MacOS version 500 commits late?
Hmm, it worked on my mini. Maybe caused by a external module…
I have by a lucky coincidence an identical MacMini here. Alas, I have no powercable and have to tinker something (more or less dangerous) for the special plug. I will report back later.
first, can you clarify what you mean by 'automatic way?
do you need a method to update or do you need a hosting place to update to?
Ok I finally managed to compile FreeCAD from your first instructions (not tried the new ones). I first created a freecad environment then configured OSX to use the the MacOSX 10.9 SDKs: installation into /opt +conda_build_config.yaml. According to the errors in the build, the build system was still looking for the 10.9 SDKs in the XCode application (/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/), but as I am running 10.14, those SDKs don’t exist by default. I created there a simlink in the application to /opt. Then I could compile.
I will try your new instructions to see if they work properly.
Question: why 10.9 SDKs? Is FreeCAD able to compile with 10.14 ones and if yes, where do I have to change the dependency?
Cheers
JMB
PS: I am interested to build the sources, because I am a software engineer and I am interested to see if I can help to improve FreeCAD.
I get (almost) the same error on the MacMini:
localadmins-Mac-mini:Desktop localadmin$ FreeCAD.app/Contents/MacOS/FreeCAD
FreeCAD 0.18, Libs: 0.18R16079 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
FreeCAD.app/Contents/MacOS/FreeCAD: line 3:   756 Abort trap: 6           $script_dir/Resources/bin/FreeCAD $@
Hope this helps: the log file talks about cocoa missing.
Msg: FreeCAD 0.18, Libs: 0.18R16079 (Git)
Log: Time = Sat Mar  9 14:42:54 2019
Log: AppDataSkipVendor = true
Log: AppHomePath = /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/
Log: AppIcon = freecad
Log: AppTempPath = /var/folders/g6/gndxh1551rq72dn3hc8dm0vc0000gn/T/
Log: BinPath = /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/bin/
Log: BuildRepositoryURL = https://github.com/FreeCAD/FreeCAD master
Log: BuildRevision = 16079 (Git)
Log: BuildRevisionBranch = master
Log: BuildRevisionDate = 2019/03/08 17:56:16
Log: BuildRevisionHash = 6363c90a20b296ab69d7b52230009928199d90df
Log: BuildVersionMajor = 0
Log: BuildVersionMinor = 18
Log: Console = 0
Log: CopyrightInfo = © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Log: Debug = 0
Log: DocPath = /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/doc/
Log: ExeName = FreeCAD
Log: ExeVendor = FreeCAD
Log: ExeVersion = 0.18
Log: LoggingFile = 1
Log: LoggingFileName = /tmp/fc.log
Log: MaintainerUrl = http://www.freecadweb.org/wiki/Main_Page
Log: PATH = /usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin
Log: PYTHONPATH =
Log: PythonSearchPath = /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/lib/python37.zip:/Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/lib/python3.7:/Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/lib/python3.7/lib-dynload
Log: RunMode = Gui
Log: SplashAlignment = Bottom|Left
Log: SplashInfoColor = #c8c8c8
Log: SplashScreen = freecadsplash
Log: SplashTextColor = #ffffff
Log: StartWorkbench = StartWorkbench
Log: SystemParameter = /Users/localadmin/Library/Preferences/FreeCAD/system.cfg
Log: UserAppData = /Users/localadmin/Library/Preferences/FreeCAD/
Log: UserHomePath = /Users/localadmin
Log: UserParameter = /Users/localadmin/Library/Preferences/FreeCAD/user.cfg
Log: Verbose =
Log: Create Application
Log: Run App init script
Log: Init: starting App::FreeCADInit.py
Log: Init:   Searching for modules...
