[Sketcher] Distance to circle
See https://devtalk.freecad.org/t/solved-conda-compilations-are-failing-on-all-platforms-no-weekly-builds/68085/1 .
tldr: build system still broken, the “new” builds that are uploaded are just the same reuploaded.
yes, only the date is changing but the build is always the same, moreover the version for py3.10 is still older … 31197 dated 16 February
I just tested circle to circle distance. It works well!
Canit be extended to arcs as well? Like tangency or point-on-object it should work as if it was a full circle, so hopefully it is not too much effort. :mrgreen:
Do you plan to integrate this into 0.21? I want to include this new constraint into my sketcher lecture, and it would of course be less effort, if I could change it all at once.
Hi chrisb ,
Distance to Arc is here : https://github.com/FreeCAD/FreeCAD/pull/9166
and Circle to Line here : https://github.com/FreeCAD/FreeCAD/pull/9044
Thanks flachyjoe, I will describe it in the document hoping that it will make it into 0.21.
Hi flachyjoe,
I’ve noticed that the newly implemented circle to circle distance constraint doesn’t work when one of the circles is an external geometry:
Is that a known limitation ?
No, it’s a bug! :confused:
EDIT: NewJoker FYI the fix is in progress.
EDIT 2: the fix is now merged.
