Result Object > Show Results
First time I view the Result Object I get random results (variable initiation issue?), which can be corrected by switching back and forward between result type (second attachment):
OS: Windows 10
Version: 0.18.15187 (Git)
Hash: 04005b5e452a7b8624f2aeac5180787d4f6a88fa
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
Locale: English/Denmark (en_DK)
PS: the results may not be that random. Have a close look at the result panel. The digits are the same, but out by several powers of 10 and the unit is GPa and not MPa
it trys to use the results from last time in the task panel, which may has some bugs. Since I do not use that at all, I implemented a preferece in FEM prefs to deactivate this. Would you gove it a try?
Bernd, I am not entirely sure which preference you mean, but I ticked “Hide Constraints when Opening Result Dialog” and that doesn’t make a difference.
