I’ve tested some dxf with these settings (and, i think, the c++ importer), my result it’s not so good
If I use “goupe layers into blocks” with the majority of project that I converted from DWG to dxf with Qcad pro, Fcad simply crash.
If I don’t use it, it works, but it’s not so quick, and all dimensions, texts, and all is mixed (messed) in the root of the tree So I have to create some order in the caos even to rearrange the tree view with the assets. A lot of work, only to see the file. The scale draw that you import it’s always a mess, because I have to calculate it every time what insert in the import screen, every draw in dwg it’s different, I don’t know why. This is REALLY annoying. Colors are not imported at all. After creating some group, then I have to create large compounds, because when you have a lot of line, it’s not so cool to work/move (even in my WS that it’s really speed up). But if you create compounds and then you want to edit some line, so you have to de-compound, edit the line, and then re-compound. Draft objects too are not convertet so all the lines are not parametric, generally speaking I have to retrace all from zero
Sadly the only solution for me, it’s to preprocess all very well with Qcad pro because Fcad it’s not able to manage (till now, at least!) 2D.
I already said that I (really) hate proprietary and closed standard?
There are definitely issues with working with DWG/DXF in FreeCAD, and up to now, basically either it’s fast but you loose individual objects and colors, or it is slow.
What I’d like to aim at is more tools to work with compound shapes. For example, tools to easily remove or add edges to a compound shape. So you could work fast, making sure everything is always “by layer”, and even so be able to work on subelements
Because the down part till now, it’s importing the assets (a lot of times you have hundreds and hundred of assets in the root of tree view, and maybe some tool here to grouping faster will be needed in the future - like the option to open a big window specific to managing assests, at full scale window UI optimized to manage a big tree, because when you have A LOT of objects imported it’s really complicated/slow/painfull now to manage all in the tree view), and when you recreated some order in the mess, then working with these lines (not parametric because imported) and making compound to what you need to move/edit, it’s really tricky (and/or really slow/painfull as process).
Having the possibilities to edit even a single imported (non parametric) line, without remove the compound (like, to make an example, in Inkscape when you can edit a single part of a group simply by clicking few times the objects, without remove the group), can be REALLY helpfull to work on existing/imported geometries.
Another idea that should be cool to implement: it’s really impossibile to make some tool/macro that try to convert lines (even a selected lines or group or a compound) to to parametric, but mainting single objects?
The not finished pr about subelements move can be of some help, also if i tested It with big 2d objects and it Is really slow… @yorik, did you ever checked It out? https://github.com/FreeCAD/FreeCAD/pull/3716
You take care that everything in your DWG is "ByLayer¨. So we can import one layer = one FreeCAD object and it keeps the correct line style. That’s what everybody would recommend anyway.
We need a new tool to select edges from a shape, and separate them, either all of them into one new shape or each edge in a separate shape
We need another tool that does the opposite, select several shapes, and add their geometry to another shape
The Draft move and rotate tools can already work on subshapes
There would be one more possibility, a special kind of shape where you can give different color/line styles to individual subcomponents. But that seems complex to do for little gain… Maybe not a priority.
Then I think it would be the best of both worlds, fast workflow in FreeCAD (if you have few objects, you can have very, very big drawings), and still the ability to change individual geometry
