Hi everyone,
I’m opening a file created in 0.20.2 that has a path from the path workbench. When I open the same file in a newer version (0.21.1) the file does not open the same way and seems like it doesn’t get parsed correctly and the tree is all messed up. I’ve attached some files and screenshots. Any help is appreciated. Not sure if this is a bug or if I’m missing something. I use the path workbench quite a bit, and having to redo all of my files to the new version will be quite some work for me.
Thanks again,
Michael.
Look at the first two pinned topics in this sub-forum, just below the announcements and just above your post!
The announcement of breaking changes: Path Workbench Code restructuring - heads up
JobFixerMacro: Code Restructuring - JobFixer Script
Much appreciated, exactly what I needed. I’ll read through those, thanks again for the help!
-Michael.
