I’ve noticed a memory leak in Path that caused my machine to go OOM overnight a couple times.
DeepSOIC showed that the leak shows up in Part-o-Magic as well if there’s a lot of objects in the tree.
I started disabling parts of Path to track it down and finally got it to where I can reproduce the leak entirely outside Path with a macro.
To reproduce,
- start FreeCAD clean
- Execute the macro. This will create a 1000 cubes in the tree, create a command and workbench.
- Watch memory usage for a minute or so and it should stabilize.
- Switch to the new workbench and the memory will start climbing and not stabilize.
The bug seems to be related to the isActive() code. I can disable this and the leak doesn’t happen. I think the leak is particularly noticable in Path because we use a use a lot of these isActive implementations.
The leak doesn’t seem to happen in the Sketcher WB or any other workbench that I tested. Perhaps it’s python related?
import FreeCAD,FreeCADGui
class JunkWorkbench (Workbench):
"Junk workbench"
def __init__(self):
self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/Path/Resources/icons/PathWorkbench.svg"
self.__class__.MenuText = "Junk"
self.__class__.ToolTip = "Junk workbench"
def Initialize(self):
self.appendToolbar("junk", ['MyCommand1'])
class MyTool:
"My tool object"
"This function is executed when FreeCAD starts"
self.list = ["MyCommand1"]
self.appendToolbar("My Commands",self.list)
def GetResources(self):
return {"MenuText": "My Command",
"Accel": "Ctrl+M",
"ToolTip": "My extraordinary command"}
def IsActive(self):
if FreeCAD.ActiveDocument is not None:
for o in FreeCAD.ActiveDocument.Objects:
if o.Name[:3] == "Job":
return True
return False
def Activated(self):
pass
# do something here...
# Add a bunch of objects to the tree
for i in range(1000):
App.ActiveDocument.addObject('Part::Box')
# Create a command and a workbench and add the icon to a toolbar.
FreeCADGui.addCommand('MyCommand1',MyTool())
FreeCADGui.addWorkbench(JunkWorkbench())
