How to check where negative Jacobina are
I have a question about tips and tricks around negative jacobian.
Most of the time i make the mesh finer and it resoved it self.
Now i have a imported step file. 2 sheetmetal plates (created in NX) and two other parts.
the point is i have now upper limit = 1 mm, lower limit = 10 µm and still:
Gmsh had warnings ...
Warning : Volume mesh: worst distortion = -0.77866 (avg = 0.999257, 11 elements with jac. < 0)
Warning : ------------------------------
Warning : Mesh generation error summary
Warning :     1 warning
Warning :     0 errors
Warning : Check the full log for details
I have 2770104 Nodes and 1814745 Volumes
What trick do FC have to now where the neg jacobians are.
I know the existence of boundary layer and mesh region. But does that work when the lower limit == 10 µm?
You can not show the negtive jacobians of gmsh in FC. You would need to use gmsh for this.
What you can do, just run it in ccx and see what happens. Sometimes it runs anyway. Sometimes ccx complains about negative (nonpositive) jacobians too. Sometimes not. Sometimes it complains about them without gmsh complaining. If you have 11 element out of 2700000 it is quite common any of the above can happen. If you would have 2000 out of them normaly gmsh and ccx will complain.
The nonpositive jacobians of ccx will show green in result mesh. Just use the run button to run the analysis not the task panel. https://forum.freecadweb.org/viewtopic.php?t=21075&start=10#p163902
BTW: In most cases it is the upper limit not the lower limit the problem.
I tried (with another model) Don’t know where the problem comes from.
When using the sover menu(write analysis >> run solver) i get the negative jacobian error but no green dots. when using the SolverRun command buttun i got first a Calculix 201 Error (by 88xxx nodes).
After that i remeshed (11xxx nodes) both methods the green dots don’t show up. as last i tested the experimental solver also no green dots…
OS: Windows 7 SP 1 (6.1)
Version: 0.19.21514 (Git)
Hash: 89ddab33f692a9bd739171689f9ab0eb58d64b35
Python version: 3.6.8
Qt version: 5.12.1
You need to use the standard CalculiX solver. Would you post the FreeCAD file?
Here you should see some prints in the report view and the green dots in the 3D scene.
jaut gave it another try. If the run button is used the nonpositve jacobians are green for me. You need to activate the mesh to see them!
Do you meant this button: https://wiki.freecadweb.org/FEM_SolverRun ?
when that button i got:
CalxuliX ccx tools solver!
References: empty in MaterialSolid, MaterialSolid
References: Face in ConstraintFixed, ConstraintFixed
References: Face in ConstraintForce, ConstraintForce
Check prerequisites.
Start writing CalculiX input file
Write ccx input file to: C:\Users\USER\AppData\Local\Temp\fcfem_vsw4x817\FEMMeshGmsh.inp
ConstraintFixed:
    Type: Fem::ConstraintFixed, Name: ConstraintFixed
  found mesh group for the IDs: ConstraintFixed_Nodes, Type: Node
Writing time CalculiX input file: 0.3 seconds
Writing CalculiX input file completed.
Run CalculiX ...
It seams we run into NOANALYSIS problem, thus workaround for wrong exit code for *NOANALYSIS check and set ret_code to 0.
We will load the ccx frd and dat result file.
Read ccx results from frd file: C:\Users\USER\AppData\Local\Temp\fcfem_vsw4x817\FEMMeshGmsh.frd
Nodes, but no results found in frd file. It means there only is a mesh but no results in frd file. Usually this happens for:
- analysis type 'NOANALYSIS'
- if CalculiX returned no results (happens on nonpositive jacobian determinant in at least one element)
- just no frd results where requestet in input file (neither 'node file' nor 'el file' in output section')
Read ccx results from dat file: C:\Users\USER\AppData\Local\Temp\fcfem_vsw4x817\FEMMeshGmsh.dat
When using the write inp → run calculix menu i got
0.0: Check dependencies...
0.3: Write completed.
0.0: CalculiX binary: C:/Users/USER/Downloads/FreeCAD_0.19.21514_x64_LP_12.1.6_PY3QT5-WinVS2015/bin/ccx.exe
0.0: CalculiX input file: C:\Users\USER\AppData\Local\Temp\fcfem_obbqgo88\FEMMeshGmsh.inp
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX is running...
0.7: CalculiX stopped.
0.7: ************************************************************
CalculiX Version 2.15, Copyright(C) 1998-2018 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on niedz., 16 gru 2018 14:14:23
The numbers below are estimated upper bounds
number of:
nodes: 11296
elements: 10012
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 4
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 0
single point constraints: 351
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 5
terms in all sets: 39137
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 1
data points in all amplitudes: 1
print requests: 1
transformations: 0
property cards: 0
*WARNING: no analysis option was chosen
STEP 1
No analysis was selected
Decascading the MPC's
Determining the structure of the matrix:
number of equations
33537
number of nonzero lower triangular matrix elements
1115283
Using up to 4 cpu(s) for the stress calculation.