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/AddonManager... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Arch... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Complete... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Draft... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Drawing... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Fem... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Idf... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Image... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Import... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Inspection... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Material... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Measure... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Mesh... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/MeshPart... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/OpenSCAD... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Part... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/PartDesign... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Path... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Points... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Raytracing... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/ReverseEngineering... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Robot... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Show(Init.py not found)... ignore
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Sketcher... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Spreadsheet... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Start... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Surface... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/TechDraw... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Test... done
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Tux(Init.py not found)... ignore
Log: Init:      Initializing /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Web... done
Log: Using /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod as module path!
Log: System path after init:
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/bin
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/AddonManager
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Arch
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Complete
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Draft
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Drawing
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Fem
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Idf
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Image
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Import
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Inspection
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Material
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Measure
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Mesh
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/MeshPart
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/OpenSCAD
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Part
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/PartDesign
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Path
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Points
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Raytracing
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/ReverseEngineering
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Robot
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Show
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Sketcher
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Spreadsheet
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Start
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Surface
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/TechDraw
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Test
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Tux
Log:    /Users/localadmin/Desktop/FreeCAD.app/Contents/Resources/Mod/Web
Log:    /usr/bin
Log:    /bin
Log:    /usr/sbin
Log:    /sbin
Log:    /usr/local/bin
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: This application failed to start because it could not find or load the Qt platform plugin "cocoa"
in "".
Reinstalling the application may fix this problem.
Ok guys. Now that I was able to build FreeCAD with freecad-feedstock, I got those messages at the end:
TEST END: /Users/jeanmarc/miniconda3/conda-bld/osx-64/freecad-0.18b0-py36h4f6ecc2_41.tar.bz2
Renaming work directory,  /Users/jeanmarc/miniconda3/conda-bld/freecad_1552136826140/work  to  /Users/jeanmarc/miniconda3/conda-bld/freecad_1552136826140/work_moved_freecad-0.18b0-py36h4f6ecc2_41_osx-64_main_build_loop
# Automatic uploading is disabled
# If you want to upload package(s) to anaconda.org later, type:
anaconda upload /Users/jeanmarc/miniconda3/conda-bld/osx-64/freecad-0.18b0-py36h4f6ecc2_41.tar.bz2
# To have conda build upload to anaconda.org automatically, use
# $ conda config --set anaconda_upload yes
anaconda_upload is not set.  Not uploading wheels: []
Resource usage summary:
Total time: 1:15:26.7
CPU usage: sys=0:19:21.5, user=2:36:43.8
Maximum memory usage observed: 1.7G
Total disk usage observed (not including envs): 3.5M
Source and build intermediates have been left in /Users/jeanmarc/miniconda3/conda-bld.
Now the build results seem to be freecad-0.18b0-py36h4f6ecc2_41.tar.bz2. So I suppose I have to extract this archive to find FreeCAD. But now if I start developping, I want to use the build results directly and not beeing obliged to always use an archive.
So 2 questions:
  1. how do you guys work when you compile from the sources and modify them?
  2. I suppose conda-build is only meant for CI integration, correct? Then where can I find the FreeCAD binary before it is bundled?
By the way the content of archive doesn’t work. Not even from the terminal, where the “brew” build worked fine. Still wondering how to make conda properly work on my Mac and build FreeCAD for OS X…
Last login: Sat Mar  9 15:36:18 on ttys001
(base) mac-mini:~ jeanmarc$ /Users/jeanmarc/miniconda3/conda-bld/osx-64/freecad-0.18b0-py36h4f6ecc2_41/bin/FreeCAD ; exit;
dyld: Library not loaded: @rpath/libpython3.6m.dylib
  Referenced from: /Users/jeanmarc/miniconda3/conda-bld/osx-64/freecad-0.18b0-py36h4f6ecc2_41/bin/FreeCAD
  Reason: image not found
Abort trap: 6
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Cheers,
JMB
small mistake at last step should be: conda build . -m .ci_support/osx_python3.7.yaml
I am still no comfortable with conda. Could you please explain what you mean with the create environment with the built package?
conda create freecad-test … --use-local …
Sorry for my stupid questions but I try to get on the train…
thanks for testing.
