Downloaded the macOS arm build a couple days ago and cannot load the Path Workbench. It appears the libgcc library is missing from the package and numpy fails to load. I tried to import numpy separately using the console and this is the error message:
Python 3.10.5 | packaged by conda-forge | (main, Jun 14 2022, 07:09:13) [Clang 13.0.1 ] on darwin
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_Workbench',10)
>>> Gui.runCommand('Std_ViewStatusBar',1)
>>> import numpy
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/__init__.py", line 23, in <module>
from . import multiarray
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/multiarray.py", line 10, in <module>
from . import overrides
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/overrides.py", line 6, in <module>
from numpy.core._multiarray_umath import (
ImportError: dlopen(/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-darwin.so, 0x0002): Library not loaded: '@rpath/libgcc_s.1.1.dylib'
Referenced from: '/Applications/FreeCAD.app/Contents/Resources/lib/libgfortran.5.dylib'
Reason: tried: '/Applications/FreeCAD.app/Contents/Resources/lib/libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/lib/libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/lib/libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/../../../../libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/../../../../libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/lib/libgcc_s.1.1.dylib' (no such file), '/Applications/FreeCAD.app/Contents/Resources/bin/../lib/libgcc_s.1.1.dylib' (no such file), '/usr/local/lib/libgcc_s.1.1.dylib' (no such file), '/usr/lib/libgcc_s.1.1.dylib' (no such file)
During handling of the above exception, another exception occurred:
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/__init__.py", line 140, in <module>
from . import core
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/__init__.py", line 49, in <module>
raise ImportError(msg)
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.10 from "/Applications/FreeCAD.app/Contents/Resources/bin/freecad"
* The NumPy version is: "1.23.2"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: dlopen(/Applications/FreeCAD.app/Contents/Resources/lib/python3.10/site-packages/numpy/core/_multiarray_umath.cpython-310-darwin.so, 0x0002): Library not loaded: '@rpath/libgcc_s.1.1.dylib'
OS: macOS 12.5
Version: 0.21.30138 (Git)
Hash: f5c5eec3bbe6cf1499d34d292d154d48e6285c0f
Locale: C/Default (C)
* ThreadProfile 1.81.0
* kicadStepUpMod 10.12.4
* Curves 0.4.4
