Hijack and override all file browser windows
I am working on some functionality that will link FreeCAD with a document database that is much more structured and controlled that a bunch of folders.
I was hoping that there might be a way to hijack and replace the global file browser dialog in FreeCAD. I imagine that this would be some where in the QT stuff.
Right now I launch FreeCAD calling an external macro at start when starting FreeCAD.
freecad ./myPython3code.py
Would much prefer not to have to mess around and build FreeCAD from scratch.
Thanks for any help or examples.
After investigating I found the following.
If it helps the thing I am looking to override is.
from PySide import QtGui
QtGui.QFileDialog
It looks like the following pattern might work. Looks like i might have really beef up on QT.
from PySide import QtCore, QtGui
class MyCoolFileDialog(QtGui.QFileDialog):
	print("yay")
QtGui.QFileDialog = MyCoolFileDialog
can anyone in the community weigh in on this ?
Best to first introduce your own file browser. Once that will be working, worry about the rest. Like hiding things you don’t want people to use, and instead expose the ones you do want the people to use.
P.S. A lot of new developers are too much focused on details, better to do the other 90% first. :wink:
I was hoping that some one might be able to make a little example with a hard coded file path return value. If I had that I think the rest would be pretty easy for me to work out.
What is your DBFS ? What is its API to list/open files ? Where is an example accessible ?
This is a tough work to do though.
Also ATM, I don’t see how we could integrate it without needing a specific compilation…
I figured the hard part would be replacing the dialogs in the program, not the catching of files on a server to a temp directory and pushing them back to server.
As to the API to be used for communicating with the server. I have a system that manages rev controlled CAD data. Looks like there will be some work on it to make it handle FreeCAD files but I don’t expect that to be an issue. I think that having an example of how to override this dialog would be beneficial to any one who is trying to set up FreeCAD in a more structured environment.
I have $75 I am willing to spend for a short example with the following.
Replace hijack and replace all file dialogs in free cad.
A textbox with the file location.
A list box that can be populated from some kind of an array. Selecting an item sets the file name in the text box. List can be hard coded for example.
An ok button that can call a function that shows a msgbox with the file name followed by the default behavior for opening or selecting the file.
I don’t know whether you can replace ALL file dialogs, but you can look in:
  • A2+ workbench, in the file a2p_importpart.py, look for
dialog = QtGui.QFileDialog( QtGui.QApplication.activeWindow(),  "Select FreeCAD document to import part from"  )
dialog.setNameFilter("Supported Formats (*.FCStd *.fcstd *.stp *.step);;All files (*.*)")
  • Assembly4 workbench, placeLinkCmd.py:
parentList = QtGui.QComboBox()
for obj in objTable:
  objIcon = obj.LinkedObject.ViewObject.Icon
  objText = Asm4.nameLabel(obj)
  parentList.addItem( objIcon, objText, obj)
partLCSlist = QtGui.QListWidget()
for lcs in partLCStable:
  newItem = QtGui.QListWidgetItem()
  newItem.setText(Asm4.nameLabel(lcs))
  newItem.setIcon( lcs.ViewObject.Icon )
  partLCSlist.addItem(newItem)
Maybe we can open a bountysource bounty for this ?
@yorik care to weigh in ?