Maybe this is a problem with absolutepaths. Maybe the appimage-equivalent way of building the package doesn’t work for the mac. I guess it’s best to ask @peterl94 how he did his build.
You have to install it with conda. The archive only contains freecad, but not it’s dependencies… To test it you need to create an environment.
There is no simple way to setup an interactive development environment with conda. I tried it with conda-build (and it also works) but you need a deeper understanding how conda works to do it right.
you are right. This has changed recently.
Please have a look at the basics of conda. I guess it’s the best reference:
https://docs.conda.io/projects/conda/en/latest/user-guide/getting-started.html#managing-environments
Hmmm followed second instructions. Just failed.
(base) mac-mini:freecad-feedstock jeanmarc$ conda build . -m .ci_support/osx_python3.7.yaml
No numpy version specified in conda_build_config.yaml.  Falling back to default numpy value of 1.11
WARNING:conda_build.metadata:No numpy version specified in conda_build_config.yaml.  Falling back to default numpy value of 1.11
Adding in variants from internal_defaults
INFO:conda_build.variants:Adding in variants from internal_defaults
Adding in variants from /Users/jeanmarc/conda_build_config.yaml
INFO:conda_build.variants:Adding in variants from /Users/jeanmarc/conda_build_config.yaml
Adding in variants from .ci_support/osx_python3.7.yaml
INFO:conda_build.variants:Adding in variants from .ci_support/osx_python3.7.yaml
Attempting to finalize metadata for freecad
INFO:conda_build.metadata:Attempting to finalize metadata for freecad
Collecting package metadata: ...working... done
Solving environment: ...working... done
BUILD START: ['freecad-0.18-py37hf00ded6_1000.tar.bz2']
## Package Plan ##
  environment location: /Users/jeanmarc/miniconda3/conda-bld/freecad_1552144669386/_h_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold
The following NEW packages will be INSTALLED:
    blas:            1.1-openblas               conda-forge
    boost-cpp:       1.68.0-h6f8c590_1000       conda-forge
    bzip2:           1.0.6-h1de35cc_1002        conda-forge
    ca-certificates: 2019.3.9-hecc5488_0        conda-forge
    certifi:         2019.3.9-py37_0            conda-forge
    coin3d:          4.0.0-hf9e6f3b_1004        conda-forge
    curl:            7.64.0-heae2a1f_2          conda-forge
    doxygen:         1.8.14-0                   conda-forge
    eigen:           3.3.7-h04f5b5a_1000        conda-forge
    expat:           2.2.5-h0a44026_1002        conda-forge
    freeimage:       3.17.0-0                   conda-forge
    freetype:        2.9.1-h597ad8a_1005        conda-forge
    future:          0.17.1-py37_1000           conda-forge
    hdf4:            4.2.13-hf3c6af0_1002       conda-forge
    hdf5:            1.10.4-nompi_h646315f_1105 conda-forge
    icu:             58.2-h0a44026_1000         conda-forge
    jpeg:            9c-h1de35cc_1001           conda-forge
    jsoncpp:         1.8.4-h04f5b5a_1001        conda-forge
    krb5:            1.16.3-hcfa6398_1001       conda-forge
    libcurl:         7.64.0-he376013_2          conda-forge
    libcxx:          7.0.0-h2d50403_1           conda-forge
    libedit:         3.1.20170329-hcfe32e1_1001 conda-forge
    libffi:          3.2.1-h0a44026_1005        conda-forge
    libgfortran:     3.0.1-0                    conda-forge
    libiconv:        1.15-h1de35cc_1004         conda-forge
    libnetcdf:       4.6.2-h6b88ef6_1001        conda-forge
    libogg:          1.3.2-h1de35cc_1001        conda-forge
    libpng:          1.6.36-ha441bb4_1000       conda-forge
    libssh2:         1.8.0-hb1dc21d_1004        conda-forge
    libtheora:       1.1.1-h1de35cc_1001        conda-forge
    libtiff:         4.0.10-h79f4b77_1001       conda-forge
