Pie Menu Improved
Y know that it is a diferent pie receipt, but what about files and columns disposition for the icons ? An option for round pie or square pie ?
No, I mean the menu for entering the value after selecting the operation, it is not somewhere on the side in the form of a panel, but directly in the window next to the model itself. All commercial CAD programs I have tried have the same function. As an example, after creating a sketch, you need to extrude it and after selecting the sketch and activating the operation, a window appears next to the sketch where you can enter a value and there are usually arrows for pulling, rotating, tilting. That’s what I mean
In the basic setting, the value is changed by 1 when you turn the mouse wheel. Would it be possible, for example? pressing another key changes the value by 0.1?
It would be helpful to approach the maximum for complex roundings or bevels.
Yes, it’s a good idea, I will see to add this with the other improvements that will arrive with the next version…
Grazie per l ottimo lavoro bravissimo
Coming soon …
https://youtu.be/ewF9MLnQEjg
Scusa come mai non trovo la cartella PieMenu in mod?
Linux:
/home/user/.FreeCAD/Mod/PieMenu
macOS:
/Users/user_name/Library/Preferences/FreeCAD/Mod/PieMenu
Windows:
C:\Users\user_name\AppData\Roaming\FreeCAD\Mod\PieMenu
or in FreeCAD directory : \FreeCAD\FreeCAD_weekly-builds-35449-2023-12-22-conda-Windows-x86_64-py310\Mod\PieMenu
grazie!!!
Buongiorno,
volevo fare una domanda, siccome ho diverse postazioni pc, c’è un modo per spostare le selezioni del menu? mi spiego meglio: in un pc al posto in alto superiore ho la selezione dimensione, nell’ altro pc invece ho la selezione linea orizzontale. come posso spostare le posizioni nella torta circolare?
Buongiorno,
I’m not sure I understand what you want, but maybe it’s this:
ahh ok non l’avevo proprio visto :laughing:
roberto8303 Sorry, but can you please use English here? Thanks.
Sorry yes
It’s very nice to see how the component acquires new capabilities.
My regards!
hi, why does the abdomen manager only install the piemenu 1.2.7 version? when I open freecad0.22 the piemenu no longer works for me
The version I developed is not the official version, it’s a modified version of version 1.2.7.
You must therefore install it manually by copying the files to the FreeCAD/Mod/PieMenu folder.
Funny auto correction?
I had to uninstall piemode from the addoon manager, create a PieMode folder with the files downloaded from gthub and put it in the mod folder and that’s how it worked
