I have with the AppImage
OS: “openSUSE Leap 42.3”
Version: 0.17.13050 (Git)
Build type: None
Hash: 305a567819522a336bd16a6c694772be2f56af47
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
several problems with the precision which are resulting in several errormessages if i try to crate a path.
First thing i noticed is to see on this pic:
The part is a ring with 306mm diameter. The Boundbox shows 306mm in lenght but only 305,73mm in with.
With the job for this object, some operations work, some not. E.g.: if i try to get a Path from Edge operation, i got this error messages:
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 99, in setEdit
self.setupTaskPanel(TaskPanel(vobj.Object, self.deleteObjectsOnReject(), page, selection))
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 108, in setupTaskPanel
panel.setupUi()
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 882, in setupUi
self.panelSetFields()
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 859, in panelSetFields
page.pageSetFields()
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 211, in pageSetFields
self.setFields(self.obj)
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 645, in setFields
self.updateSelection(obj, FreeCADGui.Selection.getSelectionEx())
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 693, in updateSelection
if self.selectionZLevel(sel) is not None:
File "/tmp/.mount_FreeCAVzrO70/usr/lib/freecad-daily/Mod/Path/PathScripts/PathOpGui.py", line 683, in selectionZLevel
if PathGeom.isHorizontal(sub):
<type 'exceptions.AttributeError'>: 'module' object has no attribute 'isHorizontal'