    libvorbis:       1.3.5-h1de35cc_1001        conda-forge
    libxml2:         2.9.8-hf14e9c8_1005        conda-forge
    libxslt:         1.1.32-h33a18ac_1002       conda-forge
    llvm-meta:       7.0.0-0                    conda-forge
    lz4-c:           1.8.1.2-0                  conda-forge
    m4:              1.4.18-h1de35cc_1001       conda-forge
    ncurses:         6.1-h0a44026_1002          conda-forge
    netgen:          6.2.1808-py37h568d2b9_1005 conda-forge
    occt:            7.3.0-h1df9755_1002        conda-forge
    openblas:        0.3.5-h436c29b_1000        conda-forge
    openssl:         1.1.1b-h1de35cc_1          conda-forge
    pcre:            8.41-h0a44026_1003         conda-forge
    pip:             19.0.3-py37_0              conda-forge
    pivy:            0.6.5a0-py37h9e2f8fd_1000  conda-forge
    pthread-stubs:   0.4-h1de35cc_1001          conda-forge
    pybind11:        2.2.4-py37h04f5b5a_1000    conda-forge
    pyside2:         5.6.0a1-py37h98637d4_1004  conda-forge
    python:          3.7.1-hbdd33cc_1002        conda-forge
    qt:              5.6.2-h822fa55_1013        conda-forge
    readline:        7.0-hcfe32e1_1001          conda-forge
    setuptools:      40.8.0-py37_0              conda-forge
    smesh:           8.3.0.2-hb6922d4_3         conda-forge
    soqt:            1.6.0a-h04f5b5a_1000       conda-forge
    sqlite:          3.26.0-h1765d9f_1001       conda-forge
    swig:            3.0.12-h0a44026_1003       conda-forge
    tbb:             2019.4-h04f5b5a_0          conda-forge
    tbb-devel:       2019.4-h04f5b5a_0          conda-forge
    tk:              8.6.9-ha441bb4_1000        conda-forge
    vtk:             8.1.2-py37h238a7ee_1200    conda-forge
    wheel:           0.33.1-py37_0              conda-forge
    xerces-c:        3.2.2-h44e365a_1001        conda-forge
    xz:              5.2.4-h1de35cc_1001        conda-forge
    zlib:            1.2.11-h1de35cc_1004       conda-forge
Preparing transaction: ...working... done
Verifying transaction: ...working... done
Executing transaction: ...working... done
WARNING: symlink_conda() is deprecated.
## Package Plan ##
  environment location: /Users/jeanmarc/miniconda3/conda-bld/freecad_1552144669386/_build_env
    cctools:         895-h7512d6f_0             conda-forge
    clang:           4.0.1-h662ec87_0           conda-forge
    clang_osx-64:    4.0.1-h1ce6c1d_11          conda-forge
    clangxx:         4.0.1-hc9b4283_0
    clangxx_osx-64:  4.0.1-h22b1bf0_11
    cmake:           3.13.4-h1e01633_0          conda-forge
    compiler-rt:     4.0.1-h5487866_0           conda-forge
    gettext:         0.19.8.1-hcca000d_1001     conda-forge
    git:             2.21.0-pl526h3e3e3d1_0     conda-forge
    ld64:            274.2-h7c2db76_0           conda-forge
    libcxx:          4.0.1-h579ed51_0
    libcxxabi:       4.0.1-hebd6815_0           conda-forge
    libuv:           1.26.0-h1de35cc_0          conda-forge
    llvm:            4.0.1-hc748206_0           conda-forge
    llvm-lto-tapi:   4.0.1-h6701bc3_0           conda-forge
    ninja:           1.9.0-h04f5b5a_0           conda-forge
    perl:            5.26.2-h79c3c89_1002       conda-forge
    rhash:           1.3.6-h1de35cc_1001        conda-forge
Source cache directory is: /Users/jeanmarc/miniconda3/conda-bld/src_cache
INFO:conda_build.source:Source cache directory is: /Users/jeanmarc/miniconda3/conda-bld/src_cache
Found source in cache: freecad_0.18_5829bbb131.tar.gz
INFO:conda_build.source:Found source in cache: freecad_0.18_5829bbb131.tar.gz
Extracting download
Applying patch: '/Users/jeanmarc/code/freecad-feedstock/recipe/osx.patch'
Trying to apply patch as-is
INFO:conda_build.source:Trying to apply patch as-is
(Stripping trailing CRs from patch.)
