potential crash on updateColor()
commit e782f5e79e9cc3e6deba4579aec85d31aafd634b
Date: Mon Jan 28 11:42:10 2019 +0800
Sketcher: allow undo sketch recompute after editing
commit 001dc41a6cdfde0c71fe239df22c4853f8d85258
Date: Sat Jan 26 17:17:37 2019 +0800
Sketcher: fix update driving constraint when not auto update
Fixes realthunder/FreeCAD_Assembly3#175
commit 9ad61c89ed87cdd283b746d661c49e11f9be79a9
Date: Sat Jan 26 16:46:40 2019 +0800
Sketcher: fix ViewProviderSketch double click handling
Fixes realthunder/FreeCAD_Assembly3#176
commit 7955d7ca5ebb1bc381979d322fe04879efb57af3
Date: Fri Jan 18 20:44:27 2019 +0800
Sketcher: fix missing signalElementsChanged on external geometry change
commit 362441873b984a4f169fd430f989aee1016a337e
Date: Wed Jan 9 07:30:24 2019 +0800
Sketcher: fix SketchExport command
commit 0cb1f4bacdda9df7488f160ad5a8a2809bf90ed4
Date: Tue Jan 8 14:18:12 2019 +0800
Command: add TriggerSource to handle checkable action
Current implementation of Command has trouble syncrhonize the checked
status with checkable action, becuase the command can either to
triggered from Python code or Qt UI. And for ActionGroup it can also be
triggered from a child action. This commit introduces the TriggerSource
as an additional argument to Command::invoke() to help the command
logic syncrhonize checked state, in the form of a helper function
Command::setupCheckable(). See PythonGroupCommand::activated() for an
example usage.
commit ca371d11271a4e7415adcce2a26f1b3aa823cb0f
Date: Thu Jan 3 12:28:57 2019 +0800
Sketcher: fix non-undoable change when editing
commit eaa2d93c0dd0db2e7e2f650e2df8071621f5e5e6
Date: Wed Jan 2 19:33:45 2019 +0800
Sketcher: fix toggleConstructions()
commit 0a41512e62ae42b37876093df0ef158753f1cd76
Date: Wed Jan 2 19:33:22 2019 +0800
Sketcher: sync element selection in TaskSketcherElements
commit 66f482ef6bdc245ac8b92e568eacd46fb2467eae
Date: Fri Dec 28 14:58:49 2018 +0800
Sketcher: add commend for auto fixing geometry reference
commit 911597cb6d5122a0dadcc0d1bf947b529ae47783
Date: Fri Dec 28 14:56:36 2018 +0800
Sketcher: fix preselection highlight for external geometry
commit b6711bc1cc4eb426df680cfb9a0d512e660a92a4
Date: Tue Dec 25 21:01:45 2018 +0800
ViewProviderSketch: fix missing commitCommand on drag constraint
commit 1de7f47a5a355242573d2135a5ec3c8ac8b4cafa
Date: Tue Dec 25 21:03:31 2018 +0800
Sketcher: fix migrating of older skech
commit 7e58e9cffec2b6575c084805d9342383e2d1688d
Date: Tue Dec 25 21:02:22 2018 +0800
Sketcher: fix TaskSketcherElements highlight of external element
commit b2bba4cef9512df649ad8141988606f1cf741245
Date: Tue Dec 25 12:17:05 2018 +0800
Sketcher: change axis geometry ID to avoid conflict
commit d298939986c2f6cc5af5f80655f0182f3d97125b
Date: Mon Dec 24 18:27:28 2018 +0800
Sketcher: fix external geo ref update
commit 6fb24f438c831f09201ad6d55477be8b1ebe671c
Date: Wed Dec 19 18:17:26 2018 +0800
Sketcher: refactor external geometry handling
External geometries are now persisted into files, and can be
* defining, for building shape,
* frozen, do not update while external object
* detached, do not associated to any external object
* re-attached, change the associated external geometry element
Missing of any external reference no longer silently delete all
associated constraints. Instead, the error will be explicitly shown to
user, and all geometry and constraints remain intact. The user can
decide whtether to detach or re-attach the external geometry.