Using up to 4 cpu(s) for the symmetric stiffness/mass contributions.
*ERROR in e_c3d: nonpositive jacobian
determinant in element 6255
determinant in element 6286
determinant in element 6371
determinant in element 6484
determinant in element 6558
determinant in element 6702
determinant in element 9469
determinant in element 9470
determinant in element 6731
determinant in element 6750
determinant in element 9531
determinant in element 9533
determinant in element 9540
determinant in element 9587
determinant in element 9588
determinant in element 9597
determinant in element 9600
determinant in element 9609
determinant in element 6904
determinant in element 9838
determinant in element 9842
determinant in element 9844
determinant in element 9908
determinant in element 9966
determinant in element 10012
determinant in element 7217
0.7: CalculiX execute error:
0.7: Loading result sets...
and
Run CalculiX ...
Write ccx input file to: C:\Users\USER\AppData\Local\Temp\fcfem_obbqgo88\FEMMeshGmsh.inp
ConstraintFixed:
run CalculiX at: C:/Users/USER/Downloads/FreeCAD_0.19.21514_x64_LP_12.1.6_PY3QT5-WinVS2015/bin/ccx.exe with: C:\Users\USER\AppData\Local\Temp\fcfem_obbqgo88\FEMMeshGmsh.inp
CalculiX returned an error due to nonpositive jacobian determinant in at least one element
Use the run button on selected solver to get a better error output.
Error()
Read ccx results from frd file: C:\Users\USER\AppData\Local\Temp\fcfem_obbqgo88\FEMMeshGmsh.frd
Read ccx results from dat file: C:\Users\USER\AppData\Local\Temp\fcfem_obbqgo88\FEMMeshGmsh.dat
So i don’t completly understoot what button you meant
yes, exactly this button. As said before it does NOT show the nonpositive jacobians if the solver task panel is used.
Furthermore you seam to use checking solver mode.
It for sure shows the nonpositive jacobians in frequency analysis. Just add an analysis, a solver set solver to frequency, add a material and hit the run button.
  • start FreeCAD
  • load the file
  • activate the analysis
  • run analysis with run button (do NOT use the task panel)
21:08:12  CalxuliX ccx tools solver!
21:08:12  References: empty in MaterialSolid, MaterialSolid
21:08:12  Check prerequisites.
21:08:12  Start writing CalculiX input file
21:08:12  Write ccx input file to: /home/hugo/Desktop/nonpositive_jacobians_ex01/SolverCcxTools/FEMMeshGmsh.inp
21:08:12  Writing time CalculiX input file: 0.07 seconds
21:08:12  Writing CalculiX input file completed.
21:08:12  Run CalculiX ...
21:08:12  CalculiX failed with exit code 201
21:08:12  --------start of stderr-------
21:08:12  --------end of stderr---------
21:08:12  --------start of stdout-------
21:08:12
CalculiX Version 2.17, Copyright(C) 1998-2020 Guido Dhondt
You are using an executable made on Thu Jul 23 21:43:50 CEST 2020
  number of:
   nodes:         4231
   elements:         3721
   single point constraints:            0
   tie constraints:            0
   sets:            4
   terms in all sets:        15251
   materials:            1
   orientations:            0
   amplitudes:            0
   data points in all amplitudes:            0
   print requests:            0
   transformations:            0
   property cards:            0
 STEP            1
 Frequency analysis was selected
 number of equations
 12693
 447204
        determinant in element        3159
        determinant in element        3161
        determinant in element        3192
        determinant in element        3194
        determinant in element        1972
21:08:12
--------end of stdout---------
21:08:12  --------start problems---------
21:08:12
CalculiX returned an error due to nonpositive jacobian elements.
21:08:12  nonpositive_jacobian_elements = [1972, 3159, 3161, 3192, 3194]
21:08:12  nonpositive_jacobian_elenodes = [335, 337, 398, 418, 428, 1253, 1262, 1264, 1279, 1289, 1302, 1310, 1400, 1406, 1408, 1444, 1445, 1446, 1447, 1448, 1450, 1746, 1746, 1747, 2164, 2167, 2183, 2184, 2185, 2348, 2348, 2351, 2351, 2363, 2367, 2368, 2369, 2369, 2370, 2600, 3605, 3684, 3938, 3938, 4055, 4056, 4110, 4111, 4161, 4161]
21:08:12
21:08:12
Following some commands to copy. They highlight the nonpositive jacobians or to reset the highlighted nodes:
21:08:12  Gui.ActiveDocument.FEMMeshGmsh.HighlightedNodes = nonpositive_jacobian_elenodes
21:08:12  Gui.ActiveDocument.FEMMeshGmsh.HighlightedNodes = []
21:08:12
--------end problems---------
21:08:12  CalculiX finished with error 201.
nonpositive_jacobians_ex01.FCStd (214 KB)
i check your example tomorow
