When I opened the boundaryDressup dlg at first I got a message about three points are colinear.
Later , I just got dumped back to the command line as soon as I opened the dlg.
No problem using dressup except when I had cloned the pocket path.
I had to use the clone without the dressup and hack the gcode by hand to remove the bits I didn’t want.
Hmm…
At the morning I going make a note about (IMO) a more convenient and easy way
But on mentioned above Debian (bookworm) when I tried edit parameters of Boundary Dressup I got full hand of crashes on FC 0.22.0dev.35758.
FC 0.21.1.33694 (official AppImage release) did not crush but did throw errors in report view like
(reproduced on the current system)
, set exclamation mark on existed Boundary Dressup and did not create correct dressup after removing first one.
Now I get same on Windows7 FC 0.21.1.33694. (screenshot were made a few minutes before)