Fixes realthunder/FreeCAD_Assembly3#76
commit 5c6272dd25e41bfb7585344bd9ea9e5c555f1205
Date: Wed Dec 19 18:17:12 2018 +0800
Sketcher: add some icons
commit 52718c851c7c3d3ddfa1bebe6595c6a0fa85b394
Date: Fri Dec 21 07:21:27 2018 +0800
Sketcher: fix PropertyConstraintList undo
Fixes realthunder/FreeCAD_Assembly3#166
commit 5c2f01826312a00bfaff2edbfaaca7a290fcb2f0
Date: Thu Dec 13 17:04:21 2018 +0800
Improve error message
commit 11931cf870e2ebdab4e16a8201763f524aab6292
Merge: 45d9defdbf 73df4e6fc0
Date: Sun Nov 25 17:44:36 2018 +0800
Merge upstream master into LinkMerge
commit 9d0c3339a9a0f00cd9bc07b8f6cee315906e2acf
Date: Mon Nov 5 17:15:06 2018 +0800
App: replace boost::any with stx::any for performance
Mostly for small body optimization, as boost::any uses dynamic
allocation to hold any data inside. See src/App/stx/any.hpp
Original implementation from
https://github.com/thelink2012/any
With modification from
https://github.com/tcbrindle/cpp17_headers
commit 3008b30596ad1ed9a63db199f0c377bd949f3968
Date: Mon Nov 5 16:27:45 2018 +0800
Expression: refactor for better performance
* Remove raw pointer usage in Expression, replace with std::unique_ptr,
and enforce C++ move symantics on expression construction.
* Use boost::pool_allocator to improvate memory allocation speed.
* Use (a patched) bison C++ parser for performance and exception safty
* Remove all Python interpreter useage, use Python API directly instead.
commit 6af8bcec1e55d0e5829bb239e4f8b593cbb6efce
Date: Mon Oct 8 07:36:47 2018 +0800
Details will be documented at
https://github.com/realthunder/FreeCAD_assembly3/wiki/Expression
commit 04ccbe4b5bf30a63d03c81811100d46f3034e584
Merge: 63dd5552a5 052d8a70e9
Date: Wed Sep 12 14:24:02 2018 +0800
Merge branch 'upstream/master' into LinkMerge
commit 2c0a8deea1b96c649070c7bc8b680f45c82017fa
Date: Fri Sep 7 16:33:54 2018 +0800
SketchExport: fix update problem
commit 6921476dfed8de7c4e4192a902924e58c5ac853f
Date: Sat Sep 1 13:30:04 2018 +0800
ViewProviderSketch: filter external object in onSelectionChanges()
commit f9b8048d863ea79e51d5bdc4f8fdd8f4c21e22c8
Date: Mon Aug 20 10:59:16 2018 +0800
Use the new ObjectIdentifier constructor to reduce ambiguity
All modifications uses ObjectIdentifier to capture the path of its own
property. The new ObjectIdentifier explicitly sets the document object
name as the owner name to avoid runtime resolving ambiguity where there
is an object with same name as the property.
commit d5685b8f19aa97c25f37ee2d72cf032712424ad3
Merge: 9374feae10 123e9d210d
Date: Mon Aug 6 16:08:07 2018 +0800
commit 960e63fa0518362c51823214ee842ed522a35b1e
Merge: 05453c6c04 8ef330d19a
Date: Mon Jul 30 16:30:38 2018 +0800
commit dc940ca3b3dc839045f4fc0a2665655d9875355c
Merge: c14743cf07 ab1520b872
Date: Sat Jun 30 17:17:01 2018 +0800
commit 7b636f5c8ab8dc922f5959fe9605113aad6d6fd7
Merge: 99ae7ede21 e49a5af3ae
Date: Sat Jun 2 11:33:34 2018 +0800
commit 6599d8e6ef215eb76fef29513a961bfefbae2faa
Date: Wed Apr 25 17:43:29 2018 +0800
Sketcher: add command to swap geometry ID
commit ad52d35284472ac36d1254c672ccf6b166fe1792
Author: Abdullah Tahiri <abdullah.tahiri.yo@gmail.com>
Date: Tue Mar 27 07:06:09 2018 +0200
Sketcher: Bug fix - prevent inter part/body links
With the support for external geometry during carbon copy, it was introduced a way for creating inter-part/inter-body links. See:
https://forum.freecadweb.org/viewtopic.php?f=10&t=27700&p=223736#p223736
This commit closes this door, while still allows carbon copy with external geometry support within the same body.
commit 075b1104f35e4edd913444f4fd9c12262109c8ca
Author: Yorik van Havre <yorik@uncreated.net>
Date: Mon Mar 26 18:52:02 2018 -0300
Merged translations from crowdin
commit c1f773491ea357a63832d923ceda6c345bf94f01
Date: Sun Apr 15 17:43:13 2018 +0800
SketchObject: fix for the new TopoShape naming scheme
ommit 2996a076422fb9b2312ee2660e6d20b1bf12ac9f
Date: Thu Apr 12 19:26:24 2018 +0800
TopoShape: remove appendTag argument in all maker API
Auto decide when to insert tag in TopoShape::processName.
