ASM4 - Ratchet screwdriver
Some time ago I made some of the parts for a ratchet screwdriver.
So I continued building it under ASM4. Now I have obtained a clean part because I did not have a plan. Apart from the visual of the springs which is problematic under W11, I think that there is no hanging error.
I have started to position a few variables but here I am stumbling over the sequence. It’s the same as setting up the crane. It’s missing something? The idea would be to open the metal handle, give it a rotation without the handle turning.
Q: Why is it not possible for a mirrored piece to make it look
https://drive.google.com/drive/folders/19QnmgaRbfKrn-jBQWZ_p18NmgMWUH4Qg?usp=sharing
If I understand your question correctly, apply a variable to the LCS where the 45 deg is shown in the image:
You can change the black mirrored screw by selecting the mirror original body link and change the View>Lighting to One Side
Note that the mirrored screws will not follow the rotation of their body link attachment when you use the variable a_Mvt for the Cliquet attachment offset angle. It is probably better to attach individual screws to the B_PoigneeMetal by adding the necessary hole axes instead of the Mirror.
EDIT: I created one these long ago as well: https://devtalk.freecad.org/t/v019-top-down-assembly-design-using-assembly4-update-11/42487/40 You may find some hints in my brief descriptions of how I did it at the time.
