CfdOF unable to run command in OpenFOAM
This is the error message
subprocess.CalledProcessError: Command 'echo $WM_PROJECT_VERSION' returned non-zero exit status 1.
Full error message:
13:06:49  Executing: echo $WM_PROJECT_VERSION in None
13:06:49  /bin/bash: line 1: \wsl.localhost\Ubuntu-20.04\opt\OpenFOAM\OpenFOAM-v2012/etc/bashrc: No such file or directory
13:06:49  OpenFOAM installation found, but unable to run command: Command 'echo $WM_PROJECT_VERSION' returned non-zero exit status 1.
13:06:49  Traceback (most recent call last):
13:06:49    File "C:\Users\wong2\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\CfdPreferencePage.py", line 276, in runDependencyChecker
13:06:49      CfdTools.checkCfdDependencies(lambda msg:  (print(msg), self.consoleMessage(msg)))
13:06:49    File "C:\Users\wong2\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\CfdTools.py", line 1074, in checkCfdDependencies
13:06:49      foam_ver = runFoamCommand("echo $WM_PROJECT_VERSION")[0]
13:06:49    File "C:\Users\wong2\AppData\Roaming\FreeCAD\Mod\CfdOF\.\CfdOF\CfdTools.py", line 929, in runFoamCommand
13:06:49      raise subprocess.CalledProcessError(exit_code, cmdline)
13:06:49  subprocess.CalledProcessError: Command 'echo $WM_PROJECT_VERSION' returned non-zero exit status 1.
What I did previously:
Followed https://www.openfoam.com/download/openfoam-installation-on-windows-10.
Set the path to \wsl.localhost\Ubuntu-20.04\opt\OpenFOAM\OpenFOAM-v2012
I also tried setting the path to bryann@DESKTOP-PB3S3DT:/opt/OpenFOAM/OpenFOAM-v2012/etc$ echo $WM_PROJECT_DIR
, but it told me it couldn’t find the installation directory
I also verified that the bashrc file was there but CfdOF could not find it.
This was what I got when I ran the echo $WM_PROJECT_VERSION command from the terminal
 /opt/OpenFOAM/OpenFOAM-v2012$ echo $WM_PROJECT_VERSION
v2012
This is what I got from the “Check that everything is OK” part
Time = 0.495
Courant Number mean: 0.222158 max: 0.852134
smoothSolver:  Solving for Ux, Initial residual = 2.43518e-07, Final residual = 2.43518e-07, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 5.33314e-07, Final residual = 5.33314e-07, No Iterations 0
DICPCG:  Solving for p, Initial residual = 5.25763e-07, Final residual = 5.25763e-07, No Iterations 0
time step continuity errors : sum local = 6.11228e-09, global = 1.51821e-18, cumulative = 1.09644e-17
DICPCG:  Solving for p, Initial residual = 7.01015e-07, Final residual = 7.01015e-07, No Iterations 0
time step continuity errors : sum local = 7.5484e-09, global = -4.1723e-19, cumulative = 1.05471e-17
ExecutionTime = 0.78 s  ClockTime = 4 s
Time = 0.5
smoothSolver:  Solving for Ux, Initial residual = 2.3091e-07, Final residual = 2.3091e-07, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 5.0684e-07, Final residual = 5.0684e-07, No Iterations 0
DICPCG:  Solving for p, Initial residual = 8.63844e-07, Final residual = 8.63844e-07, No Iterations 0
time step continuity errors : sum local = 8.8828e-09, global = 4.94571e-19, cumulative = 1.10417e-17
DICPCG:  Solving for p, Initial residual = 9.59103e-07, Final residual = 9.59103e-07, No Iterations 0
time step continuity errors : sum local = 9.66354e-09, global = 1.13175e-18, cumulative = 1.21735e-17
ExecutionTime = 0.81 s  ClockTime = 4 s
End
It looks like everything is installed, but CfdOF cannot find the files.
Hi
I have the exact same issue on Ubuntu 22.04.3 LTS running openFoam 11. Paraview is included in this install and the paraFoam examples runs when executed.
06:47:56  OpenFOAM installation found, but unable to run command: Command 'echo $WM_PROJECT_VERSION' returned non-zero exit status 1.
06:47:56  Traceback (most recent call last):
06:47:56    File "/home/carel/snap/freecad/common/Mod/CfdOF/./CfdOF/CfdPreferencePage.py", line 272, in runDependencyChecker
06:47:56      CfdTools.checkCfdDependencies(lambda msg:  (print(msg), self.consoleMessage(msg)))
06:47:56    File "/home/carel/snap/freecad/common/Mod/CfdOF/./CfdOF/CfdTools.py", line 1079, in checkCfdDependencies
06:47:56      foam_ver = runFoamCommand("echo $WM_PROJECT_VERSION")[0]
06:47:56    File "/home/carel/snap/freecad/common/Mod/CfdOF/./CfdOF/CfdTools.py", line 934, in runFoamCommand
06:47:56      raise subprocess.CalledProcessError(exit_code, cmdline)
06:47:56  subprocess.CalledProcessError: Command 'echo $WM_PROJECT_VERSION' returned non-zero exit status 1.
I suspect that it is a permission issue as FreeCAD was installed by the GUI and openFoam by ‘sudo apt install’.
