Import SVG Bug?
I’m attempting to import the svg code below and extrude it into a solid. However, when I import the file, which is a closed path with 4 arcs and two lines, FreeCAD breaks it up into four open paths. I’ve tried a few variations, using A and L, a and l, with and without translate, etc. The result is always the same.
.cls-1 { fill: none; stroke: #231f20; stroke-miterlimit: 10; }
OS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Unfortunately as I found out recently while carrying out a very complex SVG import from Inkscape 1.01 there seems to have been a change in the construction of the SVG files. If I import/load a Inkscape 1.01 file into version 0.92.4 it will open correctly but saving it in 0.92.4 as a Plain SVG results in a file that FreeCAD does not always construct correctly. In the past a file created in 0.92.4 was a reliable workflow, this caused me close on 14 hours work reconstructing the SVG from scratch, the Inkscape devs are not on my Xmas card list to say the least.
Below is the SVG that will import correctly into FreeCAD, you’ll notice a significant difference in the xml:
<?xml version="1.0"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 1.1//EN" "http://www.w3.org/Graphics/SVG/1.1/DTD/svg11.dtd">
<svg width="73.0mm" height="70.0mm" viewBox="54.540000 -78.680000 73.000000 70.000000" xmlns="http://www.w3.org/2000/svg" version="1.1">
<g id="Sketch001" transform="scale(1,-1)">
<path id="Sketch001_w0000"  d="M 63.540000000000006 78.68 C 61.42853557423195 78.84493894101419 58.93340007004436 73.88857529288455 57.17426318828601 63.74431834110994 C 55.38408817456327 53.775807885158336 54.51006368319523 39.64026489180611 54.540000000000006 27.68 C 54.510063683195256 23.225690114503966 55.38408817456319 17.960624110539545 57.174263188286034 14.246843933037578 C 58.93340007004433 10.46763233119056 61.428535574231965 8.620027233426459 63.540000000000006 8.68 L 118.54 8.68 C 120.65146442576807 8.62002723342645 123.14659992995567 10.467632331190561 124.905736811714 14.246843933037587 C 126.69591182543678 17.960624110539555 127.56993631680479 23.22569011450398 127.54 27.68000000000002 C 127.5699363168047 39.64026489180615 126.69591182543692 53.77580788515833 124.90573681171395 63.74431834110995 C 123.14659992995585 73.88857529288461 120.65146442576794 78.84493894101418 118.54 78.68 L 63.540000000000006 78.68 " stroke="#231f20" stroke-width="0.35 px" style="stroke-width:0.35;stroke-miterlimit:4;stroke-dasharray:none;fill:none;fill-rule: evenodd "/>
<title>b'Sketch001'</title>
</g>
</svg>
OS: Windows 7
Qt version: 5.6.2
It’s going to take a significant bit of debugging to get the FreeCAD importer to handle both correctly IMHO and yes it’s the same for me using:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.22474 (Git)
Hash: a44f8ffd427fa9b23b1f00dbf62d66cd152cd774
Python version: 3.6.8
Qt version: 5.12.1
I concur with this assessment.
The code for importing SVG needs to be revised in the Draft Workbench, the importSVG.py file primarily. I’ve been doing a few fixes here and there, but it needs to be thoroughly checked to make sure old code still works as intended.
And maybe we need to test with SVG files coming from different sources, as I suspect most testing is done with Inkscape files just because it’s what is available to the free software community. Maybe they don’t follow the standard, or they do, but our code doesn’t handle that part very well.
Thanks for the answers.
t seems like the arc directive (A or a) blows it up. Without those, it works. Unfortunately for this situation, I really need to import the arcs.
So it turns out bezier curves (in my case, c and s) work okay. I was able to move the path from elliptic arcs to bezier curves and get close enough that everybody is okay with the “new design” and we’re moving forward. Thanks.
