For a while we’ve been struggling with an ever growing python module incorporating all of Path in a flat structure. This makes it hard for newcomers to “get into” the code base and figure out how this is supposed to work. It also makes it quite easy to introduce cyclic dependencies in the modules which then cause problems later on. We’ve restructured the entire code base into sub modules and pulled all elements of the Path code into a single namespace in PR-7440.
Why would any none developer care?
Due to how FreeCAD stores its objects in the “.FCStd” file the data file is inherently tied to the implementation. If the implementation changes and FreeCAD can’t find the class which was used to create an element before it got saved then FreeCAD cannot process that data. In other words, once the change is merged it will break all existing Path files.
This is also the reason why we have to make this change now, before version 1.0 is released. With version 1.0 backwards compatibility becomes a priority and a cleanup like this will become much more complicated.
ToolBit’s are not affected by this change. Any created and existing ToolBit files will still work after the merge.
Yep, this is going to break a lot of stuff, make a lot of people mad, and affect both users and other developers.
Let’s do it!!
and any other power users. If you’re able to build from the PR, please do so and start keeping notes so we can write a migration guide or other instructions to users. Migration pain is going to affect us for a long time so we should probably get good at answering it.
I had started to take those out, but then ppl have added it back in - for a developer it’s really handy to change a single line and turn on/off internal debugging. I’ll keep in mind though if I come across a better pattern.
As pointed out above the change is rather dramatic. No sense in adding to master until it is quite thoroughly debugged at the PR level.
I have taken a first look. In general it seems to work pretty well for new Path WB jobs, but completely fails to handle existing jobs. They are not even recognized. I do not know if that can be fixed in any way or if some sort of converter might be possible, but that is why the testing period on the PR exists.
I don’t know how to do this “test at PR level” and for now it is only an informative questions, as I can’t compile FC with my limited power (Intel i3-2100) machine.
I was thinking that it will be as easy as making a git pull and a recompile, but in this case the PR has to be merged in “main branch”.
Probably I’m lacking ability to make a goo use of GitHub in complex projects.
There is maybe a dedicated “branch”?
Could you kindly explain me “how to do eventually” such thing, to keep note maybe in future when I could afford a more powerful machine.?
I actually tried that first. I simply replaced everything in Mod/Path. It did not work because there are some hooks back into the FreeCAD core that need to be recompiled.
Most of the Path WB source is python, but there are some important C++ portions as well.
I don’t know if a more intelligent approach would work.
The issue was that I could not move the C++ and the Python backed classes into a single namespace without moving the C++ somewhere else first. So unfortunately a recompile is required.
For nerds:
The C++ classes now publish their python bindings in the module “PathApp”. The “Path” namespace is now a pure python module which, upon it being imported, imports everything from the “PathApp” module which puts the C++ objects back where they were.
I found a couple small bugs and mlampert fixed them immediately. Gene found some issues with surface and those were fixed too. Otherwise this has not gotten much comment. So I’m assuming it’s all good.
I’ll be merging this as soon as mlampert gives me the final go-ahead.
If anyone has concerns, speak now or forever hold your peace.
Updated FreeCAD via the in program updater and am assuming this includes the recent merge of the code restructuring.
On opening my most recent project the result is as referenced in Gene’s earlier post.
The directory tree structure has exploded, most branch links are broken although some Operations still have some members.
Access to items in Gui is mostly non existent , but using Python Console via Python dot scope shows contents still valid.
ReportView on initial opening of file:
07:45:09 Recent macros : keyboard shortcut 1 disabled because conflicting with Std_ViewFront
07:45:09 Recent macros : keyboard shortcut 2 disabled because conflicting with Std_ViewTop
07:45:09 Recent macros : keyboard shortcut 3 disabled because conflicting with Std_ViewRight
07:45:15 Traceback (most recent call last):
File "/tmp/.mount_FreeCA0EhgPR/usr/lib/python3.10/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJob'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheet'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathStock'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBit'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolController'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathCustom'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDressupHoldingTags'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDrilling'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathPocketShape'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSurface'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathProfile'
07:45:16 Traceback (most recent call last):
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJobGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheetGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathIconViewProvider'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBitGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolControllerGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathOpGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathDressupTagGui'
As mentioned earlier, the refactor breaks all existing Jobs. You’ll have to delete all Jobs, their operations and associated objects and create the anew.
