i have mentioned a problem with a LeadInOut dressup after a Tag dressup in this post some time ago: https://devtalk.freecad.org/t/problem-with-dressup-tag/71620/1 (my last post in this thread)
This problem is still present and you can find an example in the file attached. If i try do add the LeadInOut dressup on top of the Tag dressup made on Profile i get the following error:
Running the Python command 'Path_DressupLeadInOut' failed:
File "C:\Program Files\FreeCAD 0.21\Mod\Path\Path\Dressup\Gui\LeadInOut.py", line 724, in Activated
FreeCADGui.doCommand("dbo.setup(obj)")
File "C:\Program Files\FreeCAD 0.21\Mod\Path\Path\Dressup\Gui\LeadInOut.py", line 147, in setup
obj.Length = obj.Base.ToolController.Tool.Diameter * 0.75
'FeaturePython' object has no attribute 'ToolController'
And the LeadInOut dressup is created standalone above the Tag dressup in the tree. It is not editable, if you made a double click on it i get into the transformation window…
OS: Windows 11 build 22631
Version: 0.21.0.33668 +7 (Git)
Branch: (HEAD detached at 0.21)
Hash: 41b058e2087de60dc8fef3d3e68c7d0129e13abf
* A2plus 0.4.61
* btl 0.9.9
* fasteners 0.4.71
* FeedsAndSpeeds 0.5.0
* Lithophane
* Manipulator 1.5.0
* OpenDark 2023.11.27
* QuickMeasure 2022.10.28
* sheetmetal 0.3.12