Fixed getRelatedElements() for the new naming scheme.
commit 18bd442c38df803b154f63f7ab3c70bd3f0cc432
Date: Sat Apr 7 08:09:04 2018 +0800
Sketcher: explicitly use shadow subname in external geometry
commit 833a0d4b56feab6d3269d1548cd55e42cca7aa11
Merge: 76593a0e44 f5bd719a6d
Date: Mon Mar 26 18:03:47 2018 +0800
commit 752d0dee28e67623529cbd5472cdf010156f7948
Date: Tue Mar 13 06:45:20 2018 +0800
Sketcher: fix vertex export
commit efbea6fe92847c1a86a9341b02008f7ebe4fffa6
Date: Sun Mar 11 09:17:47 2018 +0800
Sketcher: change element mapping op code
commit b7b9031fda1a383671c69ae1adbedb2dddc11711 (tag: asm3-0.3)
Date: Tue Mar 6 07:48:48 2018 +0800
Sketcher: fix SketchObject getSubObject
commit 7cf0beb6c024fd0cb3739de843d7ccafc6de8035 (realthunder/LinkDevMerge)
Merge: 0a95adbd72 f189c95984
Date: Mon Mar 5 16:25:45 2018 +0800
Merge remote-tracking branch 'upstream/master' into LinkDev
commit c7f9858f9e9ed3109f8ce6b976401c028be3551f
Date: Wed Feb 28 20:19:31 2018 +0800
Sketcher: migrate sketch to new element map framework
commit 2ddd4b44b900ff718b856ac54d9f99f31e091087
Date: Sat Feb 24 10:29:24 2018 +0800
Sketcher: add geo history to resuse deleted geo id
The behavior is controlled by the following parameter:
BaseApp/Preferences/Mod/Sketcher/GeoHistoryLevel
0 : disable,
1(default) : reuse id only if the new geometries's both start and end
points matches some deleted geometry,
2 : resuse id when either start or end points matches some
deleted geometry.
It works like this. The sketch object will keep an adjacency list of
each existing geometries. Every time the geometry changes, a new
boost::geometry::retree is built based on existing vertex positions. The
adjacency list is updated while the rtree is built. The list will
sychronize the adjacency id list of all existing geometry, but keep any
delete geometry id unchanged.
When new geometry is created, sketch object will query the rtree based
on the start and end points of the new geometry, and try to find any
deleted geometries id's that are connected to the same existing
geometries that owns the hitting points, and reuse its id.
The net effect is that, say, when you delete an edge in a square, and
replace it with a bspline, the bspline will have the exact same id as
the deleted line. So, if you only delete and replace one edge at a
time, you can change the type of all edges while keeping the same id's.
Moving points during the process will not have any negative effect.
commit 5fc101b3290555faeec8adb5081e92e38cc9c387
Date: Sat Feb 17 09:52:25 2018 +0800
Sketcher: add support for sketch exports
SketchObject now use the new TopoShape element name mapping to expose
mapped geometry topological names during editing. SketchExport exports
the editing geometry using those mapped names.
The SketchExport acts just like SketchObject to the end-user, except
that you can't directly edit its content. Instead, when you double
click a SketchExport, it forwards the editing request to its parent
SketchObject, and then pre-selects the exported geometries. You can
then changed the export by selecting/removing geometries.
The SketchExport is a Part2DObject, meaning that it can be mapped onto
other faces, independent of its parent SketchObject. If no mapping,
then it follows the parent SketchObject placement. If mapped, when you
double click to edit the SketchExport, it will start editing the parent
SketchObject in the placement of the SketchExport.
commit ca9ae3c897ffa5260009fe40b88318a087a0c8a0
Date: Fri Feb 9 13:00:01 2018 +0800
Sketcher: getSubObject support for internal geometries
When editing, the selected sub-element name will be appended with '_' to
tell SketchObject::getSubObject() that the element is referring to
internal geometry. This makes it possible to retrieve the shape of
internal geometries, such as constructions or external geometries.
This patch also explicitly set the editing document, object and subname
when doing selection in 3D view. Because of the support of in-place
external editing, the editing may originated from various child/link
inside some container. This patch makes sure that during editing,
selection in 3D view will cause TreeView to select the correct item.
Note, there is no support for enhanced selection from other source
during editing yet, e.g. from various commands or task panels.
commit f405cbcfb65f681366cf4ff09518cc4b95d19c99
Date: Sat Feb 3 17:02:51 2018 +0800
Remove .orig files added during merge
commit 0daa959650c4bd7454207bd561441dcaa47b58ef
Merge: a5ce0b7d71 bb39cc783a
Date: Thu Feb 1 16:27:30 2018 +0800
Merge upstream/bb39cc78 into LinkDev
commit 0ae792076681c53e4e6038499fd022bc0d066612
Merge: 88e940143c 2c69b79c15
Date: Tue Jan 9 16:23:24 2018 +0800
Merge upstream 2c69b79c15623a2dd1314f3830921822c8dc07c1
commit 83ecc94604b8ca183f44407188a01a03311a95b0
Date: Wed Dec 27 18:20:30 2017 +0800
Sketch: fix external editing
commit 8c10ed790417a7f769d6718fd554a821eda7a24e
Merge: e08f252c4c c54c08cca4
Date: Wed Dec 13 16:17:23 2017 +0800
Changes against Link branch to conform with upstream master:
* Document::recompute() no longer throw exception on cyclic dependency,
but callss DocumentP::partialTopologicalSort() to do the sort.
* PropertyContainer no longer treat DynamicProperty with Prop_ReadOnly
as Python read only attribute. Static property still does.
commit 478e64348ba845f4c1a9f54cff3b6ac7e95a86a0
Merge: 47eef5c3a4 b01c503c2c
Date: Sun Nov 12 01:33:58 2017 +0800
Merge upstream/master b01c503c into Link branch
commit ea882f5d9c427f409859a90a627c0cabb297fa91
Date: Mon Oct 16 11:27:57 2017 +0800
ViewProviderSketch: multi-placement editing support
Demonstrate how to support editing the same object in difference
placements, and possibly, different documents.
Thing to watch for:
* Do not use ActiveDocument, instead, use the object's owner document in
case the editing happens in a different document. Or, use
Gui::Application::editDocument() to access the editing document's
viewer.
* Make sure undo/redo is done through the object's owner document,
which may be different from the editing document.
TODO: current UI cannot show foreign document undo/redo when editing
externally linked object.
commit 05631137f44ab46c5d9f2c9041330f7fa37f848a
Merge: f6fc75addb 2751a3e847
Date: Wed Aug 30 13:33:22 2017 +0800
Merge remote-tracking branch 'upstream/master' into LinkStage1
I have fast read most of the first 20 commits and several of the rest.
There are several aspects that make integrating changes a daunting effort:
- The code of certain functionalities depends on changes outside the Sketcher module (e.g. App/DocumentObject, Part::TopoShape), not currently present in master. Some of these decisions were reverted several times over the LinkStage3 development and are no longer part of LinkStage3. Some others yet, most importantly on Part::TopoShape for the functionality we trying to integrate, are simply not in master yet (examples below).
- The code includes some design decisions that may require a wider discussion because of its impact, for example, the code relating to in place editing from another document (e.g. LinkStage3 commits ea882f5d9c427f409859a90a627c0cabb297fa91 (multiplacement editing support), 83ecc94604b8ca183f44407188a01a03311a95b0 ( Sketch: fix external editing)).
In order to grasp the most important hinderings, I have done the exercise of cherry-picking some basic important commits from the begining that would impact the functionalities of Export, Toponaming and Defining External geometry, so I have basically cherry-picked those on top of the geometry extensions development, for the interested this branch.
In that branch every commit compiles (but it is not functional, some parts do work).
Each cherry-pick involved adapting the extensions part and substantially looking for changes in LinkStage3 development, as several decisions affecting src/App evolved over time and were later reverted, I commented out the code involved in these cases.
Summary of operations:
→ Cherry-picked: ca9ae3c897ffa5260009fe40b88318a087a0c8a0 (Sketcher Subobject support)
→ Cherry-picked: 5fc101b3290555faeec8adb5081e92e38cc9c387 (Sketcher Export)
- Several functions that were afterwards removed commented out compiles but it is not functional.
→ Cherry-picked: 2ddd4b44b900ff718b856ac54d9f99f31e091087 (geohistory)
- Commented out code for the same reason above.
→ Cherry-picked: c7f9858f9e9ed3109f8ce6b976401c028be3551f ( Sketcher: migrate sketch to new element map framework)
→ Cherry-picked: b7b9031fda1a383671c69ae1adbedb2dddc11711 ( Sketcher: fix SketchObject getSubObject)
→ Cherry-picked: efbea6fe92847c1a86a9341b02008f7ebe4fffa6 ( Sketcher: change element mapping op code)
- Commented out code for the same reason above, and specially because of non-existing functions in Part::TopoShape()
- Missing TopoShapeOpCode.h
→ Cherry-picked: 752d0dee28e67623529cbd5472cdf010156f7948 ( Sketcher: fix vertex export)
- Missing Part::TopoShape().makEWires(shapes,TOPOP_SKETCH)
Aside from the fact that replaying commits on top of master may not be the best strategy due to all changes involved, the lack of convergence of TopoShape between LinkStage3 and master might be a major obstacle at the present. To be honest I do not have an idea of how far away from master TopoShape currently is. I have looked into changes in Part using git as above, and I got again a long list of commits.
Way forward
This massive integration requires not only wide-knowledge of FreeCAD code base, but also knowledge about LinkStage3 and its design decisions. Looking into all the TopoShape code for differences is going to take me a considerable amount of time, as I am not familiar with this part of FreeCAD.
