Creating inlays
This is just me mucking around to see what’s possible. My methods work in some designs and sizes and go very wrong in other cases. Camotics is recommended and also watching some back plots in f-engrave to see that software’s approach.
How the v-carved outline was done:
Assuming inkscape is displaying stroke with no fill.
In inkscape preferences change behaviour-steps-inset/outset to the desired face width
Make a duplicate of the current path.
Apply Path → Inset
Select the outside path and apply a black fill.
Ctrl + A to select all.
Path → Difference.
Save the file as an Inkscape SVG.
In Draft select both outer+inner path then 2 modification downgrades.
Attached is an example, zipped in case a svg isn’t accepted.
I’ve also kept a bit of a diary. Be warned it’s a hot mess created while learning (and finding easier ways) but it may contain something useful.
https://steppingintocnc.blogspot.com/
Lol I’m so slow Russ4262 posted in front. Hope this doesn’t double post.
xmas_tree_inlay.zip (3.74 KB)
Thanks Brad, you are absolutely right, it is creating a median line through the face. So it is working correctly it just doesn’t do what I had hoped it was going to do. Thanks for clarifying that for me.
Thanks, I have done this in F-Engrave (great no nonsense app) and Fusion 360. I understand it is a difficult thing to do without the tools to do it. I appreciate you sharing what you have so far.
It looks like you are making great progress. - The lines seem to be what would be needed. Please post when you have a “shareable” macro, I would love to give it a try.
I’ve been using F-engrave for years with the plotting turned off. When this topic was posted I started to pay attention to how and why it works.
What I’ve done isn’t as cumbersome as it looks, unfortunately I can now predict pretty quickly where it’s going to fail :slight_smile:
Russ4262
Need test pilots ? I’m good at breaking things.
ps/ You may already be aware of this and may be not relevant but anyway:
http://k40.scorchworks.com/Fengrave/f-engrave_calculations.htm
I’ve used F-Engrave for years (still do). Scorch has done some amazing things with it and I respect him immensely. Both F-engrave and it’s sister G-codeRipper can do some things that Path still can’t do. That said, there is some nonsense, it’s just under the hood:
It’s a single python file (currently approaching 10000 lines) - which is super hard to comprehend.
The user-interface uses Tk which has been declining in popularity for twenty years.
The ui code and the application logic are tightly coupled so refactoring it would be difficult.
Scorch doesn’t maintain the code in a git repo so it’s almost impossible for anyone to contribute, either bugs or fixes.
Finally, It’s licensed GPL3 which limits code re-use by other more permissive software (FreeCAD).
I like the software but I really hope Scorch doesn’t go near any buses.
I approached him to get the files it creates concatenated into one file with a tool change but he said it wasn’t possible. I created a fairly trivial separate python program to do the concatenation and insert the tool change so that it would work for me. - I like that it works but haven’t looked under the hood. It does take a little understanding.
I am looking forward to the time when FreeCAD can do this without too many tweaks. - I have seen great things happening with the software. I am really pleased I came back to it from Fusion 360.
Thanks, I had looked at the math and some other folks papers on this. It is sufficiently complicated that I don’t think I can add to the solution but would be happy to try if someone else wants to see how it cuts. :wink:
