Can you recommend tutorials on FreeCAD for woodworking.
At this point I’d be happy if I could design a bookshelf.
That means vertical pieces, horizontal pieces.
Front or back not very significant yet, maybe just a 1/8" piece of wood for the back.
Dimensions set in a spreadsheet, so I can change them.
Each board is a separate file, and they are assembled (Assembly4?).
I’ll need a cut list.
A2plus is the successor of Assebmly2, and it is very much alive and maintained. But it is not compatible with the original Assembly2.
Assembly3 and Assembly4 are workbenches that use the new “App::Link” element, introduced in 0.19. They are still experimental, but they may be good enough for your usecase.
Assembly3 cannot be installed from the Addon Manager yet; Assembly4 can be installed from the Addon Manager.
i think it is same as what in dutch called a ‘zaaglijst’ most used for stock products like beams that is bought on default lengths and are just cut off from this lengths.
most of the time there are no drawings from it just a list, a (raw )material, length and amount of every peace…
Similar as you say. But many woodworkers in the USA now use plywood and the cut list helps to optimize the use of a sheet of plywood. At $50-$80 a sheet, we woodworkers like to get the most parts possible from a sheet, hence we spend a lot of time developing a cut list.
