FEM Mesh has no Volumes
Hi there,
I’m trying to run a FEM analysis on a model based from an STL file.
My process:
  1. repair mesh if needs
  2. create shape from mesh
  3. refine shame
  4. convert to solid.
Then in FEM when creating a mesh it refuses to create any volumes. Only surfaces.
File attached
Thanks in adavnce
fcthingy.FCStd (147 KB)
I’m on the way … Jus two hints … Have you run Part check geometry on it? Is is really a valid solid?
yep, Part → check geometry shows there are holes in the Shape, thus it is not a valid Solid, because the Shell is not closed …
BTW: which version of FreeCAD do you run? You should have at least 0.17 Release Roland !
Aha,
I’ll try to fix this and give it another go.
Thanks again
Because of the sheetmetal like structure, it will be better to go not for a solid but for a shell.
repaired.FCStd (387 KB)
done with:
OS: Windows 10
Version: 0.18.13892 (Git)
Hash: 23f58f1afc710c6189ac44414c8696e8e838535c
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
workflow:
  • downgraded your “solid”
  • deleted unneeded faces (all the tiny ones)
  • repaired some gaps
  • upgraded to shell
  • ready to FEM :smiley:
I’m interested why you recommend the shell over solid? Presumably you can still set the shell thickness to model sheet metal?
Is it more accurate?
As a side note I found the model error in autocad and smoothly sailed into fem (solid). So thank you all for your help. didn’t notice the error