patching file src/Mod/Drawing/Gui/DrawingView.cpp
Hunk #1 FAILED at 65.
1 out of 1 hunk FAILED -- saving rejects to file src/Mod/Drawing/Gui/DrawingView.cpp.rej
Warning: failed to download source.  If building, will try again after downloading recipe dependencies.
Error was:
Command '['/usr/bin/patch', '-p1', '--ignore-whitespace', '-i', '/Users/jeanmarc/code/freecad-feedstock/recipe/osx.patch']' returned non-zero exit status 1.
Failed to download or patch source. Please see build log for info.
I have uploaded @looo’s build to the GitHub releases page. Is there any reason not to delete the older .dmg’s?
@looo you may consider removing the offline docs from future builds. I have loaded the offline docs as a separate package, so the user only has to download once. This is what I’m doing with win already.
For some reason, it seems that sources have not been extracted by the archive which would explain the patch error. I am still finding out where the “src” directory is located…
Still no getting why I have this src patching issue.
I only managed to succefully build FreeCAD from the sources with brew following those guidelines https://github.com/FreeCAD/homebrew-freecad
I understand the reason to use a “unique” build system, but I have to admit that conda is (far) more complicated to use and properly setup on MacOSX than brew…
We need to check if the dmg I produced works also on other systems. I fear there is something wrong with the paths…
I am also not yet sure why the patching isn’t working. But I think this patch isn’t needed anymore.
I just downloaded the conda packaged DMG on github. It doesn’t work: LSOpenURLsWithRole() failed with error -10810 for the file /Applications/FreeCAD.app :frowning:
Currently the only way I managed to run the latest FreeCAD (but not from the sources) is:
$ conda create --name freecad-dev3 blas=*=openblas python=3.6 tbb=2018.0.5 occt=7.3 freecad -c freecad/label/dev
$ conda activate freecad-dev3
$ conda install freecad
$ freecad
This approach is quite OK, but it is not an actual MacOS package app that can be distributed as such.
Now it still wonder how I can create and run the app if I start developping for it from the sources…
Question: which version of FC is hosted on conda-forge and which is found on http://conda.anaconda.org/freecad/label/dev?
In which path do you have FreeCAD.app? I can create the same and try again.
15310 can be removed. We should keep 15525 until the path issue with the new version is solved.
No luck here either:
Abort trap: 6
thanks for your reports @chrisb, @pablogil
with this I was able to reproduce the problem on my machine too.
Previously it was working for me, because I didn’t delete the environment where all the stuff was bundled. So somehow some libraries were calling stuff from this environment. After deleting this environment I got the same error report (something about qt-plugins…)
I remeber having similar problem on windows and linux. So I tried a similar solution like we use for the appimage. This is setting some env-variables which point to the extracted directory and are set (exported) in the initialization script.
So there is still the possibility of some stuff not setup in a correct way, but this is the same for the appimage too. As the conda-based appimage has shown to work quite nicely, I guess also the mac dmg should give similar results (hopefully)
I created a new freecad-build and a new dmg. Maybe you can try this again:
https://www.dropbox.com/sh/tcpg7xrvjdun1wa/AACORZUqJeKs1Yws1Bt5Oteia?dl=0
