This is an example of how to model in-context or “top-down” using Assembly4. The assembly is based on a design found here: https://www.youtube.com/watch?v=zU1F-RnprBU which I think serves as a good comparison between FreeCAD and Solidworks capabilities.
There seems to be some confusion of new users and lots of questions about how to best attach and locate the universal LCS connectors that Assembly4 uses as joints. The method presented here is based on the default LCS that is included in the Assembly4 body. This approach simplifies the assembly design process and facilitates in-context modelling which I prefer for designing assemblies. In the captions of the following images I will try to describe in detail the steps used to model each part in the context of the assembly, assemble the bodies, set LCS joint constraints and limits, and animate each degree of freedom the design requires. It is assumed that you are comfortable with PartDesign and the Assembly4 process.
I will be adding more details of the modelling process in additional posts as time allows. Questions or comments are welcome.
OS: Windows 11 build 22621
Version: 0.22.0dev.35639 (Git)
Branch: main
Hash: f315314569aee5334fd0e69a49aab33684a802ba
Python 3.10.13, Qt 5.15.8, Coin 4.0.2, Vtk 9.2.6, OCC 7.6.3
- Assembly4 0.50.6
- fasteners 0.5.0
- freecad.gears 1.2.0
- QuickMeasure 2022.10.28
