Hello. When I try to load a STEP file output from DesignSparkMechanical using FreeCAD 0.21.1 and apply Pocket3D, an error occurs.
When I read the relevant part of the code, it seems that the Shape object that can be obtained after processing with common is invalid, and an exception occurs when obtaining the Volume.
def _identifyRemovalSolids(sourceShape, commonShapes):
"""_identifyRemovalSolids(sourceShape, commonShapes)
Loops through solids in sourceShape to identify commonality with solids in commonShapes.
The sourceShape solids with commonality are returned as Part.Compound shape."""
common = Part.makeCompound(commonShapes)
removalSolids = [s for s in sourceShape.Solids if s.common(common).Volume > 0.0] # raised HERE
return Part.makeCompound(removalSolids)
I think that this problem is with the STEP file reading part rather than with Path Workbench, but I haven’t been able to find the cause that far.
Does anyone know what’s causing the problem?
Indeed, I was able to process it correctly using the file attached by bmsaus4ax.
However, something very strange is happening, and the result changes depending on the order in which the faces are selected.
If I select Face16,Face15,Face1 in that order and add it to Base Geometry, it works fine, but if I add Face1,Face15,Face16 in that order, an error occurs.
