ASSEMBLY 4 - Differential - Progress
After a quick review I see at least two areas to look into:
  1. There are no variables in the master sketch.
  2. The base rotation variable needs to be set equal to the master variable.
I’ll look a little more closely tomorrow.
I do not think you can without having to rename the reference in the variables.
I have difficulty applying your answer
I can generate movement on individual pieces but I have a lot of trouble combining several of them. What is the method because I am currently stuck. I try a little each time to finalize the movement on the differential project.
Please review this example of an “event scheduler” using conditional expressions:
https://devtalk.freecad.org/t/grenade-actuation-with-the-assembly4-event-scheduler/62886/1
The other approach is to have one independent time variable and then describe each movement as a function of time, but then, without conditional statements, all of the movements will occur at the same time.
Grenade
A complex exercise to perform combining Subtractive Pipe and MultiTransform
Without the ThreadedRod M14x22.
