As Debian 12 does not provide PySide6 package, I installed it using pip. It seems there is some support for that since 2f7be9e782b0 (“cMake: Add support for compiling against Qt6 (#7647)”), but it ends this way:
CMake Warning (dev) at cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:195 (set):
Cannot set "Shiboken6_INCLUDE_DIRS": current scope has no parent.
Call Stack (most recent call first):
cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:46 (find_pip_package)
CMakeLists.txt:82 (SetupShibokenAndPyside)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:196 (set):
Cannot set "Shiboken6_LIBRARIES": current scope has no parent.
-- Found pip-installed Shiboken6 in /usr/local/lib/python3.11/dist-packages/shiboken6
Cannot set "PySide6_INCLUDE_DIRS": current scope has no parent.
cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:61 (find_pip_package)
Cannot set "PySide6_LIBRARIES": current scope has no parent.
-- Found pip-installed PySide6 in /usr/local/lib/python3.11/dist-packages/PySide6
-- Found PYSIDE6 tools: /usr/lib/qt6/libexec/uic, /usr/lib/qt6/libexec/rcc
CMake Warning at cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:119 (message):
Shiboken6 include files not found, FREECAD_USE_SHIBOKEN automatically set
to OFF
CMake Warning at cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake:147 (message):
PySide6 include files not found, FREECAD_USE_PYSIDE automatically set to
OFF
-- PySide 6.6.1 Python module found at /usr/local/lib/python3.11/dist-packages/PySide6.
Since it sits in the repository for quite a long time, there’s a good chance I’m doing something wrong. Here’s patch that works for me:
--- a/cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake
+++ b/cMake/FreeCAD_Helpers/SetupShibokenAndPyside.cmake
@@ -45,9 +45,9 @@ macro(SetupShibokenAndPyside)
if(NOT SHIBOKEN_INCLUDE_DIR)
find_pip_package(Shiboken${SHIBOKEN_MAJOR_VERSION})
if (Shiboken${SHIBOKEN_MAJOR_VERSION}_FOUND)
- set(Shiboken_INCLUDE_DIR ${Shiboken${SHIBOKEN_MAJOR_VERSION}_INCLUDE_DIRS})
- set(Shiboken_LIBRARY ${Shiboken${SHIBOKEN_MAJOR_VERSION}_LIBRARIES})
- set(Shiboken_FOUND TRUE)
+ set(SHIBOKEN_INCLUDE_DIR ${Shiboken${SHIBOKEN_MAJOR_VERSION}_INCLUDE_DIRS})
+ set(SHIBOKEN_LIBRARY ${Shiboken${SHIBOKEN_MAJOR_VERSION}_LIBRARIES})
+ set(SHIBOKEN_FOUND TRUE)
endif()
endif()
@@ -60,9 +60,9 @@ macro(SetupShibokenAndPyside)
if(NOT PYSIDE_INCLUDE_DIR)
find_pip_package(PySide${PYSIDE_MAJOR_VERSION})
if (PySide${PYSIDE_MAJOR_VERSION}_FOUND)
- set(PySide_INCLUDE_DIR ${PySide${PYSIDE_MAJOR_VERSION}_INCLUDE_DIRS})
- set(PySide_LIBRARY ${PySide${PYSIDE_MAJOR_VERSION}_LIBRARIES})
- set(PySide_FOUND TRUE)
+ set(PYSIDE_INCLUDE_DIR ${PySide${PYSIDE_MAJOR_VERSION}_INCLUDE_DIRS})
+ set(PYSIDE_LIBRARY ${PySide${PYSIDE_MAJOR_VERSION}_LIBRARIES})
+ set(PYSIDE_FOUND TRUE)
endif()
endif()
@@ -192,9 +192,9 @@ macro(find_pip_package PACKAGE)
endforeach()
file(TO_NATIVE_PATH "${PIP_PACKAGE_LOCATION}/${PIP_PACKAGE_NAME}/include" INCLUDE_DIR)
file(TO_NATIVE_PATH "${PIP_PACKAGE_LOCATION}/${PIP_PACKAGE_NAME}/lib" LIBRARY)
- set(${PACKAGE}_INCLUDE_DIRS ${INCLUDE_DIR} PARENT_SCOPE)
- set(${PACKAGE}_LIBRARIES ${LIBRARY} PARENT_SCOPE)
- set(${PACKAGE}_FOUND ${LIBRARY} TRUE)
+ set(${PACKAGE}_INCLUDE_DIRS ${INCLUDE_DIR})
+ set(${PACKAGE}_LIBRARIES ${LIBRARY})
+ set(${PACKAGE}_FOUND TRUE)
message(STATUS "Found pip-installed ${PACKAGE} in ${PIP_PACKAGE_LOCATION}/${PIP_PACKAGE_NAME}")
endif()
endmacro()
Is anyone using pip installed PySide6? @chennes, does above make sense to you? I do not know much about cmake nor the usual ways of detecting packages.
